Drives: 13 FRS
Coilovers with stock wheel size?
Hi all,
I need to get new coilovers again as my rear OEM have started leaking again after being installed for less than a year... I am considering splurging on coils this time around but I don't to change my wheels.. I invested in OEM-size nice BBS wheels and personally, I think 18" or 19" wheels are kind of ugly on this car. I also don't want to ruin the driving characters on a 200hp car by getting unncessarily wide wheels just to sit flush Did Toyota really trap us here by only making coilovers work with wider wheels? Seems a little silly I know spacers are 1 solution but i've gathered that that they are iffy.. especially on the track |
#2 |
Drives: '13 FRS - STX
wut
oem suspension is coilover design no aftermarket coilover has worse clearance than the oem coilovers you'll be fine bolting on any suspension designed for this car |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | RickyRacer (01-27-2020), wparsons (01-28-2020) |
#3 |
Drives: 2017 BRZ PP , 2005 Saab 97X
the issue is guys who stab a 17x9 under stock wheel arches, the OE coilover has interferance issues depending offset
its fine for the stock 7,7.5, 8 inch applications |
| The Following User Says Thank You to Clutch Dog For This Useful Post: | RickyRacer (01-27-2020) |
#4 | |
Drives: 13 FRS
I’m not worried about clearance.. more so.. my OEM size 7.5” wheels will look sunken into the suspension will they not? Effectively making OEM wheels look ridiculous with aftermarket suspension, is that why everyone gets 9” wheels? I just don’t want wider wheels... like the way the car feels with these light wheels |
#5 |
Oh your question makes more sense now.
Toyota didn't hose narrow wheel lovers, they gifted people who like grip the clearance for a decent tire width to go out have some fun and be faster than they have any right to be. So many shitboxes don't have the clearance for more than a 225 these days. Yes if you're really so concerned with looks give it a shot and if you don't like it order a set of 20mm bolt on spacers. Good luck. |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | RickyRacer (01-27-2020), Tristor (01-29-2020) |
#6 | |
Drives: 13 FRS
Thanks... Also 9 inches are slow |
#7 |
Purist
Drives: 2013 FRS - Hot Lava
20mm Front and 25mm Rear spacers bring the stock wheels flush. 17x9 +40 to +35 fit within the arches and spring perches on a stock car. +45 depends on tires.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
| The Following 4 Users Say Thank You to Westen86 For This Useful Post: |
#8 |
Drives: C5, GT-86, '24 Colorado TrailBoss
I have coilovers, when went with new wheels I went with 8" wide 40 offset. I was scared of too much poke. Well I was wrong its too sunken in for me. Wish I went 9" 40-35 offset
| The Following User Says Thank You to SuperTom For This Useful Post: | Leonardo (01-28-2020) |
#9 |
What kind of suspension you have won't change how flush the wheels are... if you lower it 1" on lowering springs, or 1" on adjustable coilovers the wheels will sit exactly the same.
If you're happy with how the car drives now, "splurging" on coilovers will be a waste of money. They'll be stiffer, and likely much less comfortable. I would also look into how you keep getting leaking rear shocks before spending more money on coilovers.
Light travels faster than sound, so people may appear to be bright until you hear them speak... flickr Last edited by wparsons; 01-28-2020 at 05:44 PM. |
#10 |
Yeah you could just get some Bilstein B6 or Koni Yellow dampers and call it a day.
- andrew |
#11 | |
Drives: 13 FRS
Because as opposed to buying a new strut + spring assembly from Toyota for 300$+ I could just spend $1500 on all 4 corners I'm in canada so things here are more expensive for no reason. and the roads are garbage thanks to all the salt its pothole heaven over here |
#12 |
Loading...████████] 99%
Drives: #0517
Keep in mind if you go to an adjustable coilover setup there are more components that may require maintenance/servicing and/or possibly break.
As noted by previous folks already, should look into why the shock is leaking. If it is due to the road conditions, it likely would not be better on aftermarket adjustable coilovers. Something w/o adjustment like Bilstein b6 may be the easiest solution. As for the wheels...new wheels w lower offset or spacers. Most oem setups will look a bit “sunken” in if the car is lowered...
R1 3 5
╘┼┼┤ . 2 4 6 |
| The Following User Says Thank You to asdf For This Useful Post: | wparsons (01-28-2020) |
#13 | |
Who is assembling the shock/spring/upper mounts that keep failing? Is is just one side, or both rears? How many km's since the last replacement before it started leaking again? I'm in Canada too, and $1500 coilovers aren't going to ride as nice as stock at all. I'll happily take you for a ride in my car on KW V3's if you're in the GTA. It's not overly harsh, but it's definitely a lot stiffer than stock, and definitely more than $1500. I'd offer to send pictures of how sunken in the wheels are, but I'm running 10mm spacers up front and a lot more camber (-3.2). Rears will be a better sense of what you'd be looking at. Front might be decently relevant, I haven't run close to stock camber up front since it was on stock springs. Unrelated, it's not the salt causing pot holes it's the freeze/thaw cycles.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | new2subaru (01-28-2020), NoHaveMSG (01-28-2020) |
| Wheel fitment: rtx r-spec stag 17x9 38mm offset on stock height and coilovers | Gutterboy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 05-06-2017 02:39 PM |
| Best Wheel Size? | VinJah | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 08-29-2016 12:51 PM |
| Optimal Wheel Size for Stock Power | Tanuki | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 110 | 06-09-2016 11:08 PM |
| Tire size for square 18x8.5+38 lowered on coilovers? | B$ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 10-07-2015 06:50 PM |
| Stock Wheel Size Confirmed..? | CoryUyede | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-22-2011 01:26 AM |
