Drives: 2014 FRS MT
Turn signal lights
Swapped my front turn signals over to switchback leds and changed to a led specific flasher as well.
Never noticed if it did this as stock, but now when my headlights are on and my turn signals are on as white they will turn off if I hit the brakes. Did the stock bulbs do this? How can I stop this from happening? |
#2 |
Sarcastic SOB
Switchback 7440 are for front only. Rear is non switchback just in case thats the issue.
#3 |
Drives: 2014 FRS MT
Nah these are my front turn signals
#4 |
I can say with certainty that the stock front blinkers don't turn off when hitting the brakes.
#5 |
Drives: 2014 FRS MT
Any idea what could be causing my issue?
#6 |
A Demon
Drives: Raven GT86
This sounds super odd.
Where'd you get the switchbacks and have you tested it with your stock bulbs? |
#7 | |
Custom User Title
Drives: Asphalt FR-S MT
Rear is 7440 Just correcting some misinfo.... This sounds weird. What switchbacks did you get?
#8 |
Drives: 2014 FRS MT
I got the switchbacks from amazon, they're the JDM ASTAR ones.
I have not tested with my stock bulbs yet, I've been at work all day. I'll switch things back to stock tomorrow and see what happens. I wanted to put the question out there to see if anyone had any similar issues. |
#9 | |
A Demon
Drives: Raven GT86
I haven't seen anything similar on the forum. I'd say try that if you still have the same issues check wiring coming off the bulb and ground on battery, also check fuses. None of these should cause this issue but you never know. If the issue still persist and there's no wiring/fuse damage take the car into your dealer to see what's going on. If the issue stops when you switch bulbs pickup a new set. 👍 Good luck. |
#10 |
Drives: 2014 FRS MT
Just an update, I swapped back to my factory bulbs and the problem was corrected. I've contacted the manufacturer about a new set of led bulbs. Still not sure what would cause that particular malfunction.
#11 |
The front turn signal LEDs should never stop working when the brakes are engaged. It may be an issue with the LEDs. Our customers are running our A-tech Switchback LEDs for front turn signals and they have been very happy with them
Hopefully your new set of LEDs will resolve the issue you have experienced. |
#12 | |
Drives: Scion FR-S
| The Following User Says Thank You to Alexgalarreta For This Useful Post: | KI_ZN6 (12-08-2014) |
#13 |
It's voltage leakage caused by the LEDs you installed. If you install a different LED bulb you won't have that issue
Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | thatfilipinoguy (12-08-2014) |
#14 |
Drives: 2014 FRS MT
Just to resolve this issue, I ended up getting new bulbs from diode dynamics and they function perfectly..
| The Following User Says Thank You to whip For This Useful Post: | Jmonty (02-26-2015) |
| DIY: Turn signal parking lights always off at night | chicagokid | DIY (Do-It-Yourself) Guides | 3 | 09-09-2014 05:56 AM |
| Is there another way to keep the turn signal lights on? | DeadStar7 | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 06-29-2014 10:43 PM |
| valenti lights turn signal problem | jay_ | Issues | Warranty | Recalls / TSB | 2 | 06-03-2014 10:43 AM |
| WTB FR-S Turn Signal Lights | retrosmiths | Want-To-Buy Requests | 2 | 01-08-2014 02:13 PM |
| Turn signal lights | Brzer | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-18-2012 01:36 PM |
