| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2020 BRZ
Decel Fuel Cut Behavior in 2020 BRZ – 5th/6th Gear at High Speeds
Hey all,
I’ve noticed something odd with my 2020 BRZ regarding deceleration. Normally, when I lift off the gas, the car hits fuel cutoff pretty hard and decels quickly. However, in 5th and 6th gear at speeds above 80 mph, it behaves differently. Instead of the usual hard fuel cutoff, it gradually lets off fuel and deceleration feels much softer. This doesn’t happen in other gears or at lower speeds. The car is bone stock, other than muffler delete and some RPF1s. Stock airbox, never changed. 57k miles, I’m the original owner and haven’t done anything besides basic maintenance. Things I’ve tried so far: • Cleaned the MAF sensor • Reset the ECU by disconnecting the battery Neither of these made a difference. Has anyone else noticed this behavior? Could this be normal ECU programming for high-speed cruising, or is it something that could be tuned or adjusted? I’m curious if anyone else has noticed this or if someone can go for a drive in their car and see if it’s the same. Thanks in advance for any insights. |
| 5th Gear Decel Whine/Vibration/Rattle/Whatever you want to call it | M0nk3y | Engine, Exhaust, Transmission | 1 | 05-10-2023 12:08 AM |
| Fuel cut/throttle cut in high boost after installing motor mounts | Top Gun | Forced Induction | 0 | 10-03-2020 11:01 PM |
| 5th Gear Grind at Freeway Speeds? | l0aded | Issues | Warranty | Recalls / TSB | 124 | 03-21-2018 08:04 PM |
| Stock ECU decel fuel cut? | armstrom | Software Tuning | 8 | 06-17-2016 05:03 AM |
| 5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? | kharn83 | Issues | Warranty | Recalls / TSB | 9 | 08-06-2012 08:44 PM |
