Old 09-30-2015, 06:56 AM   #1
smudge
Drives: Supercharged GT86
3" exhaust questions
I think it's time to bite the bullet and except the fact I need a 3" system with the new charger in place
After a bit of advice from Tarmac Sportz and Mark at Abbey, we don't think my current setup below will hack it:
Borla UEL manifold
Cobra overpipe
Berk high flow cat
Invidia Q300 catback
Our main points for concern at the HFC and the Invidia catback. I've seen HFC's blown out on turbo and charged 350z's in the past so it stands to reason that this may also be an issue on my 86.
The Invidia's backbox will be fairly restrictive and we probably need to look at a more free-flowing design to get the most out of the engine now.
I know very few people on here have 3" systems, but what do you have and what has been your experience? The only systems I know of are the Perrin and the Avo. Not really a fan of the look of either which I know isn't really the point but I want something that looks and sounds good obviously, as well as having the function.
Mark informed me that a 3" overpipe is possible. Apparently Cosworth have something?
I've also seen the Full Blown kit on here, looks like a nice piece of kit and has a 3" overpipe, front pipe and catback
I want to still keep my manifold UEL. I know this will lose me some horses but the Scooby burble is just too addictive to go to EL. Are there any UEL manifolds out there with a larger bore than the Borla I currently have?
Thanks in advance!
smudge is offline   Reply With Quote
Old 09-30-2015, 08:48 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
I have a JDL over-frontpipe and D2 exhaust. Fit is great. Quality is their usual.
Only header I know that's 3" is Nameless.
I'd be surprised if a good 2.5" system is much of a bottleneck. I'm not really sure even today why I went 3" - even pondering a swap of the whole setup to get the car quieter.
C
The Following 3 Users Say Thank You to cjd For This Useful Post:
Brzerker (05-23-2016), Chad86 (10-24-2015), smudge (09-30-2015)
Old 09-30-2015, 09:36 AM   #3
smudge
Thanks cjd
I've been looking at either the JDL, RevWorks or HKS UEL header. These seem to be the best of the offerings out there in terms of performance for the money
As for overpipe to catback, I've got my supplier quoting me on the Full Blown above and might be looking at a custom option being built if I get a chance to visit my fabrication guys this weekend
Old 09-30-2015, 09:51 AM   #4
fika84
fika84's Avatar
You don't NEED a 3" system FYI, there are people on this forum that have run into the 400WHP mark on 2.5" and didn't gain anything with 3".
fika84 is offline   Reply With Quote
Old 09-30-2015, 10:04 AM   #5
smudge
I'm in a position where I might as well. My 2.5" system is damaged so I may as well go for 3" to make sure I don't have to upgrade in the future
The Following User Says Thank You to smudge For This Useful Post:
fika84 (09-30-2015)
Old 09-30-2015, 10:04 AM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
^ This ^
Old 09-30-2015, 10:39 AM   #7
fika84
fika84's Avatar
Can't argue with that. Just know it's going to be louder and you're not going to get any gains out of it compared to the 2.5"
Old 09-30-2015, 10:42 AM   #8
smudge
^ This ^
^ This ^.....
Old 09-30-2015, 10:47 AM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
^ This ^.....
^^ That ^^
Old 09-30-2015, 10:56 AM   #10
Marcbrz86
Drives: 2015 Subaru BRZ Series Blue
^^ That ^^
This^^^
Marcbrz86 is offline   Reply With Quote
Old 09-30-2015, 11:19 AM   #11
smudge
^^ That ^^
^ Those....? ^
But seriously, I might as well upgrade while I have the opportunity
Old 09-30-2015, 11:25 AM   #12
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
CX kit came with 3" to the cat-back position, otherwise I would've gone 2.5. 2.5" is more than sufficient for the stock motor/trans power levels. 3" overpipe is very tight clearance and will rattle against the subframe depending on angle.
BRZoomTX is offline   Reply With Quote
Old 09-30-2015, 11:31 AM   #13
smudge
For those that don't know, I'm not stock
I'm on a built motor running the Sprintex 335 kit. Currently running her in and we're already seeing 1.2bar of boost at just 5500revs
Old 09-30-2015, 11:40 AM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
You might find that the Borla is in fact the issue and getting a good manifold will sort it out. You want a good merge collector and the right runners and I bet that running a quality 2.5" system won't hold you back. 3" is really for those running a turbo and will be a PITA daily unless you silence it alot, in which case a freer flowing 2.5-2.75" with less silencing might be the optimal solution.
If standard manifolds aren't up to your requirement you could always get a custom one made that will be optimal for an/your SC application.
.: Stealth 86 :.
Kodename 47 DJ:
wparsons (09-30-2015)
Raceseng Shock Tops Questions - 1" or 2" TrogDor the Burninator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-07-2014 10:12 AM
REQ: Looking for sound clip of Nameless 2.5" "No Muffler" Dual Exhaust Axleback jbsali Engine, Exhaust, Transmission 1 01-28-2014 07:22 AM
FS: j2 quad tip exhaust 2.75" NEED THIS GONE "price updated" FRSex Engine, Exhaust, Bolt-Ons 23 07-28-2013 10:07 AM
How many miles do you have on your "Turbo Kit" + Other's poll questions... NickFRS Forced Induction 40 05-10-2013 01:55 PM
How many miles do you have on your "Turbo Kit" + Other's poll questions NickFRS Forced Induction 0 05-01-2013 07:22 PM
