Old 06-07-2018, 11:43 PM   #1
stlgrym3
17” wheels too small for FI’d twins?
I’m posting this in the FI forum instead of wheels and tires forum because I need feedbacks from FI owners. Are 17” wheel setup too small to handle the added power and torque of the FI’d twins?
stlgrym3 is offline   Reply With Quote
Old 06-07-2018, 11:44 PM   #2
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
No, not really.
It’s all in the tire
________
~refer to username~
idkwhatimdoing is offline   Reply With Quote
Old 06-08-2018, 12:10 AM   #3
fer3d
Drives: Toyota 86 FT
I don't think so.
I'm doing ok with 300whp and 255/40 R compounds on 17x9 wheels
Enviado desde mi Nexus 5X mediante Tapatalk
fer3d is offline   Reply With Quote
Old 06-08-2018, 01:04 AM   #4
CSG Mike
CSG Mike's Avatar
Your right foot determines if that is too small or not.
Old 06-08-2018, 01:51 AM   #5
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
17's are fine. I prefer 17's to 18's.
Tyres are normally cheaper too.
Fish Eagle is offline   Reply With Quote
Old 06-08-2018, 11:14 AM   #6
toast
Drives: 14 BSP Edelbrock BRZ
What does the diameter of the wheel have to do with power? You're worried about rippling the sidewalls of 17" tires when you launch?
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
CSG Mike (06-08-2018)
Old 06-08-2018, 11:18 AM   #7
Icecreamtruk
Drives: Track preped NA FRS
Formula one cars are running 13", just saying...
Icecreamtruk is offline   Reply With Quote
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
CSG Mike (06-08-2018), strat61caster (06-08-2018), toast (06-08-2018)
Old 06-08-2018, 12:15 PM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
^ that
Really OP 17's are too BIG, you need to go smaller to really lay down the power, goodyear doesn't make slicks for wheels bigger than 17.
ineedyourdiddly
Old 06-08-2018, 12:20 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I run 18s because I like the look.
Old 06-08-2018, 12:51 PM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You should use the smallest wheel that fits your brake calipers. Period.
The Following 2 Users Say Thank You to nikitopo For This Useful Post:
JoeC (06-08-2018), Yoshoobaroo (06-08-2018)
Old 06-08-2018, 02:01 PM   #11
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I feel width would be more important than diameter, wouldn't it?
MS, CSCS, TSAC-F, CPT
Old 06-08-2018, 02:01 PM   #12
wbradley
Sarcastic SOB
wbradley's Avatar
I never thought there was any correlation between big wheels high horse power. The trend of using 19" or bigger wheels on sports cars is just that. After all, bigger is better, right?
In reality, the weight and strength of the wheel and using a diameter that allows for the optimal tire profile is probably what matters functionally.
Super low profile tires necessary on supersized wheels makes it harder to get traction with hard acceleration. Plus the unsprung weight increasing only hampers the responsiveness of suspension and steering. My STI has stock 19" wheels and for sure I'd never buy that size aftermarket. I like 17" wider wheels on the twins.
The Following User Says Thank You to wbradley For This Useful Post:
new2subaru (06-08-2018)
Old 06-08-2018, 06:24 PM   #13
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Exactly. The question makes no sense at all.
bmxr is offline   Reply With Quote
Old 06-08-2018, 09:09 PM   #14
15limited
15limited's Avatar
Even more than that, tire compound
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Anyone interested in a small run of custom wheels? aznatama Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 09-11-2014 07:06 PM
Panda 86 Thread: White Twins on Black wheels fooddude Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-17-2014 06:44 PM
Stock brakes too small for stock wheels ndsleep612 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 04-11-2014 10:24 PM
Pic Request: Silver twins with bronze wheels euroshowoff Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-23-2013 07:25 PM
What the best way to fix a small rip in my set? speedy racer Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2013 07:08 PM
