Front license Plate
Ok... bought the car in Arizona. No front plate required. Never had the front fascia drilled. And I like it that way.
But here on the Big Island, they frown on that (no front plate). So I want to fasten the plate frame TOTALLY in the grille area (got a spare). Any insight on whether this will cause overheating? P.S. And I hate how that plate on the passenger side thing looks.... |
#2 |
Drives: 2015 FR-S (Steel)
It might blow up ... but seriously no, it shouldn't be a problem.
#3 |
Drives: ̶1̶0̶ ̶S̶
There's a front licence plate bracket thing that is mounted on the grille, not the bumper, if anyone does the latter they're fucking dumb. There are also an infinite number of tow hook mounts, and then there are zip ties which you can use to cheaply and easily attach a plate to the front grille. |
| The Following User Says Thank You to saj For This Useful Post: | Tcoat (07-02-2016) |
#4 |
Drives: 17 Alfa Romeo 4C
Punch some holes in the plate to let the air pass.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
#5 |
I've never had any problems with overheating (or even seen the temp gauge close to, let alone passed the half-way mark) even sitting in traffic in August in Houston with 100 degree temps and AC blasting full. I've had a front plate installed since day one.
#6 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
Drilling holes in your radiator helps get the cold air to the engine as well
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
#7 |
I've had my front plate in the center of the grill for 3 years, no overheating problem here.
humfrz |
#8 |
Drives: 2014 BRZ Limited
Plus from a distance putting your plate in your grille makes the car look like a bucktoothed rabbit.
#9 |
#10 | |
Drives: Release Series 1.0
| The Following User Says Thank You to andrewtgg For This Useful Post: | saj (07-02-2016) |
#11 |
Drives: ̶1̶0̶ ̶S̶
Yea, I hate seeing brackets/plates drilled into the front bumper from dealerships, especially on luxury/sports cars when the manufacturer provides a mounting point.
#12 |
#13 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
#14 |
Drives: 2009 Nissan Altima, 2015 Scion FR-S
I believe there was a member on here that used neodymium magnets to create a bracket iirc.
Found it http://www.ft86club.com/forums/showthread.php?t=35261 Just saw it was on a brz so might not work for frs |
| Front License plate | DVNARC | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 09-23-2015 04:35 PM |
| Front License Plate | jaime3 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 07-08-2013 01:31 AM |
| License plate covering front plate effect cooling? | Wolfkiller | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-04-2013 08:19 PM |
| front license plate | bjun | BRZ First-Gen (2012+) — General Topics | 35 | 03-20-2013 03:20 PM |
| CA Front License Plate Law? | ashtray | Southern California | 24 | 09-11-2012 06:14 PM |
