Drives: '13 10 Series FRS #1203
Toe Rods with Heim joints making noise?
I just installed PBM's toe rods on the rear of my car, the previous set I had were very inferior and a few months of driving they were squeaking awfully loud and upon taking them apart they were rusted.
Anyways, I decided to pick up a set a PBM's to try, however it seems now that whenever I go over a bump, especially when one side moves more, i get a pop, almost like something is hitting. Everything is tight, and it looks like when sitting in my driveway that the toe rods are a bit crooked and very close to touching the sides of the rod (where the reaches its outward most movement) |
#2 |
Is there any play in the heim joints at all?
#3 |
No they seem solid, but I may have just figured out what it was..
The PBM toe rods are pretty bulky, more so on one side where the threadded slip joints clamp, I have a suspicion they are hitting the traction rods. I'll see about it when I get home. |
| The Following User Says Thank You to Shady195 For This Useful Post: | Sleepless (08-05-2016) |
#4 |
Just drive it
Drives: 13' FR-S
Don't heim joints make noise? I remember having upper control arms in full heim joints in my previous car and it made noise when going over bump. All bolts were tight and solid. So I ended up getting 1 side heim joint and other end factory style bushing and it didn't make noise since then.
#5 | |
Drives: '13 FRS - STX
Ones that are low quality or worn out will make noise. |
#6 | |
| K Sports making noise? | Brentkeys1814 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-22-2016 07:24 PM |
| Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc | Chase Bays | Brakes, Suspension, Chassis | 14 | 02-03-2016 10:14 PM |
| kw v3 rear making clunking noise | eera | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-17-2015 05:10 PM |
| New rims and tires making a noise | Frs32907 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-21-2013 04:01 PM |
| Ballast Making Noise | remorse87 | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 10-24-2012 11:35 PM |
