05-30-2018, 06:39 PM | #1 |
Rust bucket enthusiast
FR-S Turbo Build
Current Build Information
Engine IAG Stage 1 w/ 10.5:1 Compression ratio. Using stock heads with Kelford 68lb springs, ARP2000 headstuds and stock headgasket. Stock coilpacks and stock sparkplugs Boostlab BL58x w/ T51r Mod ( Basically a GTX3076r Gen2). Tial vband hotside. Protected by a PTP turbo blanket Cam driven oil scavenging for turbo oil drain, uses WRX oil scavenge pump w/ AVO bracket JDL Equal length turbo manifold and downpipe, all Vband. Turbosmart 38mm Ultragate wastegate recirculates into downpipe JDL Catted and resonated 3" front pipe/overpipe combo FT86speedfactory x Remark 3" catback w/ quad tip Garrett bar and plate core intercooler w/ Treadstone piping and Turbosmart raceport BOV. Mishimoto slim fan shroud w/ fans CSR coolant connector w/ Mishimoto coolant hoses. Radium passenger side catch can, venting crankcase side to atmosphere w/ filter ID1050x injectors Walbro 450LPH fuel pump w/ custom return style fuel circuit Radium fuel rails JDM OEM AC delete Verus DI ECU bracket and driver's side injector cover Tuning Tuned by VEMS using Ecutek w/ Racerom Currently running about 26PSI, 93 octane. About 500WHP Using a 3 port MAC solenoid for boost control through Ecutek Drivetrain Stock transmission Stock axles STI transmission mount STI engine mounts Southbend Stage 3 Daily clutch Verus carbon fiber driveshaft Upgraded shifter detent springs (best mod) Removed clutch assist spring (DO THIS) TRD brake pads Centric blank rotors Interior Atoto A6 pro head unit (link here - https://www.amazon.com/ATOTO-Navigat.../dp/B075W9H5P3) Tomei delrin shift knob Suede wrapped center console VEMS wideband gauge Prosport boost gauge Defi racer oil pressure gauge JDM black panels anywhere that silver was in US trim 3DMaxpider floor mats (unexpectedly great) Exterior HKS IVGT coilovers Whiteline front endlinks ARC-8 wheels in 17x9+42 Nitto NT555R drag radials 245/45R17 Muteki SR48 Neochrome lug nuts Verus slanted hood vents TrueFocusFab front bash bar Custom blacked out stock FRS headlights w/ 100mm halos Toyota badges front and rear, removed all other lettering on the trunk eBay black sidemarkers superglued in place Last edited by DarkPira7e; 09-17-2023 at 07:03 PM. |
05-30-2018, 06:40 PM | #2 |
I typed all of this on my phone, please forgive typos, it's too hot right now to proofread.
Against my better judgment, I'm going FI on my only car, daily driver (even through Vermont winters) FR-S. I love so many things about this car. I love the seating position, I love rwd, I love the look, the steering feel, the stock ride quality and handling. Honestly though, I don't spend much time "carving canyons" or doing track days (go ahead, try to find a track in Vermont. Try it.) While the handling of the car is wonderful and I do push it sometimes, the car leaves me wanting a bit more in acceleration. I don't want my tires cording at each chance, I don't want Teslas to fear me in a 1/4. I don't want to BUILD my motor if I can avoid it. Hell, I don't even have a whp goal, I don't have a benchmark I want to reach. Why? I'll let the car respond how it will and enjoy it as such. I plan to run 8-10psi on whatever turbo lasts on the cxracing manifold. It will be dyno tuned, it will have an oil cooler. It will be tuned to build boost higher in the revs, no low rpm nonsense here. It was have a pcv side catch can (already does) and crack case VTA. That's it. Here is what I'm thinking: Oil pressure builds by RPM. lower RPM torque means the rods are handling higher forces for longer, and preventing rod failure is one of my paramount concerns with every choice I'm making here (as it is with anyone who doesn't want to build a bomb). My turbo I've ordered is the generic journal bearing T3 T04E 60/63 cxracing makes. What I've found in my research, is that these are the best turbos they make for reliability. "Best" is subjective, so keep reading and hear me out. Search "cxracing turbo" and no doubt, you'll get horror before praise. This is true of anything. ANYTHING. People are more apt to complain when something goes wrong, than to take time leaving a positive review when they could be out enjoying their product. This is a fact. I'm not going to dispute that the negative connotation associated with CXracing has not been earned; to a degree, it is low tier quality. However, when your goals are not in the clouds, the quality disparity is nothing like you may think with some parts. Let's talk intercoolers. What is an intercooler? It's a heatsink, essentially. It holds an air charge the turbo forces into your intake and attempts to cool it as much as possible before it reaches the intake. Other than that purpose, it's ONLY JOB is holding the air. To me, quality may be the finish of the piping, it's choice of a BOV flange location, the fitment, blah blah. If you go for BEST OF THE Best and need that, you'll be concerned with pressure drop, with the effectiveness of the intercooler core, the diameter piping. This is where I plant my feet and get ready to meet criticism. The route CXRACING takes for their piping isn't the longest, but it's pretty long compared to other kits. The BOV flange is on a bend, which sucks. The fitment hopefully is good, and I'm assuming it won't leak. My goal is not whp driven, so pressure drop, and cooling effectiveness is really not going to concern me. So long as it cools the charge air, I'm happy. The manifold. Equal length to me is a nice plus. The welds look decent, collector is OK, it has an EWG flange, and I can have the flanges milled flat if they're not great. I don't care about MAX POWER, I just need them to support the turbo and not leak, seems simple enough. Word vomit is a skill of mine, if you're still reading you probably should look busy so your boss doesn't catch on. Anyways, enough hard ass. I still want the car to be fun so it's not like I'll let it run like garbage or only make 210whp either. Let's get onto the other goodies! Going to run a PTP Turbo blanket and either use header wrap, or get the manifold ceramic coated. Under hood circulation is terrible and I am not interested in venting my hood right now (rain/snow, I don't want the header wrap getting saturated) so minimizing radiant heat will be important. I think I'll be getting a standard mishimoto oil cooler with a thermostatic adapter, and a stock radiator. Reflective gold tape/sleeving on anything close to the manifold and turbo should also minimize hazard. I still have far from everything and will likely be stagnant for a little while as new parts roll in. As of today, I have the following: Cxracing downpipe/manifold Cxracing intercooler Grimmspeed header gaskets Prosport boost/oil temp gauge OMNI 3bar map sensor Radium Engineering PCV catch can Brzedit for tuning Tomorrow the turbo and oil lines show up! Aside the collector being a bit grungy, things look great! It's nice that the intercooler piping is flared too. I'll update with more as time goes on! Let me know your thoughts/advice, I welcome all cisms and won't bite your head off if I disagree. Just be aware that bashing the kit in all likelihood won't elicit a response from me at all. Before I forget, I'm buying a new stock oil pan to weld a return into, and I'll get a clutch. Probably ACT with LWFW because chatter doesn't bother me, and I've had success with ACT on other platforms. Here we go Car currently is catless with stock catback, dynapack calls it 174whp 140wtq. UEL CNT headers, Megan racing frontpipe, stock overpipe. Last edited by DarkPira7e; 09-19-2022 at 11:38 AM. |
06-01-2018, 01:53 PM | #3 |
Turbo showed up, I got a new Turbosmart ultra gate 38mm from a specialty tuning and dyno shop called VEMS that is localled owned/operated very close to me. They put out amazing work, and I'm trusting them with my build. They had the wastegate in stock so I bought it.
I brought some of the kit there to have their opinion on it. Received a passing grade (not flying colors by any means) so there may be a couple additional things I'll need to budget for to make it right. The gasket for the downpipe is just expansive foil with only the exhaust port, the wastegate port is covered by the same gasket and may be a weakness in the design. See what I mean about the wastegate hole? We'll see what can been done to be sure it's sealed. Prosport oil temp and boost gauges are here too! |
06-01-2018, 03:07 PM | #4 |
Had a 3 gauge single DIN bracket made, this isn't the final product (60% fill) but it's really weak and doesn't fit quite like I thought. Being the incredibly malleable and accepting human being that I am, I still think it looks great! The fit is actually better since I can squish it a little and it's held tight by the poor fitment. Radio isn't wired in, so no powered on shots. I'm very much a fan of visibility, and did not want to be conventional with $100+ steering wheel column mounts, so I'm trying this! |
06-04-2018, 03:18 PM | #5 | |
Drives: 2014 BRZ
06-05-2018, 10:16 AM | #6 | |
I've actually revised this setup again and mounted the radio in the cubby where the usb/aux ports were, along with the little space. Fits really nicely, now I have a double din hole to mount gauges in. Still working on figuring that out so I'm going to post pictures once I'm done planning, should be pretty good. |
06-14-2018, 03:54 PM | #7 |
Small update! A lot more parts are in. I ended up buying a dual gauge pod, only want two gauges: boost and oil temp. I wrapped the intake pipe with dei reflective tape and bought silicon spray for the header wrap! Oil cooler just got here, I think I have about everything I need to get the installation process moving forward. Eventually a new clutch will come in with a couple other little goodies too!! Oh, and I have a new oem oil pan. Buying an oem serpentine belt because I may as well.
Imgur isn't working so I'll update later with images! |
04-27-2019, 08:10 PM | #8 |
Long overdue update. I've changed to ECUTEK with the RaceRom patch for tuning. Since my car has been blown up multiple times due to the valve recall, I finally have it back and am ready to proceed. I settled on my gauge design too. Moved the radio to the bottom. Also bought an oil cooler, heatwrapped and sprayed everything with DEI silicon spray. I had to remove my windshield washer fluid res, and trim the tab on both headlights to fit the intercooler piping at all. I also bought $20 vented fog light housings and ditched my LED strips.
Not impressed with fitment on this intercooler at all. I had to trim the ear off of the right side so that a pipe wasn't againt it. Not sure if I just really am bad at lining up the pipes , but it's still going to need work to fit when everything goes in. Last edited by DarkPira7e; 04-28-2019 at 10:45 AM. Reason: Added photo |
05-05-2019, 02:08 PM | #9 |
Drives: 2013 frs- pearl sattin white
Hey I’m looking into getting the cx kit, did you have any more pics of the ic piping and hour you routed it, and how you mounted the intercooler. Just hoping to get a rough game plan for how to tackle the install.
05-05-2019, 02:37 PM | #10 |
Thanks
Have you been to Palmer Motorsports Park? I liked that track even though i got black flagged. It wasn't completed and they said i kicked up a piece of gravel even though i never dropped a wheel. That was couple years ago it must be completed by now.
I don't envy you driving a turbo twin on those rock and ice covered VT roads. Good luck.
05-05-2019, 03:12 PM | #11 | ||
11-04-2019, 07:31 PM | #12 |
Drives: Bone stock
Any updates?
Sent from my SM-N960U using Tapatalk |
11-24-2019, 07:35 PM | #13 |
Drives: Argento FR-S
Love this build!
Sent from my SM-G892A using Tapatalk |
11-24-2019, 07:38 PM | #14 |
Drives: Bone stock
Same. Need updates. He did post in the FI section but still...
Tags |
brz, frs, iag, jdl, turbo |
Similar Threads | ||||
Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 05:59 PM |
Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 07:57 AM |
Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-25-2015 11:02 PM |
My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 09:29 PM |
Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 08:44 AM |
