Old 03-15-2020, 08:09 PM   #1
jordanaintshittt
jordanaintshittt's Avatar
Drives: 99 Mx-5 13 FR-S 04 WRX
Won’t go into gears sometimes
So I got my clutch replace around August this last year and the clutch is a “ACT Heavy Duty Performance Clutch Kit” and I already broke the clutch in so it had more than 3k miles on it. I was maybe thinking of replacing the trans fluid or diff fluid even tho I had those fluids replaced when I got my clutch installed. Has anyone else dealt with this problem? My car is a 2013 FRS. Thanks.
jordanaintshittt is offline   Reply With Quote
Old 03-15-2020, 08:13 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
What kit?
I had nothing but problems with my ACT. Forged fork and pivot got rid of 70% of the problems. Went back to stock flywheel with Southbend stage 2.
Nothing to do with fluids.
Old 03-15-2020, 08:18 PM   #3
jordanaintshittt
This one
Old 03-15-2020, 11:47 PM   #4
No, I haven't had this problem.
But, if I did, the first thing I would do is to bleed the clutch system.
If that didn't fix it, I'd try adjusting the clutch.
Spuds (03-16-2020)
Old 03-16-2020, 01:27 AM   #5
AT-JeffT
Drives: 14 BRZ SWP
How many miles on the car?
AT-JeffT is offline   Reply With Quote
Old 03-16-2020, 01:39 AM   #6
jordanaintshittt
69,122 I believe
Old 03-16-2020, 03:26 AM   #7
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Had the same problem with my SB7-HDSS on my '13 FR-S. Was alright at first, but eventually I got locked out of all gears. Bled the system, replaced the slave -- nothing helped. I think ACT have some major QC issues.
Never was able to solve the issue.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
The Following User Says Thank You to dhuang For This Useful Post:
jordanaintshittt (03-16-2020)
Old 03-16-2020, 03:49 AM   #8
alan.chalkley
Drives: 4wd zooks
Is this more so when the car is cold?
Does it shift okay with double shuffling (a small blip of throttle in neutral between gear changes)?
alan.chalkley is offline   Reply With Quote
Old 03-16-2020, 03:58 AM   #9
jordanaintshittt
I’m not sure I just noticed that it’s been happening lately
Old 03-17-2020, 06:02 PM   #10
jordanaintshittt
@dhuang did you eventually change you’re clutch again?
Old 03-17-2020, 06:03 PM   #11
jordanaintshittt
@ should I get a forged fork and pivot?
Old 03-17-2020, 07:06 PM   #12
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
The more I see ACT clutches and issues along with it, makes me remember back in the 2010's when ACT clutches where avoided like the plague in the MR2 world. Seems like they are cutting corners again.
As for getting new forks and pivots, unless it's bent or beat to hell yeah you'll need it. Lucky it's not that expensive. But, if I was in your shoes I'll be looking at a new clutch.
Old 03-17-2020, 07:07 PM   #13
jordanaintshittt
Yeah you probably right
Old 03-21-2020, 05:45 AM   #14
dhuang
dhuang's Avatar
@jordanaintshittt, I had a Verus forged fork and pivot installed when I did my ACT clutch, but the problem still eventually developed and got worse with time -- made the car unenjoyable to drive.
The FR-S is now at some recycling center.
2017 Series.Yellow
2013 Whiteout
ElijahF (03-21-2020)
Even Gears rns294 Engine, Exhaust, Transmission 1 04-12-2017 10:52 AM
Any one have 5.29 gears yet ? ogie Oglethorpe Engine, Exhaust, Transmission 13 09-17-2016 12:17 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 01:48 AM
2nd gears a b*tch Carbon420 Scion FR-S / Toyota 86 GT86 General Forum 32 01-29-2013 06:09 PM
