Old 10-21-2015, 05:27 AM   #1
ravisraval
Drives: 2013 FRS
Vibration on hard right turns
Not sure what the deal is. I just got all 4 wheels balanced, and I still have a rhythmic vibration that I feel through the steering wheel. Thoughts?
ravisraval is offline   Reply With Quote
Old 10-21-2015, 09:43 AM   #2
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
check to be sure the wheels are properly mounted.
Kuri is offline   Reply With Quote
Old 10-21-2015, 11:07 AM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Do you feel the vibration when going straight or only on hard right turns? are you braking in the turn or off the brakes? Doesn't sound like wheel balancing or mounting to me if you don't feel any vibration except in that particular circumstance. stock wheels and suspension? recent alignment or work done?
shiumai is offline   Reply With Quote
Old 10-21-2015, 11:51 AM   #4
stugray
Drives: 2013 GBS BRZ Limited
Is your car lowered, or do you have overly wide tires/wheels?
Old 10-21-2015, 03:14 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
as the responses have suggested, you need to be more specific in order for internet armchair mechanics to be able to diagnose.
Kuri (10-21-2015)
Old 10-21-2015, 03:24 PM   #6
totopo
Drives: 370z
how many miles do you have? check your wheel bearings.
totopo is offline   Reply With Quote
Old 10-21-2015, 03:28 PM   #7
JS + BRZ
Drives: 2010 MS3
turn harder?
Old 10-21-2015, 03:41 PM   #8
ravisraval
Drives: 2013 FRS
Kw v3, rpf1 17x9 245/40 mpss.
Car has just under 80k miles.
Only feel the vibration under hard rights, not when going straight or left . No braking midcorner.
Come to think of it, my mechanic (neal@theracersline) did mention my front passenger wheel bearing was in so so condition.
The Following User Says Thank You to ravisraval For This Useful Post:
Kuri (10-21-2015)
Old 10-21-2015, 03:50 PM   #9
Kuri
Kuri's Avatar
That would do it^
#TrackDayBro
Old 10-21-2015, 04:34 PM   #10
ravisraval
Drives: 2013 FRS
Is a wheel bearing something the dealer would replace under warranty, or is it considered a wear item? I have the extended warranty until 125k miles.
Old 10-21-2015, 04:36 PM   #11
mav1178
mav1178's Avatar
Your mods will make any warranty claim on wheel bearings sketchy at best. A wheel hub is not that expensive to buy, especially front.
-alex
Ultramaroon (10-21-2015)
Old 10-21-2015, 04:44 PM   #12
Originally Posted by Kuri View Post
That would do it^
I don't think that's it because the passenger side is unloaded in a right turn. Check for bent wheel or belts slipped in tire. The latter is especially hazardous.
edit: actually, yeah, maybe if the bearing was downright floppy. That's not so-so, more like dangerously failed.
Old 10-21-2015, 04:48 PM   #13
totopo
Drives: 370z
how long is the powertrain covered? Ehh, might as well try a dealer. If it's a subaru USA warranty they get paid pretty well, so may be willing to do it.
Old 10-21-2015, 05:08 PM   #14
mav1178
mav1178's Avatar
This is not a powertrain issue. Powertrain would be everything up to the axles, wheel bearings are under bumper-to-bumper warranty.
-alex
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 02:53 PM
AC HVAC turns on randomly DarkestBuddha Electronics | Audio | NAV | Infotainment 0 06-28-2014 09:53 PM
Charging Phone Turns On Air-Bag onepremiere Issues | Warranty | Recalls / TSB 19 09-27-2013 03:23 AM
Switching the Turns and the DRLs, possible, or just too dang hard? VesperLynn BRZ First-Gen (2012+) — General Topics 3 08-18-2013 10:38 AM
Bluetooth turns on in driveway Pete156 Electronics | Audio | NAV | Infotainment 2 08-05-2013 01:12 AM
