Old 07-31-2015, 07:04 AM   #1
wbradley
Sarcastic SOB
wbradley's Avatar
Impeller touched slightly, possible cause cylinder damage?
When my supercharger ran dry and seized, the impeller touched and sheared off a small amount of metal. The particles probably would have been very fine. I am wondering if they could have etched the cylinder walls when going thru the intake tract. Or would they have settled in the huge HKS S type intercooler I am running?
I ran the engine probably 2.5 hours NA while waiting for a replacement HKS blower and it seems OK though not optimally tuned. Startup isn't as smooth and sounds like knock at initial crank but I'm not sure. Would the heavier 40 weight oil I am running have better suspended any trapped particles? I am not so worried that I'd have the pistons removed at this point and will pay attention to any suspect compression loss when I get a new blower in place. Should I maybe change the oil just to be safe?
Since a centrifugal blower runs like a turbocharger compressor, surely people have had turbo impeller touch in the past.
Anybody here with experience in this type of scenario?
Incidentally, if I remember correctly one of the features of the FAr0 engine is that the pistons can be removed just by opening the bottom of the engine (not sure how crankshaft is removed). I am hoping there is no functional damage.
Old 07-31-2015, 07:36 AM   #2
CSG Mike
CSG Mike's Avatar
Normally I'd say scope the cylinder but that's a bit difficult with the FA20...
Old 07-31-2015, 09:28 AM   #3
Bergen23
Drives: '15 Halo FR-S
Totalled
Bergen23 is offline   Reply With Quote
Old 07-31-2015, 09:31 AM   #4
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Change the oil, like you said. If you find the need to, maybe drop the oil pan and take a peek up in there and see if you can see anything. You might need to remove the oil pickup and some baffling to get a clear view.
How big was the chunk of metal?
Bobblehead is offline   Reply With Quote
Old 07-31-2015, 11:40 AM   #5
Sleepless
Drives: 2016 FR-S
Yes, I've had an engine ingest turbo impeller fragments. Engine required a rebuild.
Sorry man!
Sleepless is offline   Reply With Quote
Old 07-31-2015, 10:13 PM   #6
Well, back in the day, we would have run a compression check ....... that would have told us whether or not any piston compression rings were damaged or any valves were not closing all the way.
Of course it was easy then, just pop out the spark plugs, insert compresssion gauge in the spark plug holes and crank the engine over.......
Old 07-31-2015, 10:50 PM   #7
CSG Mike
CSG Mike's Avatar
It's not quite THAT easy with a Boxer.... but doable.
Old 07-31-2015, 11:52 PM   #8
Yep, kind of looks difficult .....
I reckon when my FR-S needs new plugs ...... I'll just trade it in for a new one .....
Old 08-01-2015, 12:06 AM   #9
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I've had engines swallow entire plug tips and survive with merely superficial markings on the pistons. I wouldn't say the engine is a total loss, by any means, but I would still inspect what I could just to verify.
Coheed is offline   Reply With Quote
Old 08-01-2015, 04:47 PM   #10
Poodles
Drives: 2015 Series.Blue
More likely to be stuck in the intercooler, so I think you're fine. But by all means, compression check would be the easy way to verify.
Old 08-01-2015, 04:57 PM   #11
Beat me to it, sir. Just look for any "significant" difference between the cylinders.
Old 08-01-2015, 05:00 PM   #12
Seems like the pieces could be shaken out, no? Shop vac with a little shaky shaky tap tap?
Old 08-01-2015, 05:13 PM   #13
wbradley
Sarcastic SOB
wbradley's Avatar
I'm going to bet that the massive intercooler I am using (HKS S Type, popular for Surpras) has some oil in the bottom from the original owner, in which case the metal particles will be trapped there forever.I am planning to install my replacement supercharger and keep my ears and butt focussed initially if I sense anything is off. I am concerned, but not enough to have the sparks removed to scope the cylinders unless something seems off. I wanted to see if someone would say thats a definite danger, I must have the engine opened up or else. Hopefully the fine particulate is in the intercooler or was fine enough that 40 weight oil trapped it and it eventually burnt up or passed below the piston rings to eventually get caught in the oil filter. Just hope it didn't badly score the rings/cylinder walls.
Old 08-01-2015, 07:53 PM   #14
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
bore scope or compression test first. if you have to lower the subframe and motor
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
HIC ROOF Spoiler$100/TRD REAR bumper rep$100/slightly bent Raven hood $100 VakaGT Exterior Parts (Aero, Lighting, Etc.) 16 07-11-2016 01:49 AM
SEIBON slightly damage hood clearence SOLD! Stav Canada Classifieds 9 11-27-2014 11:58 AM
WTB; Oem hood no damage, Front bumper, Fenders sokol Want-To-Buy Requests 0 10-10-2014 12:30 AM
GrimmSpeed Strut Bar, Master Cylinder Brace, Hood Struts and Pulley Cover BRZNutt Brakes, Suspension, Chassis 10 08-05-2014 01:05 AM
Selling slightly used SEIBON CARBON FIBER OEM HOOD. davidshu0327 Exterior Parts (Aero, Lighting, Etc.) 7 08-30-2013 01:05 AM
