sway bar problems =(
So as the topic suggest i have a sway bar/LCA/end link problem. I have whiteline adjustable rear sway and end link. I have ISC LCA's. When i have the end link in the medium configuration i should be able to match it up with the center hole on the sway bar, only i cant. it will only go in the front one. I do not know if this is a problem with the sway bar and lca not being compatible, even though it would seem weird since its literally just a straight LCA. Ive broken 2 endlinks this year, along with the fact they squeak alot. i had this install professionally. i just need help really. i have no idea where to start and how to access the problem.
| FS: Koni shocks, TRD sway bar & WRX sway bar | scirocco78 | Brakes, Suspension, Chassis | 14 | 08-31-2015 07:47 AM |
| WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 02:20 PM |
| AT problems? | AJPG | Engine, Exhaust, Transmission | 8 | 03-08-2015 07:50 AM |
| Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. | FRSport.com | Brakes, Suspension, Chassis | 0 | 01-23-2015 01:38 PM |
| Transmission problems, oil leaks and detonation problems.. | turboviper | Issues | Warranty | Recalls / TSB | 4 | 06-18-2014 05:01 PM |
