Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
22GR/BRZ Oil Temps
Hey,
Just wondering what's the range of oil temps people are seeing? Normal street driving temps are 195-210 depending on load. When I was at the track I was experiencing temps as high as 235, maybe 240. 87 degrees ambient out. Oil temp would quickly dropped once I reduced load. This a normal range? |
#2 |
Normal. You hit 260, it's time to think about a remote oil cooler.
| The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post: | autosenses (07-17-2022), jcw99 (08-07-2022) |
#3 |
Drives: Subaru BRZ
The highest I have seen so far at Road Atlanta is the very end of 2 in 270.
Rough calculation: 1 square = (340 - 120) / 74 = 2.97 degrees. I am 47 squares in so 120 + 47*2.97 = 260 degrees. Running Motul 300V 5w30 and will be switching to 5w40 in the future. |
| The Following User Says Thank You to Code Monkey For This Useful Post: | autosenses (07-17-2022) |
#4 |
Drives: 2022 BRZ
235 wouldn’t be any concern. I’m debating a oil cooler for sure though.
At Sebring in 98* ambient, I hit 268 in 3 laps. Firm in 95* ambient I hit 253 in 7 laps. |
#5 |
Thanks for the input.
There's no way to get ambient intake temp readings right? |
#6 | |
Wheels for Brains
Or you can look at your ambient temperature readout on the dash (or your weather report) |
| The Following User Says Thank You to EndlessAzure For This Useful Post: | jcw99 (08-07-2022) |
#7 | |
#8 |
Drives: 22 BRZ limited
#9 | |
CSG has Color Fittings, Jackson Racing, and GReddy available. |
#10 |
#11 |
Drives: '23 BRZ
FWIW I always see temps of 270F-275F at the track with my '17, regardless of ambient temps. No oil cooler and not planning on one for my usage, which is 95% street with ~10-12 track days per year (consisting of 3-4x ~15-minute sessions per day). I run 5w30 synthetic. Currently at 70k miles and 48 track days.
Oil in the car now still looks remarkably "fresh" after ~2500 miles and 6 track days on this fill. Also, this is the first car I've ever dailied or tracked that seems to use NO oil whatsoever between changes. Even with the 6 track days thrown in it's still a bit above the "full" mark as it was when I checked it just after last oil change. Kind of amazing... |
| The Following 3 Users Say Thank You to ZDan For This Useful Post: |
#12 | |
How often did you change the first couple oils? |
#13 |
Drives: '23 BRZ
Changed factory fill out after ~5k miles with 5w30 for track season. Changed after two track events (4 days with ~4x15min stints/day) + ~3500 street miles. Changed oil ~ every 5k miles or every 2 or sometimes 3 track events since then, switching back to 0w20 for winter months.
| The Following User Says Thank You to ZDan For This Useful Post: | Teseo (07-26-2022) |
#14 |
Drives: frs
I thought with new models having integrated oil cooler (Forester OEM like) Temps should be more lower
| Oil temps | gen3v8 | Engine, Exhaust, Transmission | 10 | 02-11-2021 07:54 PM |
| LED H11 Headlights in 3 Temps for $42 | stevesnj | Cosmetic Modification (Interior/Exterior/Lighting) | 37 | 10-19-2015 01:03 PM |
| N/A typical oil temps | JB86'd | Engine, Exhaust, Transmission | 13 | 12-16-2014 01:42 AM |
| Oil temps with JR SC and JR oil cooler | dp1 | Tracking / Autocross / HPDE / Drifting | 87 | 11-14-2014 01:35 AM |
| Oil Temps | Fish Eagle | AFRICA | 13 | 07-22-2014 06:53 PM |
