Old 06-22-2013, 12:17 PM   #1
Hempo
Drives: Subaru BRZ
Aluminium intake manifold?
Hempo is offline   Reply With Quote
Old 06-22-2013, 12:21 PM   #2
grostoine
Drives: Subaru BRZ
FA20Club Cold air intake is what your looking for. Go to the selling section.
grostoine is offline   Reply With Quote
Old 06-22-2013, 12:33 PM   #3
Hempo
Drives: Subaru BRZ
Not really,
THIS is what i want in aluminium https://sphotos-a.xx.fbcdn.net/hphot...70113259_o.jpg
Old 06-22-2013, 12:37 PM   #4
grostoine
Drives: Subaru BRZ
OH ! Sorry! I read it wrong.
Old 06-22-2013, 12:52 PM   #5
Hempo
Drives: Subaru BRZ
No problem
Old 06-22-2013, 01:37 PM   #6
ML
ML's Avatar
Drives: 13 White MT FR-S
I have seen them but not for sale
Old 06-22-2013, 05:07 PM   #7
Muller Performance
Muller Performance's Avatar
Drives: Subaru & Scion
I've never seen one and all the old suby motors all have round runners. What are you trying to accomplish?
Muller Performance is offline   Reply With Quote
Old 06-23-2013, 09:57 AM   #8
Hempo
Drives: Subaru BRZ
Where have you seen them?
Old 06-23-2013, 10:25 AM   #9
Muller Performance
Originally Posted by Hempo View Post
Yeah i know they have round runners, used to drive and old WRX earlier But maybe there is a manifold that has the mounting holes equal or at least similar to the BRZ that one can modify with an adapter for the round runners.
I'm in the starting pits of building my own SC-BRZ
I don't think there's anything wrong with the factory intake manifold though. You wouldn't want aluminum compared to the plastic one, it holds heat more. In fact, did you know the newer WRX manifolds flow better than the current gen STI manifolds?
Old 06-23-2013, 11:39 AM   #10
arghx7
Drives: car
Plastic/composite intake manifolds are better than metal, assuming they aren't leaking. You don't have the imperfections of metal casting (rough surfaces etc) and it weighs less. The only issue for a custom project is that yes, you can't cut it up and weld to it.
Old 06-23-2013, 12:12 PM   #11
benster
Drives: none yet
plus I'm pretty sure the runs at 620whp were with the stock plastic intake if you're worried about blowing it up.
benster is offline   Reply With Quote
Old 06-23-2013, 02:53 PM   #12
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Since JDL blew up their intake manifold, I believe they are designing one. I'm sure it will be pricey though.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
Old 06-23-2013, 05:16 PM   #13
wparsons
wparsons's Avatar
Yes i know that the plastic ones isn't bad at all, it's just that what arghx7 says, i can't weld to it..
I won't run super high boost or an insanely amount of torque/HP so the difference in heat shouldn't be an issue.
Why do you need to weld to it?
As for heat, even a stock engine without boost will heat soak the manifold enough to make a noticeable change in performance.
Unless you're running enough boost to burst the stock one, or are running really aggressive cams that require a totally different runner length and plenum volume you shouldn't have to touch the manifold.
flickr
Old 06-23-2013, 07:09 PM   #14
NomoreNA
NomoreNA's Avatar
Drives: Raven FRS
Im not going into detail but to avoid further speculation and the spread of false information I picked up solid gains on my sheet metal manifold. its well worth it for a boosted application over 500.
NomoreNA is offline   Reply With Quote
Intake Manifold Bu-Tang Engine, Exhaust, Transmission 29 12-06-2014 02:43 PM
TRD/STI Aluminium Carpet plates AL008 Australia Classifieds 22 05-26-2014 05:35 AM
WTB Turbo manifold evanmd Engine, Exhaust, Bolt-Ons 0 06-02-2013 08:02 PM
Custom Hello Kitty Intake Manifold Cover (seriously?) Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 6 04-01-2013 02:36 PM
Grimmspeed 86 aluminium oil cap jonnyboy Australia Classifieds 1 03-22-2013 07:07 AM
