Old 03-27-2020, 10:11 AM   #1
grumpysnapper
grumpysnapper's Avatar
Ohlins TTX/TPX rally adapted for BRZ
I've finally (today) completed my full BRZ build, and thought you might be interested in the specially built Öhlins TTX/TPX rally dampers I have had built to fit the BRZ...replacing an existing set of Ohlins SUS MP21 R&T.
(I've tried to build my perfect interpretation of a useable daily driver tarmac/dirt rally car, that is still comfortable, reliable and can cover large distances.
It is producing around 350 HP and a touch over 400Nm at the rear wheels via a Harrop supercharger controlled via a Motec. I had a priority to keep weight down, and with a full tank of fuel, it sits at about 1260kg. But with aircon and an OK sound system.)
Fronts are a twin piston strut with a 44 mm piston (TPX 44) and 3-way adjusted with 1-way rebound and 2-way compression. The rear damper is a twin tube damper (TTX 44) with a 44 mm piston and 3-way adjusted.
I couldn't find anyone here in Australia, or the USA, who wanted to take on the challenge...and eventually found an amazing Ohlins rally suspension specialist in Holland (Leo at Madeno Racing) who has produced the most incredible dampers....after many emails, cad drawings, photographs, measurements etc etc.
My stipulation was that they had to be a direct "bolt in" to a standard BRZ/86 suspension set up...but then have enough flexibility of adjustment to be able to cope with a number of different possible set ups.
The TPX and TTX had to be completely re-engineered....including being shortened to a huge degree (Rally dampers have a huge amount of travel...and our cars have a very small amount of travel...sadly..).
The dampers come from the factory with no front mounts, and incompatible rear mounts, so every thing had to be custom made from scratch.
On advice from the builder I have fitted softer spring rates (40N/40N compared to my existing SUS MP21 rate of 60N/60N). He ended up fitting Eibach springs with helpers.
These are the finished beasts....
If there is any interest, I can post comparison pictures and development pictures.
Cheers, Lyndon
Last edited by grumpysnapper; 04-06-2020 at 09:45 AM. Reason: Forgot to credit the guy who did the amazing work
grumpysnapper is offline   Reply With Quote
The Following 12 Users Say Thank You to grumpysnapper For This Useful Post:
asdf (03-27-2020), bcj (03-27-2020), Captain Snooze (03-31-2020), Celica00 (04-01-2020), Clutch Dog (03-28-2020), Code Monkey (03-27-2020), CSG Mike (03-27-2020), DarkSunrise (03-28-2020), kask2_6.0 (03-27-2020), solidONE (03-27-2020), soundman98 (03-27-2020), TofuJoe (03-28-2020)
Old 03-27-2020, 10:32 AM   #2
new2subaru
Weight Weenie
Drives: 15 FR-S
Interested and subbed!
The Following User Says Thank You to new2subaru For This Useful Post:
grumpysnapper (03-28-2020)
Old 03-27-2020, 10:57 AM   #3
Racecomp Engineering
Absolutely brilliant. Well done!
How much travel did you end up with? What kind of tires? Stock swaybars?
- Andrew
BuT tWiNtUbEs ArE nO gOoD
grumpysnapper (03-28-2020), wparsons (03-29-2020)
Old 03-27-2020, 11:26 AM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
If you intend to use for rally, haven't considered ohlin's strut hole camber inserts for reliable under abuse/hits/jumps camber offset? (page #9)
No clue how these performs, but purely from aesthetic viewpoint, looks & finish of these look like porn.
Capt Spaulding (03-30-2020), grumpysnapper (03-28-2020)
Old 03-27-2020, 11:27 AM   #5
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Hell - I'd just hang those in the living room and stare at them all day..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
grumpysnapper (03-28-2020), soundman98 (03-27-2020)
Old 03-27-2020, 11:50 AM   #6
grumpysnapper
I know this will all seem strange...
I run 16" wheels with 225/55 Pirelli P7 and P1's on two sets of Rays CE28's.
Front sway bar is standard, and rear is a hollow 23mm.
Bushes are all standard...but replaced regularly. All arms and links are standard too. (Brakes are AP Racing)
Ride height is set about 5mm above standard.
I've fitted a different rear top mount to release an extra ~25mm of travel.
However, aside from that, the front has the standard length of travel.
I might be wrong, but I've always felt that controlled compliance is your friend for speed on real world roads, and that too much mechanical grip can take a lot of fun out of driving.
This is the comparison of a standard SUS MP21 strut with the TPX as it came out of the box before any modifications!
The Following 7 Users Say Thank You to grumpysnapper For This Useful Post:
churchx (03-27-2020), CSG Mike (03-27-2020), new2subaru (03-27-2020), Pat (03-27-2020), solidONE (03-27-2020), soundman98 (03-27-2020), wparsons (03-29-2020)
Old 03-27-2020, 11:55 AM   #7
grumpysnapper
Rears: comparison of a standard SUS MP21 with the TTX as it came out of the box before any modifications.
The Following 4 Users Say Thank You to grumpysnapper For This Useful Post:
CSG Mike (03-27-2020), new2subaru (03-27-2020), soundman98 (03-27-2020), wparsons (03-29-2020)
Old 03-27-2020, 12:27 PM   #8
venturaII
venturaII's Avatar
I run 16" wheels with 225/55 Pirelli P7 and P1's on two sets of Rays CN28's.
225/55-16?? Or 225/50? Or 205/55?
And compliance is indeed the way to go fast on real roads.
The Following User Says Thank You to venturaII For This Useful Post:
Old 03-27-2020, 12:38 PM   #9
grumpysnapper
225/55 r16 Pirelli P7's & P1's. (P1's have a touch less grip, but can cope with road surface abuse a little better)
The Following User Says Thank You to grumpysnapper For This Useful Post:
venturaII (03-27-2020)
Old 03-27-2020, 12:50 PM   #10
grumpysnapper
Yeah, it has the camber 'shim' inserts system, and came with a set of inserts from 0 to -3.5 deg.
Its a great system, very quick to change and very accurate.
Having said that I only run about -1.5 deg on the road, and the car is still intended as a road car, I won't be rallying it.
You can see the cutout for the camber inserts under the top bolt in this shot.
The Following 5 Users Say Thank You to grumpysnapper For This Useful Post:
Kiske (11-27-2020), new2subaru (03-29-2020), Racecomp Engineering (03-27-2020), solidONE (03-27-2020), soundman98 (03-27-2020)
Old 03-27-2020, 01:00 PM   #11
venturaII
venturaII's Avatar
Weird...I can only find the Centurato P7 all season in that size on TireRack, and nothing in the P1. The P7 has a TWR of 700, which seems to put it in a very different performance category than what the rest of your suspension setup is capable of delivering. Maybe you have a different selection of Pirelli products down under?
EDIT: Just went to Pirelli Australia, and indeed it does seem that way...
Old 03-27-2020, 01:33 PM   #12
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
This is a cool project, props! Those photos showing the standard Ohlins vs Motorsports Ohlins says it all, travel is king.
Lincoln Logs is offline   Reply With Quote
The Following 3 Users Say Thank You to Lincoln Logs For This Useful Post:
grumpysnapper (03-28-2020), Racecomp Engineering (03-27-2020), wparsons (03-29-2020)
Old 03-27-2020, 03:18 PM   #13
CSG Mike
CSG Mike's Avatar
Carn porn!
Old 03-27-2020, 05:44 PM   #14
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Beautiful! Would love to see more photos!
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Ohlins TTX/TPX Group N rally adapted for BRZ grumpysnapper Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-27-2020 10:09 AM
JRP-Suspenson Group buy! KW,Ohlins,HSD,Cusco,SPC-NOW FREE SHIPPING! Stav Canada Classifieds 33 05-16-2015 11:51 AM
*GROUP BUY: JUST IN RALLY ARMOR MUDFLAPS!* genometuning Groupbuys 585 01-15-2015 07:08 PM
Ohlins group buy aruxe CANADA 1 05-22-2014 04:36 PM
Group B rally awesomeness MtnDrvr86 Other Vehicles & General Automotive Discussions 0 11-08-2011 06:05 PM
