FT86Club Official Vendor
Drives: FR-S/BRZ
Introducing the NEO Motorsport Big Brake Kit
Hello Members,
We are from Toronto and we would love to share our products with you photo from scion.ca NEO BRAKE SYSTEM HIGHLIGHTS
NEO BRAKE CALIPER All NEO calipers are made from ultra-high strength forged 6061 alloy aluminum, the same material used in today NASCAR racecars. The ultra-light weight construction decreases unsprung mass while the increased rigidity allows both higher clamping force and incredibly consistent pedal response. It features differential bore pistons to optimize car control during heavy braking. External hydraulic pipe design keeps the brake fluid temperature low by utilizing air-flow technology to increase the efficiency in heat dissipation. The result is a significantly lowered operating temperature of the caliper and a more balanced brake pressure to ensure vehicle stability. NEO Brake Systems are designed to meet your heavy duty braking needs in both road and track applications. At NEO, we test our products thoroughly on the road and on the track to bring you the confidence you need in your everyday road driving. Two Piece Fixed Rotor Design
NEO BRAKE PADS NEO has developed a high performance pad to match the upgraded performance of the brake system. Our brake ceramic pads are made from organic materials that are environmentally friendly. The SILVER pads are designed for everyday use without the need to change your brake pads for weekend track use. Our GOLD race pads are full carbon ceramic. It provides aggressive braking power with low brake noise and dust level. Our friction material is a special composite that is designed for NEO’s specific purpose. Under the Japanese Industrial Standard testing, our silver and gold pads both achieve consistent 0.51mu; and 0.60mu; in operating temperature range up to 662 degree F. It is capable of sustaining a high coefficient of friction over a wide temperature range for all kinds of high performance road and track applications. Street Performance Pad Dyno Result Race Pad Dyno Result Product is used to compete in 2014 Canadian Touring Car Championship Series Big Brake Kit Clearance Table [12'/13' setup] Wheel Fitment Guide: For 12'(304mm) Clearance Enkei Racing Series: RPF1 Wheel Spec: 17x9 +35 *Note: More than 3mm clearance For 13'(330mm) Clearance Enkei Touring Series: Kojin, Tenjin, T6S, and the TSP6 Wheel Spec: 17x9 +45 Last edited by NEO Motorsport; 09-24-2014 at 04:09 PM. |
| The Following 3 Users Say Thank You to NEO Motorsport For This Useful Post: |
#2 |
So elite I'm 1338
Drives: WRB Subaru BRZ
![]() Shopping for brakes. Sprintkit is my #1 choice right now. Lets see where this goes.
-Jack Burton |
| The Following User Says Thank You to tahdizzle For This Useful Post: | ZionsWrath (09-15-2014) |
#3 |
What is the D# for the pads?
What happens to the pads at 1400 F (800 C)? What do replacement pads cost? Replacement rotor rings? Is this for the front and rear? Does it retain the parking brake? Is this brake kit free, or since I have to ask, I can't afford it? |
| The Following 3 Users Say Thank You to celica73 For This Useful Post: |
#4 |
Thanks
I already bought a sprint kit so I'm just in for the
![]() Interested in same questions above. Also interested in the proof behind "Improved Balance, Improved Brake Torque and Modulation"
#5 |
Drives: FR-S/BRZ
Hello Celia73
I am not exactly sure what you mean the D# for the pads? If you can explain it to us a liittle more, We can try our best to answer you. What happens to the pads at 1400 F (800 C)? At 800 C, the brake fluid in the car would have already boiled over since even the best of the brake fluids Motul RBF 660 can only withstand temperature up to 660 F which is 325 C. 800 degree is the absolute highest temperature any pads can exert before it becomes completely destroyed and deteriorate. Rotor on the other hand can reach 800 ~ 1200 C very frequently and require good ventilation to keep the temperature down. What do replacement pads cost? Replacement Street pads from NEO cost $160 a set for F300 and F400 series calipers while Replacement Racing pads are $240 a set. Alternative HAWKS, BREMBO, and AP pads can also be used in our caliper. Reference number is available upon request. Replacement rotor rings? Replacement rotor rings start at $378 a pair for 11.25" rotors. Is this for the front and rear? Does it retain the parking brake? Front and rear brake kits are available, and yes it retains the parking brake =) Is this brake kit free, or since I have to ask, I can't afford it? No, the kit is not free =) However, special discounts are given to board member as part of becoming a vendor on the forum, please PM us for a quote. Thank you! Alan@NEO. |
#6 | |
Something like on this list https://www.pegasusautoracing.com/do...ocID=TECH00057 It just lets us quickly cross reference to other manufacturers. |
#7 | |
Drives: FR-S/BRZ
NEO F301,F303,F401,F403 Interchangeable Pads - PFC (7767) - Pagid (1361) - Hawk (HB110) - Carbone Lorraine (5004W50) - Ferodo (FRP216) - Brembo (B52) - AP Racing (AP5200) - ACRE (RP002) pad thickness is 10mm for a 30mm thick rotor and 12mm for 28mm thick rotor and 14mm for a 26mm thick rotor. |
#8 | |
Drives: FR-S/BRZ
We will work on a comparison with a stock vehicle to demostrate the changes with an upgraded brake setup, please be patient with us for this demo. Thank you. |
#9 |
Drives: 2014 Toyota 86
Can you PM me the price for the kit? I was planning to jump on the sprint.. I would also like to know about wheel clearance vs the apracing sprint kit.. huge factor.. my big question, can you clearn 17x9 rpf1's with more than the few mm the sprint kit provides.
Also let us know weights please. |
#10 | |
Drives: 2013 Firestorm FRS
#11 |
Drives: FR-S/BRZ
More Detail:
13'(330mm) Rotor 4 Piston Setup
#12 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | CSG Mike (09-16-2014) |
#13 | |
Site Moderator
Drives: Stuff
-Dave
#14 | |
Site Moderator
Drives: Stuff
Not exactly what he was asking. My rotors (and pads) see temps north of 1,000 degrees often. The caliper bodies see 300-600 degrees. Fluid is around there. Some pads melt at 1,000 degrees, some at 1,200, some at 1,400, etc. He's asking what the temp range is for your racing pads.
-Dave
| NEO Motorsport Big Brake Kit | NEO Motorsport | Brakes, Suspension, Chassis | 2 | 09-23-2014 05:56 PM |
| Introducing myself! | czechm8 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 04-05-2014 11:02 PM |
| Introducing myself | fz6r | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 02-14-2014 02:54 PM |
| Introducing myself and my FRS | Apes Six | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-12-2013 04:51 AM |
| Introducing: AP Racing Six Piston, 14 inch Formula Road Brake Kit | JRitt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 01-23-2013 05:18 PM |
