Old 10-21-2021, 08:10 PM   #1
ML
ML's Avatar
Drives: 13 White MT FR-S
Electric Power Steering with no CAN
Does anyone know if you our EPS motor will run in limp mode with only power and no CAN connection? Context is this is a aftermarket ECU and I'm building the chassis harness and would rather not run add the complexity of steering angle sensor, so just want to give the EPS motor/controller 12v and be done.
Old 10-22-2021, 02:15 PM   #2
pope
has a funny hat
Drives: 2014 BRZ Limited
I read in another thread (I don't remember which) that it does similar to the Prius, but I cannot confirm at the moment. Although, I did recently acquire the parts to experiment with, but haven't done so yet.
pope is offline   Reply With Quote
Old 10-22-2021, 02:22 PM   #3
ML
ML's Avatar
That is very much what I'm hoping and is my guess just based on visual similarities between ours and the Prius'.
Old 10-22-2021, 11:25 PM   #4
pope
has a funny hat
I found a fail safe chart in the service manual this evening. I highlighted the condition I believe it will operate in when missing the CAN data (speed) from the stability computer. We should have a continuous output roughly equivalent to highway speeds.
Old 10-23-2021, 08:06 AM   #5
ML
ML's Avatar
Wow you are awesome! Send me your PayPal and I’ll throw you some beer money!
Old 10-23-2021, 10:43 AM   #6
pope
has a funny hat
Not necessary. I was going through the manual looking for a wiring diagram and stumbled on the chart.
Old 03-10-2023, 06:14 AM   #7
Franklin.
Drives: 2013 Brz Limited
Were you able to find a remedy to this? I swapped in a 2JZ and want to run as much of the car as possible on the standalone ecu.
If there's a way to permanently limit the power steering without the body control & power steering modules id love to hear how if worked out in your case.
Franklin. is offline   Reply With Quote
Old 03-10-2023, 08:41 AM   #8
ML
ML's Avatar
yes, you just give the PS box 12v straight from the battery and ground with the 4ga wire, and then switched 12v to the box on pin 6 of connector a15 to switch it on. it will go on limp mode but I have found it to be perfectly adequate that way
Old 03-12-2023, 12:51 AM   #9
Franklin.
That makes sense.
Does the power steering box need the other modules in place to have the ability to go into limp mode?
I deleted ABS, and I'm not sure if the box needs inputs from the wheel speed sensors or if I can delete the system all together.
Old 03-12-2023, 12:51 PM   #10
ML
ML's Avatar
That makes sense.
no, I have mine in with an engine swap and a standalone ECU and no ABS and its fine.
Electric Power Steering (EPS) noisy RevoG Suspension | Chassis | Brakes -- Sponsored by 949 Racing 144 10-01-2023 03:25 PM
Electric power steering and steering column part info raspec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 10-12-2021 05:27 PM
Electric Power Steering oziel Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 01-24-2021 01:06 AM
Electric Power Steering ArtS Electronics | Audio | NAV | Infotainment 0 10-31-2016 08:19 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
