| Software Tuning Discuss all software tuning topics. |
Drives: 2017 BRZ
P015A Code
Has anyone had issues with this code appearing before? I have done some searching for it and there is not much information on the code.
I have a 2017 manual with a Tomei UEL header and delicious tune for 91oct. I get this code every now and then. I won’t see it for a couple thousand miles, and then it’ll appear. Once or twice it cleared itself. This time I did notice that it came up right about 40-50 miles after filling up with gas from a QT instead of my normal Shell. Maybe this is coincidence? Any help would be appreciated. I have checked the header twice for leaks. First was a visual check with soapy water. Second was me undoing all bolts and retorquing them. If this isn’t a fueling issue, I’ll take the header off completely tonight to inspect the gaskets and use copper gasket sealer as an extra step when installing. Edit: here is a cruising log a few days before the code showed up. I can upload one tonight with the code if it doesn’t clear itself. https://datazap.me/u/barefootdan/log...7?log=0&data=6 Thanks! Dan Last edited by Barefootdan; 01-26-2018 at 12:24 PM. |
#2 |
Drives: UK GT86
A quick Google pulls up:
If the O2 sensor in question fails to cycle as rapidly and/or regularly as expected, over a set period of time and under certain predetermined circumstances, a P015A code will be stored and a malfunction indicator lamp may be illuminated. Possibly a sign the O2 sensor is on it's way out?
.: Stealth 86 :.
#3 | |
Drives: 2017 BRZ
#4 |
Drives: 2017 BRZ
Just an update for anyone who runs into this. I checked my header again for any leaks with some soapy water. None found. No soot or blackness around the header either. I filled up with shell 91 and about 75 miles later the light went off. Either my car hates QT gas or this is a huge coincidence!
| The Following User Says Thank You to Barefootdan For This Useful Post: | MJones_RB (05-04-2018) |
#5 |
Drives: FT86
LTFT look a little high at low rpm and high positive as well. usually a sign of a small exhaust leak
info on code diagnosis http://www.sucross.com/dtc_p015a_a_f...or_1-1834.html |
#6 |
Drives: 2017 BRZ WRB with PP
My 17 MY threw this also today while going 70. 1/4 tank of e85 left. Having a friend clear it for now.
Sent from my SAMSUNG-SM-N910A using Tapatalk |
#7 |
Sarcastic SOB
Helped a guy on the weekend with that code in the track parking lot. Did a visual and his secondary O2 sensor was so loose you could spin it!
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 12:27 PM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 09:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 11:19 PM |
| Code C1201 | Dipstik-sportech | Issues | Warranty | Recalls / TSB | 2 | 06-26-2014 11:12 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 02:27 AM |
