Old 12-10-2014, 11:20 AM   #1
Atticus808
Atticus808's Avatar
Drives: Splash Mountain
IPhone 6 Data draining
anyone else have this problem?
I got it end of November and got on a plan with 3 GB
My data got used up quickly and a quick google search told me to turn off the Background App Refresh, which i did.
Now i'm 9 days in to December and i just got a message saying i used up 75% of the data.
wtf?
any other suggestions?
Atticus808 is offline   Reply With Quote
Old 12-10-2014, 11:32 AM   #2
53Driver
T64-416Ax3=13,140shp
53Driver's Avatar
Drives: 2002 AP1 and 2015 F-150 EB (DD)
wtf?
Do you have it set to use WiFi hotspots when available? If not, that could be a big part of the issue. Are you streaming a lot of videos and music? I have a 5C and my plan is a paltry 500GB, I have to be very careful what I do, but I survive because I make sure to use WiFi when browsing or downloading stuff.
53Driver is offline   Reply With Quote
The Following User Says Thank You to 53Driver For This Useful Post:
Atticus808 (12-10-2014)
Old 12-10-2014, 11:43 AM   #3
Atticus808
Atticus808's Avatar
yeah i have wifi at home and at work (although i just recently starting using the work one).
but when i had 2 GB with my iphone 4 i only went over 2 GB once in 2 years.
so i have no idea. i turned off a bunch of the obvious data usage ones, but i'm wondering if there's something i'm missing
Old 12-10-2014, 11:50 AM   #4
53Driver
53Driver's Avatar
Well, something isn't adding up. Unless you were streaming a lot of music/videos/etc you shouldn't be blowing through 3 gigs. My plan used to be 2 gigs and I never got close to exceeding that. Now, my 500 MB plan does suck...
Old 12-10-2014, 12:13 PM   #5
Atticus808
Atticus808's Avatar
exactly.
i have no idea, i'm gonna check on it once in awhile in the nexr couple of days.
no way i can burn through over 2000 MB in 9 days, especially when i'm on wifi a lot of the time
Old 12-10-2014, 01:46 PM   #6
Ramster
Ramster's Avatar
Drives: Subaru BRZ Limited
Could be you downloaded some data in the background, like Spotify for example where they let you download a playlist for use offline.
Or you downloaded/updated your apps using cellular data.
Ramster is offline   Reply With Quote
The Following User Says Thank You to Ramster For This Useful Post:
Old 12-10-2014, 01:56 PM   #7
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
There's a huge difference between the 3G you were using before and LTE, since you're able to consume content so much more quickly you're going to be using more data.
I find that when I first get a new phone I crush my data for the first month or two while I'm trying new things and downloading new apps, then it usually goes back to normal.
Anything you used before for streaming, spotify, youtube and stuff like that will use a higher quality stream since you have more bandwidth available. Same goes for things like facetime or automatic uploads of (now higher quality) pics to instagram and apps like that.
Also check "automatic update" in your app store, if that's enabled it could be updating apps without you knowing over cellular.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following 2 Users Say Thank You to f0rge For This Useful Post:
53Driver (12-10-2014), Atticus808 (12-10-2014)
Old 12-10-2014, 02:11 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
My droid phone has a data usage app that tells you exactly what app is using what amount of data.
I would be surprised to hear the iPhone does not have a similar app.
The Following 2 Users Say Thank You to stugray For This Useful Post:
Atticus808 (12-10-2014), strat61caster (12-10-2014)
Old 12-10-2014, 02:16 PM   #9
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
iMessage and Siri both use data as well. If you're sending a bunch of pictures that may be the culprit. This is exactly why I stuck with T-Mobile. I'll deal with the spotty service as long as I never have to worry about my data usage. Not to mention I'm always around the city so coverage isn't an issue.
MokSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to MokSpeed For This Useful Post:
Atticus808 (12-10-2014), Ramster (12-10-2014)
Old 12-10-2014, 02:17 PM   #10
Atticus808
Atticus808's Avatar
hm, that could be it. a Chris Harris video here and there probably drained the crap out of it, where as it didn't when i had 3G
Old 12-10-2014, 02:40 PM   #11
53Driver
53Driver's Avatar
f0rge makes some great points and I didn't even think about the LTE vs 3G thing. In fact, because my data plan is so small right now, I actually turned my LTE ability off per the recommendation of Verizon so I'm using 3G instead of LTE intentionally. And yes, turn off automatic upload/update feature immediately if you haven't done so. Mine is set to only update when I'm in a WiFi spot.
Exactly and I plan on switching to T-Mobile when I can. Right now my dad is on my account so to big of a pain to try and switch carriers.
Old 12-10-2014, 03:44 PM   #12
Atticus808
Atticus808's Avatar
good info everyone!
thanks a lot.
better to ask tech questions in here instead of the chat option for Rogers
The Following User Says Thank You to Atticus808 For This Useful Post:
Ramster (12-11-2014)
Old 12-10-2014, 07:29 PM   #13
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
In most cases for me, its things like auto syncing or apps that check every few minutes (email). For me what I generally do, is turn off data unless I want to use it.
GhostRai is offline   Reply With Quote
Old 12-11-2014, 02:27 PM   #14
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
Don't recall if iPhone can do this but androids can check the data consumption of each app. That would help lots
JERM^ is offline   Reply With Quote
OFT Data log.. Are these okay HSayaovong Software Tuning 2 03-25-2014 07:56 PM
K&C data Gunman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-03-2013 02:11 PM
Fexible data cable to mount iphone or android in car speedy racer Electronics | Audio | NAV | Infotainment 3 05-23-2013 10:37 AM
iPhone track data logger app? Wonderbar Tracking / Autocross / HPDE / Drifting 14 05-07-2013 04:31 PM
Sink draining sound kgc Issues | Warranty | Recalls / TSB 5 08-17-2012 02:06 PM
