AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
"Official" Suspension/Brake Thread
So I have seen a ton of different info on the stock suspension/brake setup on the twins. I want to create a 1 stop shop for info on the stock BRZ/FRS suspension/brake setup. Also any companies that are working on upgrades please chime in! Hopefully if the mods feel its worthy it can become a sticky.
What I'd like to see: Stock shock manufacturer Stock spring manufacturer Stock spring rates BRZ Stock spring rates FR-S Stock brake caliper manufacturer Stock pad manufacturer I'll start: Can anyone 100% confirm or deny that the stock calipers/rotors/pads are 2011+ WRX or something different? A lot of magazines seem to think so. If I can order high bite WRX pads day 1 and they'll fit then it makes my life and everyone else who wants to upgrades life easier lol.
2013 BRZ Limited- GBS - 6MT -VIN #0937 ~~NYR SCCA # 18 C Street R (CSR)~~ "But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson |
#2 |
FIA Licensed Rally Driver
Drives: Lots...
Great idea for a thread… Wish I had something to contribute. Brake upgrade will certainly be early in my modding.
#3 |
Since we were lucky enough to have a preproduction car for a little we figured a few things out:
Stock shock manufacturer - Showa non inverted twin tube Stock spring rates BRZ - 185 lbs/in front and rear Motion ratio in the rear around 0.75 18mm front sway bar 14mm rear sway bar Fronts are 2011 WRX pads and rotors. Rears need confirmation (I think Legacy GT though). 6 inches total suspension stroke front (bump + droop). About 2.5 inch bump travel and 3.5 droop, but that bump travel includes the bumpstop. shock dyno for BRZ ![]() I have more info coming soon and more things to work on with the car but we are incredibly busy this week and I'm at home now. Will try to post some next weekend. - Andrew Last edited by Racecomp Engineering; 03-20-2014 at 04:51 PM. |
| The Following 13 Users Say Thank You to Racecomp Engineering For This Useful Post: | Bristecom (06-17-2012), civicdrivr (05-29-2012), coyote (05-29-2012), Dimman (05-29-2012), Fly Guy (05-29-2012), Lonewolf (05-29-2012), NYC BRZ (05-29-2012), Primo86 (05-30-2012), Ryephile (05-29-2012), Shankenstein (03-20-2014), Slartibartfast (06-09-2012), SonnyBRZ (05-29-2012), Symbiont (05-30-2012) |
#4 |
added rear motion ratio.
#5 |
Drives: Moped
Thanks for the helpful information Racecomp. Do you guys need a donor vehicle for R&D?
***Can anyone confirm if the rears pads are from the Legacy GT? |
#6 |
Drives: Slowly
#7 | |
![]() We'll try and confirm rear pad fitment but someone will likely beat us to it! - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Lonewolf (05-29-2012) |
#8 | |
Hot Dog
Drives: quicker than arghx7
![]() More total stroke than I was expecting, and that's a good thing.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
| The Following User Says Thank You to Ryephile For This Useful Post: | blu_ (06-04-2012) |
#9 |
AutoX Addict
I'm most excited about the fact that they're 2011+ WRX pads and rotors. I've been in touch with the boys at Carbotech. Now I need to get a set of AX6 pads.
Thanks RCE!
#10 | |
Drives: '05 Toyota Celica (Sold) Scion FR-S
Showa has some good engineering, and their products seem to be of good quality. Just from their website I have one or two questions regarding the suspension set up:
1. For clarity, since the suspensions are "tuned" differently on the BRZ/FR-S, do they use the same shocks/ struts but with different spring rates? 2. If they do, then Shows produces both cars' shocks/struts. Earlier Racecomp Engineering said, Quote:
Conventional ![]() Double-tubed construction filled wish low pressure nitrogen gas. This type of shock absorber is supple and provides stable riding comfort. Under "struts," the same option looks to be the correct counter-part. Conventional ![]() Double-tubed shock absorber with a function as part of the surpport structure of the suspension. Like the double wishbone type, it is a shock absorber filled with low-pressure nitrogen gas that is supple and provides stable riding comfort. My question is, are these the shocks/struts on the FR-S/BRZ? If not, what are on the FR-S? 3. Do they share the same brand of springs? even though the rates are different? If not, what brand spring is the FR-S, and what brand is the BRZ? thank you!
'05 Toyota Celica (sold)
Scion FR-S ((arriving shortly!! June 1st - 12th.)) Asphalt Grey, Manual Trans., Upgraded Audio, and TRD air filter. |
#11 |
^ Those are actual pictures of the Shows shocks/struts from their website...
#12 |
Kuruma Otaku
Does TEIN use stock spring rates for their H-Tech line?
The FR-S H-Tech springs are listed as 3.0kg/mm (167 lbs/in) Front and 4.6kg/mm (257 lbs/in) Rear. This would fit in with what we've been hearing about the different suspension settings, as well as identify why the FR-S is said to be a bit more tail-happy.
Because titanium. |
#13 | |
Drives: BRZ(sold), STI
I have 08 spec.b, rear brake are the same for all 05-09 LGTs. Here's a pic of some rear EBC Yellowstaff I had on my legacy at some point and stock rear BRZ pad. ![]() Pad size is a bit different, and the 'ears' on LGT pad are thicker, so it does not fit into BRZ bracket even with clips removed. |
#14 | |
Drives: Moped
| Limited gets brake "upgrade" over Premium - Canada only? | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 25 | 05-15-2012 01:35 AM |
| The Official "E-Peen" (BRAG) Thread | S2kphile | Off-Topic Lounge [WARNING: NO POLITICS] | 46 | 03-31-2012 10:49 PM |
| New Official WRB Subaru BRZ Video from Geneva "Lift" | gt86mods | BRZ Photos, Videos, Wallpapers, Gallery Forum | 13 | 03-06-2012 11:25 PM |
| The *Official* "I'm Back!" thread | BoostJunkie | Off-Topic Lounge [WARNING: NO POLITICS] | 34 | 02-02-2012 08:21 AM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 08:59 PM |
