Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-28-2020, 04:49 PM | #1 |
Drives: 2K19 GT86
STFT/LTFT
So, today I threw on the OFT(v2) Stage2+ tune, (I have a catless header). After the tune, I let it run for about 10 min, then easy/normal driving for 20 miles (city and highway). It runs a lot better now an feels stronger. My question is re: the STFT and LTFT numbers at idle as I plan to go e85 after this tank runs out...
12-28-2020, 05:08 PM | #2 |
Drives: 17 Asphalt 86
For anybody who doesn't check new thread activity you'll want to use the software tuning Subforum 👍
https://www.ft86club.com/forums/forumdisplay.php?f=88 Video here to explain it. Looking for STFT to go up once E85 is in the lines. |
The Following User Says Thank You to RToyo86 For This Useful Post: | czellers (12-28-2020) |
12-28-2020, 05:12 PM | #3 |
Drives: Crapcan
You need to run more miles before starting to be concerned with making changes the ECU does a bit of learning. My big concern right away is your IAM is low. I would read the sticky's in the tuning subforum. You need to log injection mode and coolant temp as well.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | czellers (12-28-2020), DarkPira7e (12-28-2020) |
12-28-2020, 05:21 PM | #4 | |
Rust bucket enthusiast
Also (unrelated)- Domino's employee?
The Following User Says Thank You to DarkPira7e For This Useful Post: | czellers (12-28-2020) |
12-28-2020, 05:27 PM | #5 |
Drives: 2K19 GT86
12-28-2020, 05:34 PM | #6 |
Drives: Crapcan
"Ignition Advanced Multiplier" seen as "Adv. Multiplier" on your screen.
Say you have 10 degrees of advance at XXXXRPM. If you IAM is .76 it takes that 10 degrees and multiplies it by .76, so you are only getting 7.6 degrees. Ideally it should be at 1.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | czellers (12-28-2020) |
12-28-2020, 05:54 PM | #7 |
Drives: 2K19 GT86
Hmm trying to work the math, as this picture is at 699 RPM (IDLE)
12-28-2020, 05:55 PM | #8 |
Drives: 2K19 GT86
12-28-2020, 06:06 PM | #9 |
30 minute maintenance
Drives: My18 wrxsti My19 brzts
Idle is not in the equation. It`s Ignition adv. Times Adv. Multiplier, so 8.0 x 0.76
Wait until my Flex capacitor hits 88
12-28-2020, 06:07 PM | #10 |
Drives: 2K19 GT86
Interestingly enough, in the video that was added to this thread, its in line with mine (while on premium gas as mine is also still on premium gas) with idle around 700 and the IAM bouncing between 6 and 8
12-28-2020, 06:07 PM | #11 |
The blue shirt and black pants... I did delivery a while ago for them. The FRS is perfect if you take out the passenger seat
12-28-2020, 06:12 PM | #12 |
Drives: 2K19 GT86
12-28-2020, 06:13 PM | #13 |
Drives: 2K19 GT86
12-28-2020, 06:15 PM | #14 |
Drives: FT86
OFT V4 tunes have IAM initial set to 0.7 so each startup iam reverts to 0.7 max, if fuel is good generally 93 then iam will get to 1 after 10 minutes or so of driving, if your on 91 or in canada it likely wont get to 1 due fuel quality.
the ltft is high positive are you on 10% ethanol fuel ?? or you might have minor exhaust leak or non standard intake ? does the ltft get lower once your at say 2000 or so rpm ?? Last edited by steve99; 12-29-2020 at 04:13 AM. |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | DarkPira7e (12-28-2020), NoHaveMSG (12-28-2020) |
Similar Threads | ||||
Help with LTFT & STFT Stage 2 E85 OFT | juniorrr | Software Tuning | 8 | 08-29-2021 09:53 PM |
High negative STFT and LTFT | 86TOYO2k17 | Issues | Warranty | Recalls / TSB | 21 | 01-07-2021 06:06 PM |
E85 normal LTFT and STFT | Yitzb | BRZ First-Gen (2012+) -- General Topics | 6 | 05-19-2020 06:11 AM |
STFT and LTFT trims are negitive | Coop | Engine, Exhaust, Transmission | 1 | 09-10-2018 03:26 PM |
Is it normal for STFT and LTFT to always be 5% above? | pcguru2000 | Issues | Warranty | Recalls / TSB | 3 | 04-13-2018 08:36 PM |
