| Software Tuning Discuss all software tuning topics. |
Drives: 13 White MT FR-S
Electric Power Steering with no CAN
Does anyone know if you our EPS motor will run in limp mode with only power and no CAN connection? Context is this is a aftermarket ECU and I'm building the chassis harness and would rather not run add the complexity of steering angle sensor, so just want to give the EPS motor/controller 12v and be done.
#2 |
has a funny hat
Drives: 2014 BRZ Limited
I read in another thread (I don't remember which) that it does similar to the Prius, but I cannot confirm at the moment. Although, I did recently acquire the parts to experiment with, but haven't done so yet.
#3 |
That is very much what I'm hoping and is my guess just based on visual similarities between ours and the Prius'.
#4 |
has a funny hat
I found a fail safe chart in the service manual this evening. I highlighted the condition I believe it will operate in when missing the CAN data (speed) from the stability computer. We should have a continuous output roughly equivalent to highway speeds.
#5 |
Wow you are awesome! Send me your PayPal and I’ll throw you some beer money!
#6 |
has a funny hat
Not necessary. I was going through the manual looking for a wiring diagram and stumbled on the chart.
#7 |
Drives: 2013 Brz Limited
Were you able to find a remedy to this? I swapped in a 2JZ and want to run as much of the car as possible on the standalone ecu.
If there's a way to permanently limit the power steering without the body control & power steering modules id love to hear how if worked out in your case. |
#8 | |
yes, you just give the PS box 12v straight from the battery and ground with the 4ga wire, and then switched 12v to the box on pin 6 of connector a15 to switch it on. it will go on limp mode but I have found it to be perfectly adequate that way
#9 | |
Does the power steering box need the other modules in place to have the ability to go into limp mode? I deleted ABS, and I'm not sure if the box needs inputs from the wheel speed sensors or if I can delete the system all together. |
#10 |
no, I have mine in with an engine swap and a standalone ECU and no ABS and its fine.
| Electric Power Steering (EPS) noisy | RevoG | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 144 | 10-01-2023 03:25 PM |
| Electric power steering and steering column part info | raspec | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 10-12-2021 05:27 PM |
| Electric Power Steering | oziel | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 01-24-2021 01:06 AM |
| Electric Power Steering | ArtS | Electronics | Audio | NAV | Infotainment | 0 | 10-31-2016 08:19 AM |
| Electric power steering | madfast | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 10-13-2011 10:11 AM |
