Drives: 2015 Scion FR-S
Possible headlight condensation?!
So it's been raining quite a bit here in Southern California, and my 10 series HID headlights has been fogging up time to time inside the lense
![]() I'm not sure if it's a condensation/leak somewhere, but I can see a little of haze inside the lense and when the car is completely dry, I make out some dried water streaks along the bottom edge of the headlights as well. It's happening on both side of my headlights. I don't see water anywhere so I'm ASSUMING it's from the pressure hose when I wash my car and all of that water may be getting underneath the hood?! I taped up the lid where it covers the low beam light to make sure no water gets through. I don't think it can be the sealant/silicone around the headlights; at least not on both sides. Do you think it can be due to the climate change? Inside the lense is hot when the lights are on so due to the cold weather outside can it be that the inner lense is fogging up? |
#2 |
Just drive it
Drives: 13' FR-S
Mine shows same hazy inside the housing, but no water inside.
#3 |
Drives: on the highway to hell
mine looks similar with the haziness
#5 |
No, it's not from the exterior. I can clearly make out some dried up water streaks around the bottom edge of the headlight as well. I'm guessing these are happening from the dried fog inside the lenses. Unlike the taillight condensation, I can't seem to make out the cause but can a climate change cause something like this?! I'm already having issues with my taillights and I'm starting to give up on this car if the headlights are leaking too...
#6 | |
If some condensation inside lights make you give up on a car then you may be in for a disappointing life of automotive ownership. Oh and LOL at "raining quite a bit" and "cold weather" in Southern California.
#7 |
Drives: 2019 BMW ///M4
Looks normal to me. Seems like my 10 series head light?
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
#8 | |
I've also gone through a faulty set of tail lights three times! under warranty and now with the headlights so it's a little more than you think. I have gear grinds and chirping as most FRS do, but it's certainly not "normal." You're right; I guess I'm being dramatic but the car is certainly a handful. I knew it before I even bought the car so I guess I have to deal with it. Thanks for helping a noobie. |
| The Following User Says Thank You to LANI86 For This Useful Post: | Tcoat (01-05-2017) |
#9 |
I can't make out the water streaks on the photo but there is more "character" to the condensation I see in my headlights. I can only get a glimpse with my own physical eyes. It's fine as long as it doesn't moisten up my entire headlights.
#10 | |
#11 | |
| The Following User Says Thank You to LANI86 For This Useful Post: | Tcoat (01-06-2017) |
#12 |
So I've managed to capture the fog inside the lense. You can see a bunch of cloudiness developing inside. When the HID is turned off you can't see it unless if you look at it from an angle, but it's prominent when the lights are turned on. It's happening on both sides and I can't seem to figure out where it's leaking from.
#13 |
Drives: '13 BRZ
Didn't they only make the 10 Series in 2013? Your signature lists your car as a 2015...are they aftermarket headlights?
#14 | |
N1rve
| Headlight condensation? | hmkk | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 09-10-2014 08:51 PM |
| Winjet headlight condensation after 3 months? | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-24-2014 03:55 AM |
| headlight/taillight condensation | Moe23 | Issues | Warranty | Recalls / TSB | 6 | 01-22-2014 03:27 PM |
| WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 04:32 PM |
| headlight condensation | MRZ415 | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 01-23-2012 03:24 AM |
