| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Screw Size Inquiry
Good morning all,
Last night, while attempting to install hood dampers, I over-tightened one of the 10mm bolt on the fender lining area and broke the top portion off... Now I need a replacement bolt but having a hard time looking for the right size.. I attached a diagram for your convenience (#3 on the diagram), please tell me what size bolt I need to get... Thanks!
#2 |
Drives: Dark Grey Metallic 2013 BRZ
M10-1.25x ___MM is the way to look for it. Metric bolts are measured in mm, not inches. Also on top it should have a number stamped in it. 8.8, 10.9 or 12.9 those tell you the hardness. Other than that if you had a comparo picture, or just bring it to a local fastenal and they'll be able to help you size it.
| The Following User Says Thank You to RurumariGhost For This Useful Post: | PHOsho (07-29-2013) |
#3 |
you'll also probably want a screw extractor to get the threaded portion you snapped off out of that hole. Unless you already took care of that.
#4 |
Thanks!! Getting it removed tonight after work
#5 |
Drives: old
That is not an M10 bolt. Bolts are measured by the diameter and pitch of the threaded portion. It was most likely an M5x1.25 or M6x1.25 bolt with a 10 mm head. Remove one of the other fender bolts and bring it to a napa to match it up.
#6 |
yeah what ozzman said, bolts are measured by diameter not head size my mistake.
#7 |
I did the same thing yesterday. Had a hell of a time getting the rest of the bolt out. Were you able to get a replacement and if so what size. May save me a few minutes at the store.
| WHAT DID YOU SCREW UP TODAY? | Books | Scion FR-S / Toyota 86 GT86 General Forum | 115 | 06-07-2013 09:38 AM |
| TRD Exhaust inquiry? | Realm | Engine, Exhaust, Transmission | 2 | 02-27-2013 02:18 PM |
| What is this screw for? | chenshuo | BRZ First-Gen (2012+) — General Topics | 13 | 02-17-2013 11:15 AM |
| Pop-Screw Retainer Size? | FR-S Matt | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 01-20-2013 11:48 AM |
| Another dealer inquiry (vic ***) | xeri | AUSTRALIA | 8 | 05-08-2012 11:58 PM |
