Old 07-14-2017, 07:21 PM   #1
FirstWinter
Drives: Car
FirstWinter is offline   Reply With Quote
Old 07-14-2017, 07:33 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Pull the endlink out and flip it around inside the LCA which should straighten it more vertical. Whether it's offset or there's a spacer or something, you should be able to shift the bottom part in the LCA so that it's located more ideally. Yeah the sway bar will be at an angle but that's better than metal on metal contact limiting your suspension travel.
ineedyourdiddly
FS: Whiteline Rear Endlinks, Asidrive Brakes, Suspension, Chassis 4 06-25-2017 02:45 PM
Wtb oem lca and rear endlinks bjun Want-To-Buy Requests 4 02-14-2017 03:11 AM
WTB OEM Exhaust and rear endlinks Blood New England 1 02-01-2017 07:38 PM
Safe to jack car from rear diff (while potentially touching the cover)? bloomy116 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 05-30-2014 12:18 AM
