Old 03-15-2016, 05:57 PM   #1
Taydork
Drives: 2015 Scion FRS Custom 4 stage pearl
enkei rs05rr 18x9.5 +43 squared
heres my setup. first set of 9.5 squared in Hawaii mounted on an 86 twin.
toyo proxes T1 235/40 F/ 255/40 R
sitting on megan street series coilovers
Taydork is offline   Reply With Quote
Old 03-15-2016, 06:04 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
any rubbing up front with the +43 offset? also with a squared wheel setup why did you go staggered tires?
Instagram: trevor.parque
Old 03-15-2016, 06:16 PM   #3
kch
Senior Misanthrope
kch's Avatar
you can go up to a 265/35/18 without rubbing on these, usually.
edit: assuming you're on coils.
Old 03-15-2016, 06:16 PM   #4
MisterSheep
Killed Scion
Just need coilovers to have the wheels clear?
Old 03-15-2016, 06:30 PM   #5
kch
Senior Misanthrope
kch's Avatar
yep. http://www.ft86club.com/forums/showthread.php?t=48897
Old 03-17-2016, 12:00 AM   #6
Taydork
Just to clear everything once I slam. Clearance to coil is also VERY close. 1 finger gap
Old 03-17-2016, 12:13 PM   #7
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
That sounds pretty roomy to me!
Unless you have tiny fingers?
JazzleSAURUS is offline   Reply With Quote
Old 03-17-2016, 02:47 PM   #8
Taydork
its a tight fitment. but im gonna end up spacing it a bit in the future. the +43 is both a helper and hinderer.
Old 03-17-2016, 10:38 PM   #9
Bykov
Drives: 2014 Monogram FR-S Whiteout
Lots of poke in the front for my taste but it looks great with the stretched tire and I am sure it will be alleviated by your plans to slam it. I love these wheels to death too.
Bykov is offline   Reply With Quote
Old 03-18-2016, 09:34 AM   #10
Timmy_Jones
Spun
Drives: 17' Focus RS
Front tires seem a bit stretched and poke out of the wheel well a bit. I think if the car were lower, overall it would look better. Only other thing, would be to get a clear side-marker, ditch that amber one.
Otherwise its clean and subtle, I really like the overall look.
Timmy_Jones is offline   Reply With Quote
Old 04-11-2016, 10:37 PM   #11
Taydork
Pokes actually not that bad after I lowered another 1/2 inch. It's pretty flushed out
Old 04-11-2016, 10:38 PM   #12
Taydork
Cars gonna be getting an entire exterior change so all the amber/silver pieces changing
The Following User Says Thank You to Taydork For This Useful Post:
Timmy_Jones (04-12-2016)
Old 04-12-2016, 12:00 AM   #13
Ginosaur
Drives: 2015 Toyota 86 GTS Manual
That's so nice bro! I'm planning to buy the XXR 550 version because brokelife haha
Ginosaur is offline   Reply With Quote
Old 04-27-2016, 09:21 PM   #14
Taydork
dont buy xxr's.. if anything buy the ambit ones. theyre +38 offset too so a little more clearance to strut/spring
Enkei rs05rr 18x9.5 +43 cjm86 Wheels and Tires 32 04-27-2020 06:23 PM
Wheel Directory: Enkei RS05RR 18x9.5 +43 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 09-22-2019 11:39 PM
Fs: Enkei RS05rr 18x9.5 +43 wheels only protpibe Canada Classifieds 14 12-28-2015 11:45 PM
Enkei RS05RR 18x8.5+42 / 18x9.5+43 Futaba Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 08-14-2015 01:02 PM
18x9.5 enkei rs05rr with rs3's spitfire481 Wheels and Tires 20 02-06-2015 11:43 AM
