Drives: 2015 BRZ
Bypassing the Rotrex
My JRSC is sick, but I still need to get to work. Is there a way I can bypass it so it won't spin? I don't want to cause even more damage.
Thanks -Mark |
#3 |
Drives: 2016 Scion FRS Release Series 2#439
Surely you’ll need to go back to the NA tune as well.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms 235F/245R Conti ECS on TRD/Enkei wheels (street), 245/40 sq. ECF on 17x8 720Form GTF2 wheels (track) |
#4 |
Drives: 2015 BRZ
I looked it over & I think I can just remove the s/c, put the idler pulley back, and run off of the stock belt. If I don't touch anything else, I should be able to use the s/c tune. I mean, it'll just stay on the part of the map where there's no boost, right?
#5 | |
Drives: WRB BRZ
Yes if it makes no boost you still fine on the SC tune |
#6 |
Drives: 2015 BRZ
Well, that was the most depressing Saturday ever.
Spent several hours making my car slower. I was able to put some stock parts back & get it running while I send the blower back for a replacement. I think it might be slower than stock now, since it has to suck air through all that tubing and the intercooler. http://ls1m.com/demo/SCGONE1.jpg http://ls1m.com/demo/SCGONE2.jpg |
#7 | |
friendly
Drives: 17' 86
Seek comfort in discomfort.
#8 |
Remove rotrex assembly.
Replace stock pulley and belt Replace stock intake Flash stock rom. Leave the intercooler and everything else in place, for minimum re-assembly/installation. Tape up/cover up all the hose/pipe openings so you don't get contamination. |
| What's the official solution to bypassing the VSS + e-brake sensor for videos? | [Cyanide] | Electronics | Audio | NAV | Infotainment | 37 | 05-05-2015 02:51 AM |
| Bypassing the navigation activation ??? | Sabretooth | Electronics | Audio | NAV | Infotainment | 15 | 02-24-2015 12:32 PM |
| Bypassing your NAVI without moving out your NAVI | 8987846 | CANADA | 0 | 12-24-2012 03:20 AM |
