Old 09-24-2014, 09:03 PM   #1
VIPER
Professional Test Driver
VIPER's Avatar
Drives: ’14 Monogram Hot Lava FR-S
Factory LED DRL Blink off when braking
If come to a medium to quick stop I notice that my LED Daytime running lights will blink off then back on. Anyone have a Scion 10 series, Monogram or Release series notice this?
I see it when parking in the garage at work before shifting into reverse and when stopping at a stoplight (reflection from the car in front of me)
I searched online and in the forum but did not see anything.
VIPER is offline   Reply With Quote
Old 09-24-2014, 09:18 PM   #2
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
I believe the DRL turn off when the car is not in gear (for manual) and when car is in P (for auto), and they are off when the e-brake is pulled.
aegisdrgn is offline   Reply With Quote
Old 09-24-2014, 09:41 PM   #3
VIPER
VIPER's Avatar
correct, however this is happening when the car is in gear and braking, seems to happen right when the car comes to a complete stop, then it blinks off then back on. It is an automatic.
Old 09-24-2014, 10:27 PM   #4
Loose wire someplace??????
Old 09-24-2014, 11:05 PM   #5
mabviper
Drives: WRB BRZ
I have a manual and this happens to me when I keep it in gear right before I stop completely. It usually happens when rpm dips below 400ish. Pay attention to your rpm when it happens.
mabviper is offline   Reply With Quote
The Following 4 Users Say Thank You to mabviper For This Useful Post:
Haeb (09-26-2014), PandaSPUR (04-12-2015), RobertPaulson (02-10-2015), VIPER (09-26-2014)
Old 09-24-2014, 11:07 PM   #6
navanodd
Drives: 2013 BRZ Sport-tech WRB
I've seen it happen to mine every now and then. Less so now that I had the ECU updated to the latest rev to fix the idle dip issue.
I don't think its anything to be concerned with, just a matter of the voltage dipping a little low when the alternator current drops off and the draw starts coming from the battery again. Its not as noticeable in other cars without LED DRLs because the voltage drop is very brief. Normal lights would just slightly dim whereas these LEDs flicker.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
VIPER (09-26-2014)
Old 09-25-2014, 12:28 AM   #7
Poodles
Drives: 2015 Series.Blue
No, they're on anytime you're out of Park (on an auto) or the e-brake is down (on a manual),and of course the car is on.
If they turned off when you're not in gear they'd be flashing all the time.
The flashing is from the idle going too low (also happens if you almost stall it on take off) and it's well known quirk of the BRZ. Nice of your guys to share the pain now too
Old 09-25-2014, 04:42 PM   #8
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
This happens in my car too. But mines related to the car coasting down to stop where the RPM drops too low and about to cut out engine before bouncing back up to regular rpm...
fantah is offline   Reply With Quote
The Following 3 Users Say Thank You to fantah For This Useful Post:
Muaddib (02-10-2015), Sportsguy83 (04-22-2015), VIPER (09-26-2014)
Old 09-26-2014, 08:51 PM   #9
VIPER
VIPER's Avatar
Thanks, that's what's happening on mine, it's when I notice the rpm drop. Good to know nothing to worry about.
Old 01-22-2015, 11:13 PM   #10
ray_viva
Drives: Scion FR-S
I have the same problem too on my FR-S it doesn't have the LED DRLs, but Everytime when I hit the brake the RPM drops and the DRLs shut off and come back on within a sec...
ray_viva is offline   Reply With Quote
The Following User Says Thank You to ray_viva For This Useful Post:
VIPER (04-06-2015)
Old 01-25-2015, 11:05 PM   #11
dpgfunk
Drives: 2012 E92 M3, 2013 BRZ
Same thing happens on my BRZ (automatic) - when i come to a stop, the RPMs dip and DRLs flicker. Took it to the dealership and of course they couldn't replicate it even with my specific description of when it happens...so they didn't do anything about it. Is the ECU flash an official fix for this that I could possibly refer them to?
dpgfunk is offline   Reply With Quote
The Following User Says Thank You to dpgfunk For This Useful Post:
VIPER (04-06-2015)
Old 02-09-2015, 05:15 AM   #12
eldevil
eldevil's Avatar
Drives: 2013 FR-S 10 Series 477 of 2500
i have a 10 series had the same problem this what i found
[IMG]file:///C:/Users/c7559/Downloads/IMG_0351.JPG[/IMG]
eldevil is offline   Reply With Quote
Old 02-09-2015, 09:50 PM   #13
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
To OP: Seems to be normal; if I let the RPMs drop too low (right before the engine stalls), the DRLs on my manual BRZ flicker off as well.
You'll need to upload an image to a hosting site like Imgur before you can link it.
Lelantas is offline   Reply With Quote
The Following User Says Thank You to Lelantas For This Useful Post:
VIPER (04-06-2015)
Old 02-10-2015, 07:04 AM   #14
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
This is normal. Subaru cheaped out on a couple of capacitors for those sensitive LED lights...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following User Says Thank You to DaJo For This Useful Post:
VIPER (04-06-2015)
AutoWindow 3 blink Tap-Turn Module schwartzki Exterior Parts (Aero, Lighting, Etc.) 1 08-13-2013 07:28 PM
GT86 front panel in the GT6 trailer, but for a blink moment yajin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-17-2013 01:43 AM
Is it possible to link the turn signal blink to the side marker on the BRZ? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 1 03-09-2013 03:03 PM
How to: Fixing hyper blink on LED turn signals Laika Cosmetic Modification (Interior/Exterior/Lighting) 0 01-20-2013 07:58 PM
F.S. Three blink...1 tap signal module BMWDavid Audio/Visual, Electronics, Infotainment, NAV 0 10-02-2012 03:37 PM
