Drives: 2015 FR-S - Halo
OEM Toe Arms Adjustable?
Are the OEM toe arms on the FRS adjustable? I'm getting an alignment done tomorrow and need to know if they can be adjusted
#3 |
Thank you. I don't suppose you know the amount of degrees it can be adjusted?
#4 |
A shit ton. Enough that the question sounds kind of weird. What exactly is your concern?
#5 |
Drives: FR-S Whiteout
Si
#6 |
Well... I ordered SPC lower arms and they came with toe adjustments. Just wondering if I should install the SPC toe adjustments or if the OEM ones will be suffice?
#7 | |
Drives: 2005 Toyota Camry
Considering you don't know what ride height you want your car to be at (see replies in your other thread in this subforum), you should first figure out what ride height you want the car to be at and whether or not there is sufficient toe adjustment to meet your needs. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Ultramaroon (06-04-2015) |
#8 |
Amount of toe correction isn't directly related to ride height, it's related to how much you're changing the camber via the LCA. The more you
That said, if the car is lowered a lot and you're dialing out a lot of camber, you'll probably run out of toe adjustment range.
| The Following User Says Thank You to wparsons For This Useful Post: | Ultramaroon (06-04-2015) |
#9 |
I love this forum and the learning process.
#10 | |
Figure out what ride height first, then figure out the rest. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | wparsons (06-04-2015) |
#11 |
So... got the alignment today and the tech stated that he has never seen toe off by that much before. I'm lowered about 2" on Tein Street Flex w/ SPC lower control arms. The tech stated that the OEM toe arms are really good and he was able to put everything in the green with room to spare so the toe bushings from SPC weren't needed. Hope this helps someone in the future.
#12 |
How much did you adjust the camber? That's what affects toe, not ride height.
| DIY: Whiteline Rear Adjustable Toe Arms | RallySport Direct | DIY (Do-It-Yourself) Guides | 1 | 07-10-2015 10:38 PM |
| Adjustable control arms and Toe arms | zumin | Brakes, Suspension, Chassis | 12 | 07-08-2015 07:54 AM |
| WTB: Adjustable Toe Arms | srizzors25 | Want-To-Buy Requests | 0 | 03-26-2015 02:12 PM |
| SPC Adjustable Toe Arms | Johnny_MA | Brakes, Suspension, Chassis | 1 | 07-29-2014 01:55 PM |
| SPL Adjustable Suspension Arms?? | Trmx2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 11-28-2013 02:22 AM |
