Old 10-04-2013, 03:23 PM   #1
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
Slicks upgraded axles 1/4 mile?
Bought some wheel adapters and some real big boy drag radials. Also upgraded axles. Its time to break into the 11's with this 470@wheels. If i don't then I need a driver mod. I will be making a video with the gopro and having someone record. Next sat is the big event. Guess i'll be the first to test some mickey thompsons Et street radials and see what breaks. Hope clutch holds.
http://www.ft86club.com/forums/showthread.php?t=31807
Fabron757 is offline   Reply With Quote
Old 10-04-2013, 04:22 PM   #2
jamesm
which clutch are you using?
Old 10-04-2013, 04:27 PM   #3
Fabron757
FX400
Old 10-04-2013, 04:27 PM   #4
MrSlay
Drives: Gx 460, FRS, Prius
You shouldn't need slicks, but there definitely going to make a real difference.
Best of luck!!
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
Old 10-04-2013, 04:33 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
Clutchmasters fx400 6 puck
Old 10-04-2013, 04:52 PM   #6
Ross
Drives: 85 corolla gts
Yeah it is a 6 puck. It is a bit grabby you could say with light chatter at idle with the ac on. pedal effort is not bad at all and engagement is not that bad to get used to.
Ross is offline   Reply With Quote
Old 10-04-2013, 04:56 PM   #7
STV3
Señor Member
STV3's Avatar
Clutch should hold, but then again I've had problems with both clutch masters clutches I had in my other car. But good luck! go run 11s!
STV3 is offline   Reply With Quote
Old 10-04-2013, 07:34 PM   #8
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Lets see pics of the wheel setup?
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 10-04-2013, 08:17 PM   #9
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Best of luck!!
Nothing going to put the power to the road other than slicks on this light chassis
Old 10-05-2013, 03:08 AM   #10
MrSlay
I think a solid DR and good clutch modulation is going to do the trick. I hooked over 650wtq in my isf utilizing the same NTO5R that I'm going to be using on my FRS.
Ill be on boost next month so I guess well see how my theory works.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
Old 10-05-2013, 03:15 AM   #11
SmsAlSuwaidi
Boosted
Remember the ISF is way heavier and is longer.
Old 10-05-2013, 11:12 AM   #12
Diggitydog89
Drives: 2005 Chrysler Crossfire
What are you currently running now @470?
Diggitydog89 is offline   Reply With Quote
Old 10-06-2013, 06:54 AM   #13
SUB-ZERO
Drives: GT86/GTR R35
I am getting the driveshaft shop - axle and drive shaft alminmum
and ats clutch and lsd
SUB-ZERO is offline   Reply With Quote
Old 06-29-2014, 07:25 PM   #14
Dipstik-sportech
Dipstik-sportech's Avatar
Did u ever get this thing down the track?
Low car + replacement axles + raising diff advice JordanWho Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 04-05-2019 09:47 PM
should i upgrade axles? Frs300 Engine, Exhaust, Transmission 16 07-02-2013 12:00 AM
The Driveshaft Shop Custom Axles and Shafts Sportsguy83 Engine, Exhaust, Transmission 26 01-11-2013 05:55 PM
FS: (Toronto,Canada) Continental Racing Slicks 225/45/17 OptionJDM Wheels and Tires 2 09-19-2012 11:48 AM
Choice of slicks for HPDE CB762 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-02-2012 10:25 PM
