Old 04-03-2016, 10:27 PM   #1
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Coilover question for those running RCE Tarmac II's
I bought a set used a while back and have had no problems with it thus far, but I noticed something a little weird on the rear suspension. I'm running raceseng rear shock top hats in the rear if it makes any difference, but the springs are compressed all the way down at the top.I was just wondering if it's normal to be compressed like that.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 04-03-2016, 10:34 PM   #2
enjoi23
enjoi23's Avatar
Drives: FRS
Old 04-03-2016, 10:46 PM   #3
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Pretty sure that's normal and mine look like that too.
@Racecomp Engineering
infinity21 is offline   Reply With Quote
The Following User Says Thank You to infinity21 For This Useful Post:
enjoi23 (04-04-2016)
Old 04-03-2016, 10:48 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
That's the helper spring - if you were to lift the rear of the car you'd likely see that expand to take up the slack once there's no weight at all on the rear suspension and it's fully extended.
The Following 3 Users Say Thank You to cjd For This Useful Post:
enjoi23 (04-04-2016), gramicci101 (04-03-2016), Porcupint (04-04-2016)
Old 04-04-2016, 12:34 AM   #5
Porcupint
Drives: 13 GBS BRZ
Yep, like CJD said, that's the helper spring. It's supposed to be like that.
Porcupint is offline   Reply With Quote
The Following User Says Thank You to Porcupint For This Useful Post:
Old 04-04-2016, 12:38 AM   #6
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Totally normal, those are helper springs that can be compressed very easily, they help take up droop when the suspension unloads.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
Old 04-04-2016, 01:07 AM   #7
renfield90
The Stig's German cousin
Yup. Without the tender spring, if that corner became fully unloaded the main spring might not be seated properly when everything compressed back to normal.
The Following User Says Thank You to renfield90 For This Useful Post:
Old 04-04-2016, 01:23 PM   #8
enjoi23
enjoi23's Avatar
Drives: FRS
Awesome just checking. Better to be safe than sorry. Thanks guys!
Old 04-05-2016, 08:21 AM   #9
Normal.
Sorry just saw your PM, I'm out of the country.
- Andrew
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 04:43 PM
RaceComp Engineering Tarmac Coilover sale Racecomp Engineering Brakes, Suspension, Chassis 1 11-02-2015 11:08 AM
coilover question Sketchi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-27-2014 07:00 PM
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
