| Engine Swaps Discussion of engine swaps. |
Drives: FRS Silver LS1 swapped.
Sway bar fix for header interferance.
Just wanted to post that my local shop (Texas Track Works) has made some relocation brackets for my Vorshlag kitted LS1 swap and can have them made for others if needed.....pictures to follow hopefully tomorrow.
#2 |
Drives: RAVEN
Find it interesting that Canbus turned out to be an easier nut to crack than swaybar install!
#3 | |
Drives: 2015 FRS - FFR GTM
Excellent!!! Will it use OEM bar??
2015 FR-S - One Day I'll Finish The Swap |
#4 |
Yes any bar that will fit OEM application will work, just different end links.
#5 |
Drives: 2015 Raven V8
#6 |
Drives: 2013 Ultramarine FR-S
Bump?
#7 |
Sway bar relocate bracket.
#8 |
Does the ground clearance change?
#10 |
Ground clearance un-effected, as you can see in the photo the OEM engine shield and the bracket well above it, a much beefier stiffer bracket I might add compared to the stamped steel unit,.........anybody needing this can contact Texas Track Works Fort Worth Texas......Mason or Forrest being the contacts, they assured me they will make this available for others wanting it.
#11 |
SPL Parts custom made ends links just showed up.
#12 |
Drives: 2017 WR BLUE BRZ
Looks great!
| WRX rear sway bar: good front sway bar combo? | LerpK | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 11-11-2016 06:02 PM |
| FS: Koni shocks, TRD sway bar & WRX sway bar | scirocco78 | Brakes, Suspension, Chassis | 14 | 08-31-2015 06:47 AM |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 01:20 PM |
| Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 12:38 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
