| BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ |
Drives: '23 BRZ
Fuel Range/DTE 10-mile increments
Just discovered this as I ran out my first tankful last night. 50 miles, 50, 50, 50, then 40? WTF? 40-40-40-30, Ohhhh, WTF?! Is there *any* way to change this? GR86 apparently has 1-mile increments.
Combine that with, instead of an almost continuously decrementing fuel gauge of my old '17 (gotta be at least 64 little needle jumps from F to E), now there are 12 big fat discrete blocks that go out one by one. So now I have way less precise info on how much fuel I have left and how far I can go before having to fill up. The old dashboard/infoscreen is WAY better than the new one. It's like it went from 64-bit to 8-bit. Also everything being white is not a great look either. |
#2 |
Drives: 22 BRZ
The distance to empty isn't perfectly accurate in any car, so limiting it to 10 mile increments makes fine sense.
It's a largely useless, redundant feature anyways. Just use the fuel gauge and common sense. |
| The Following 2 Users Say Thank You to AK2112 For This Useful Post: | CaptainFenderbaum (05-18-2023), Jdmjunkie (05-18-2023) |
#3 | |
Drives: '23 BRZ
New system, look down and see "10 miles", it's not telling you nearly as much info at a time when it would be *very useful* to know whether it really means 19 miles, or 5 miles (+ safe "reserve" +/- error). Accuracy is one thing, precision is another. It has taken away precision by a factor of 10x or more, for *no reason*. 10 mile increments makes zero sense, taking a formerly somewhat useful feature and *making* it useless. Combined with the new far worse fuel gauge, it's mildly infuriating. The old gauge had much much finer resolution, and continued to decrement past "E", new one with 12 massive blocks, each representing upwards of 30 miles. Combined, the new setup gives you *way* less info about how much fuel and range you have left. Stupid, senseless changes. |
#4 |
Drives: 2023 brz limited 6mt red
I have always been weird and never ran any of my vehicles to the fuel light or under 50miles to empty....potential starvation of fuel pump or having all the gunk concentrated in the fuel pump basket or an emergency that requires me to not stop at a gas station.
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
#5 |
Drives: 22 BRZ limited
I just think of each bar as 1 gallon.
#6 |
Drives: 2022 BRZ; 2014 BRZ
In my experience, when the gas light comes on there's still 2 gallons in the tank. The most I've ever put in the car at one time was 11.5 gallons, and that was 2 autocross runs and about 5 miles after the gas light came on and there were "0 bars" of gas left. There's a lot of margin for error on these cars, I'm not the only one who's experienced this on both the BRZ and GR86.
As far as 10 mile increments, I think that's just a Subaru thing.
#7 | |
Drives: 2018 Subaru BRZ Limited with PP
#8 | |
Drives: '23 BRZ Limited
I typically fill up any car once I hit 1/4 tank.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
#9 |
Drives: '23 BRZ
If you fuel up at 1/4-tank or 50 miles *indicated* remaining, you are refueling about 33% more often than you need to. For peeps who do this, the "new" setup with 10x less precision on *both* the fuel gauge *and* the range/DTE meter, not an issue at all.
Me, I like to run it down as near to empty as I safely can, with some reasonable margin. EASY with the old car reporting range all the way down 10-9-8-7-6-5-4-3-2-1---. Where the new car is just gonna go from 10, to -- (I guess? Haven't been there yet). And while the old car's fuel gauge would tick down in tiny increments all the way to E, and beyond, giving useful info all the way, the new one is gonna have a giant 1/12-tank block that disappears and that's it. Like 25-30 mile resolution where the old one it's something like a couple of miles per tick IIRC. Both are particularly galling because in the range, there's a digit that just stupidly stays at "0". And for the fuel tank the LCD gauge could be more continuously variable using more pixels like the voltmeter and oil temp gauges do, but NO, giant 1/12 blocks. Ditto the coolant temp with it's huge increments. Why? FWIW here's some of my fillups from fuelly ranked by most fuel per fill. Never ran it out of fuel... Last edited by ZDan; 05-18-2023 at 01:04 PM. |
#10 |
Drives: FR-S,GTI
So you like to keep your car as heavy as possible? Do you keep your windshield washer full too?
Sorry just being a smart ass. |
#11 | |
Drives: '23 BRZ
At the track I ran with a full tank +40 lb. ballast in the trunk with the '17, with empty washer fluid reservoir and 5 lb. Li battery, to meet my minimum weight for time-trial class with best weight distribution. With the new one I'ma hafta run with full tank, massive stock battery, transplanted spare tire, plus another ~90 lb. in the trunk! Last edited by ZDan; 05-18-2023 at 01:45 PM. |
#12 | |
But I drive so little I really don't care if I'm filling up 40 miles too soon nor is the 3-4 minutes it takes a big deal. I've had the car since Sept 3rd and it still only has 1650 miles on it. And 250 of that was a trip to Tulsa two weeks ago to see a friend of ours.
#13 | ||
Drives: '23 BRZ
I *used* the much-greater range and fuel-tank gauge accuracy in the '17 PP. And I will most definitely *miss* getting to-the-mile range estimate *and* ~10x finer resolution fuel gauge with the new one's big clumsy 10-mile and 1-gallon increments
#14 | |
I was doing 85-95 on the way up most of the time a few times above 100. On the way back I was able to just set the cruise at 85. IIRC I have two bars and only about 270 miles on the trip meter.
| Camber plate increments. | gen3v8 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 05-19-2022 11:28 PM |
| The return of Aptera? 1000 Mile Range Solar Vehicle | spcmafia | Other Vehicles & General Automotive Discussions | 7 | 02-10-2022 10:21 PM |
| BMW iX coming in 2022 with 500 horsepower and 300-mile range | vh_supra26 | Other Vehicles & General Automotive Discussions | 14 | 11-13-2020 01:05 PM |
| Fuel light range | pushrod | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 09-04-2014 03:20 PM |
| FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. | MmmDieselFumes | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 02-02-2014 09:19 PM |
