| Member's Car Journals Car journals by our members. |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
The reason I'm always broke - Dustin's Supercharged 86
After waiting what seemed like an eternity I finally got my car. I made a 573 mile trip to Nebraska to pick up the FRS I want. Yes the trip was a bit excessive but it was good fun.
![]() ![]() Engine/Transmission/Drivetrain Installed Delicious Tuned Innovate Supercharger Stage 2 w/ intercooler - 285 whp 219 lb/ft tq Installed Raceseng 70mm supercharger pulley Installed Nameless Performance long tube EL header Installed Nameless Performance 3" OP/FP combo Installed Nameless Performance 3" Mid pipe Installed Nameless Performance 3" Axle back Installed ACT Clutch and Flywheel Installed MTEC Stainless steel braided clutch line Installed Full Blown Radiator/Fan Shroud combo with SPAL fans Installed Weir Performance 4.56 Ring and Pinion Installed Tomei 2 Way Limited Slip Differential Installed Aluminum Carrier Bushings - my design Installed Forcedfab Transmission mount stiffener modified to fit Whiteline bushing Planned TRD Short Shift Kit Planned 1 Piece Aluminum Driveshaft Planned K&N drop in Planned Oil Cooler Planned Fully built motor and a Sprintex 335 blower when I get bored with what I have now Suspension Installed H&R Super Sport Lowering Spring Installed Nameless Performance Lateral Bars Installed Perrin Steering Rack Lockdowns Planned Nameless Performance Strut Tower Bar Planned Ohlins Coilovers w/ Extended Tophats Planned RacerX Suspension components Planned Caged when the kids no longer fit in the back seat Exterior Installed Subaru Outback Fog Lights with OEM bezels and PIAA yellow lights Installed Front and Rear Toyota Badges and removed FRS badge Installed JDM Style clear side markers Installed Beat Sonic Shark Fin antenna Installed Resprayed tails with VHT Red spray paint Installed 18" RH Evolution C2's wheels Installed 35% Tint on the front and 5% on the back Planned VIS AMS Carbon Fiber Vented Hood Planned VIS AMS Carbon Fiber Trunk Planned TRD Lip Kit Planned Buddyclub Tail Lights Planned JDM Head Lights Planned Different wheels - undecided Interior Installed Toyota Tundra headlight/fog light stalk Installed 7th Gen Celica GTS Throttle Pedal Installed Cusco Spin Turn Knob Planned Rear seat delete when kids no longer fit Planned Bride Seats Planned Weighted Shift Knob Planned JDM Knee Pads Planned BRZ Shift Boot 02/18/13 - Purchased Whiteout FRS #661 ![]() Page 1 02/23/13 - Rebadged exterior and removed FRS emblem 02/25/13 - 35% tint on front windows and 5% on back 02/26/13 - Sprayed tail lights Page 2 02/27/13 - Rebadged key 04/10/13 - Lowered on H&R Super Sport springs 04/24/13 - Busted my AC condensor so replaced with new OEM unit 06/01/13 - BWR license plate hardware kit 06/29/13 - 18" RH Evolution C2's Page 3 08/31/13 - Installed Whiteline Positive Shift Kit and received Weir Performance 4.56 Ring and Pinion gear set ![]() 09/03/13 - Installed modified ForcedFab transmission mount stiffener Page 4 12/09/13 - Received Tomei 2 Way LSD 12/21/13 - Removed 3rd member from car and removed factory differential and ring gear. Installed Weir Performance ring gear on Tomei 2 way My 6 year old son being my helper ![]() 12/25/13 - Received Nameless Performance 3" catted and resonated overpipe/downpipe combo and fog lights ![]() 01/04/14 - Started designing carrier bushing ![]() 01/10/14 - @Rue & Boston Mike (not on this forum) machined my bushing inserts out of 1" 304 stainless round bar. 01/11/14 - Installed Toyota Tundra stalk for fog lights. Page 5 01/24/14 - @Rue & Boston Mike finished machining and installed the aluminum carrier bushings with stainless steel inserts. ![]() 01/25/14 - Installed carrier with Tomei 2 way, Weir Performance 4.56 ring and pinion, and aluminum carrier bushings, my design, made by @Rue and Boston Mike. ![]() 01/25/14 - Installed fog lights and 7th gen Celica GTS throttle pedal installed for better heel/toe. 01/26/14 - Installed Cusco spin turn knob that I got as a freebie. Page 6 02/14/14 - Received Innovate Stg 2 supercharger ![]() 02/22/14 - Received Raceseng 70mm pulley 02/24/14 - Received ACT clutch and flywheel & MTEC clutch line. 03/11/14 - Received Nameless header ![]() 03/14/14 - Received FBM radiator/fan shroud combo ![]() Page 7 03/18/14 - Installed Nameless header and Nameless OP/FP combo 03/29/14 - Installed FBM radiator/fan shroud combo. 04/09/14 - Received & installed Nameless 3" mid pipe and axle back and Nameless lateral bars ![]() 04/09/14 - Received Nameless intake for the Innovate supercharger - no longer installed 04/22/14 - Purchased tune from Delicious Tuning Page 8 04/25/13 - Supercharger manifold machined, got Honda MAP sensor, and MAP sensor/IAT sensor plate designed by my brother. ![]() 04/26/14 - Installed ACT clutch and flywheel and MTEC clutch line. 04/28/14 - Received EcuTek software with Delicious tune. 04/30/14 - Ordered GM open element IAT sensor 05/01/14 - New IAT/MAP sensor plate finished by @Rue ![]() ![]() 05/03/14 - Installed Innovate supercharger with Raceseng 70mm pulley, Nameless intake tube, and all running with a tune from Delicious Tuning. ![]() Page 9 05/12/14 - Installed Beat Sonic shark fin antenna 06/24/14 - Dyno'd 285whp & 219 lb/ft torque ![]() Page 10 08/09/14 - Received Perrin Steering Rack Lockdowns 10/04/14 - Installed Perrin Steering Rack Lockdowns To Do List Oil Cooler Ohlins coil overs RacerX suspension components And lots more....... Plenty more pics to come!! Last edited by Dustin; 10-04-2014 at 02:57 PM. Reason: Updated |
#2 |
Drives: Scion FR-S Whiteout
Congratulations on your purchase! At least you'll be able to get some miles in and get closer to that break in period lol. I am also awaiting my frs, can't wait!
#3 |
__(X)__
Drives: '11 Legacy, '89 190E, '78 GS1000
Fellow Dustin and FR-S owner here
Welcome to the club!
#4 | |
Twin Screw You
Thanks Dustin!! Last edited by Dustin; 12-03-2013 at 04:53 PM. |
#5 |
Twin Screw You
My brother made the trip with me. He's one of the reasons I'm getting this car. He has owned an original AE86 for going on close to a decade and he's pretty stoked I'm getting this. If I didn't trade in a car on the FR-S, I would've made the cruise in his Levin.
| The Following 4 Users Say Thank You to Dustin For This Useful Post: |
#6 |
Drives: 2013 SWP BRZ Ltd. / E60 M5
Congrats on reaching the big day and enjoy the ride home!
#7 |
Congrats man! Your brother's car is siiiiiick!!!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#8 |
Dirt Trackin'
Drives: '13 Raven FR-S MT
Mmmm blacktop... Good luck! Hope you like it.
#9 |
Drives: 2013 Whiteout Scion FR-S 6MT
Congrats man! I actually looked and considered that exact car but I just went and ordered a new one at the Scion dealership in Omaha.
#10 |
where are the new pics!?!?!?!? Congrats! Just picked mine up last week! Beyond happy with my purchase!
#11 |
Twin Screw You
My camera battery was dead before I left. And to be honest, all day yesterday was me catching up on sleep. I was up pretty much he whole 23 hours of the trip going off of about 5 hours of sleep from the night before. I'll try to get some pics today.
#12 |
Twin Screw You
It's been raining today so no pics. But I did pick something up for it today. Nothing big but then again I won't be getting anything big for it for a while. I'll try to have it done by this weekend when the weather is better.
#13 |
Twin Screw You
I did take one pic today. A little hazy but eh..........whatever.
#14 |
Drives: SWP Subaru BRZ
Where did you pick it up in Nebraska, curious lol. At least you made it home before the snow storm that is about to ravage us here in Nebraska.
| BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 07:18 PM |
| step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 11:44 AM |
| [StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 12:38 PM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 12:27 PM |
