Old 02-20-2018, 10:12 PM   #1
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Sparco EVO II USA Seat random feedback...
This past weekend at Sebring I sat in a car with the Sparco II EVO USA seat. It was mounted with the Sparco mounts. Looked right and felt right. Seating postion was lower than stock, which was a preference for me as well. I'm 5'8" and fat, I fit. Owner of the car is similar height. If you're an Orangutan, you might even want the seat lower. It may have been able to mount slightly lower - something to fiddle with, if needed. If you fit in the stock seat, you'll fit better in this seat. Brackets / mounts can be dealt with. This seat fits the car very well and looks right. Obviously it's not a full containment seat, but the shoulder support was good.
This is an easy choice for something you can't "trial fit" in the car. I would have no reservations about buying one and may do just that.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
The Following 4 Users Say Thank You to jmimac351 For This Useful Post:
Andyxin (02-08-2019), Kestrel (02-24-2018), Tristor (09-02-2018), x808drifter (07-05-2018)
Old 02-24-2018, 12:19 PM   #2
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
This seat seems perfect for me. Thanks for reporting in.
Kestrel is offline   Reply With Quote
Old 02-24-2018, 04:32 PM   #3
Kestrel
Kestrel's Avatar
Were sliders used in this set up?
Old 02-24-2018, 08:04 PM   #4
jmimac351
jmimac351's Avatar
No sliders. Installed with a seat mounting base with the Sparco uprights you see there. I think it was an easy bolt-in.
2015 Subaru BRZ
Old 02-27-2018, 05:52 PM   #5
Pat
Pat's Avatar
Drives: 2023 BRZ
Good stuff, thanks for sharing. I miss having a good one-piece seat.
I know you're big on safety, so be careful with things like, "If you fit in the stock seat, you'll fit better in this seat." There are very few one-piece seats I fit in, as I'm 6'3" and shoulder harness pass-throughs are often too low for me. I had a hell of a time finding one that I felt was "right".
That said, I recognize your comment may have been exclusively about seat fitment, not the use of a full harness with the seat.
Old 02-27-2018, 06:30 PM   #6
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
It's good to know what size chair the car can accommodate - thanks!
Originally Posted by Pat View Post
There are very few one-piece seats I fit in...
Taking off from there...I fit in most chairs, but in terms of a chair fitting my body, I've found that Recaros fit me much better than the half-dozen or so other brands that either came with cars I've bought or that I tested out on a showroom floor.
To me, chairs are like helmets. If you can, try it on before buying; if you can't, be prepared to send it back.
dradernh is offline   Reply With Quote
Old 02-28-2018, 09:45 PM   #7
jmimac351
jmimac351's Avatar
Yes. Great point. My view is that this seat is "more" of what the stock seat is. More aggressive hip and shoulder support, etc. Proper belt alignment / install requires measuring, for sure.
I'm buying the setup in these pictures. The owner just bought a GT-4...
2015 Subaru BRZ
The Following User Says Thank You to jmimac351 For This Useful Post:
Old 05-27-2018, 03:23 PM   #8
Kestrel
Kestrel's Avatar
I'm attempting to install one now with Nagisa Auto rails and I can't seem to get them wide enough to line up.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 05-28-2018, 11:05 AM   #9
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
I have the EVO II (not US) as my passenger seat in my BRZ. Easy mounting with Planted bases and side brackets. No slider. Plenty of room and range of adjustment. I barely fit in this seat, though, at 6'3'' 275.
For my seat, I went with the Ergo II (L). The seat is significantly bigger than the Evo II and somewhat larger than the Evo II US in overall size and has a much higher and wider top with the removable halos. As a result, to get enough legroom, we had to make some modification to the seat base and position the seat far enough back that the top left of the seat interfered with the b-pillar and headliner. Those were removed. Tall/wide drivers with shorter legs may be able to put an Ergo II in the car without issue as at least one other 86er has done.
If anyone wants pics, let me know.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
Old 07-04-2018, 12:37 PM   #10
Turbo
Drives: FR-S Turbo
I'd love to see pics of the base and how you mounted it in, Alan.
I have a race bucket here ready to install, just need a push in the right direction!
Turbo is offline   Reply With Quote
Old 07-26-2018, 03:44 PM   #11
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I need to buy a new seat for my new build and knowing what you know, do think the EVO or EVO II is the droid I'm looking for?
I'm 6' even and 190lbs. 36" waist. Would the EVO II be too big?
SCCA T4 - FRS
Old 07-27-2018, 10:24 PM   #12
jmimac351
jmimac351's Avatar
I don't know for sure, Alan may have other thoughts... but it's not obvious to me that it would be too big for you. Something else to consider... it may be big enough to work for you and also allow someone else to drive the car (you never know when you want that to happen, and why).
I think seats are like helmets and gloves... you have to try them on. The only reason I bought this seat is because I sat in it, liked it, and it became for sale; otherwise, I would not have sought it out. That's why I shared this as I figured others may be wondering what works in the 86.
Good luck.
2015 Subaru BRZ
Old 09-02-2018, 09:30 PM   #13
Alan
Alan's Avatar
Sorry I'm late to the party on this, but I don't check in here as often as I used to. As jmimac351 said, you have to try it on. I'm big, but carry my weight in the front, so seat width isn't as much of an issue for me as someone that is more pear-shaped. Go sit in seats and find out what is most comfortable that fits in the car. Remember, it also has to fit at the right distance to the wheel. Space gets tighter as you move the seat back in these cars.
OEM Seat rails rebuild for Sparco Seat? JDM_12 Cosmetic Modification (Interior/Exterior/Lighting) 2 12-03-2017 08:54 AM
Sparco EVO Seat and Stock BRZ Cloth Driver Seat jonesy Interior Parts (Incl. Lighting) 4 08-25-2017 11:42 AM
FS: Sparco Evo 2 Bucket Seat sebastiansim Interior Parts (Incl. Lighting) 1 07-31-2016 10:20 PM
Sparco seat mount and Sparco sliders for FRS/BRZ justinco Interior Parts (Incl. Lighting) 8 07-13-2016 08:35 PM
Random feedback after a few months Moe AFRICA 6 05-06-2014 07:48 AM
