Old 01-08-2014, 12:00 PM   #1
mikes603
mikes603's Avatar
Drives: 2012 FRS
Tire Temperature System
Hey FT,
I'm an EE and I've been developing this kit for my own car. It's to know when your tires are up to operating temp. Is this something anyone else would be interested in?
Here are the features of the kit:
  • Four IR sensors
  • Narrow 10deg sensor field of view for sampling tire sections
  • Large 1 1/12 by 2 1/2 inch display
  • Weather resistant; sensors can get wet without being ruined.
  • Removable lens cap if they need cleaning or replacement
  • Extra protective lenses
  • Does both fahrenheit and celsius
  • You can adjust the emissivity of each sensor (different materials reflect light at differing rates)
  • Quality harnesses
  • DC supply is designed for difficult automotive environments with large current dumps and voltage spikes
The installation is straight forward. You drill a small hole in the wheel arch liner for the sensor to poke through. Top center is best to account for changes in tire angle.
If anyone is interested just send me a PM or email me at mikes at ntisys.com
mikes603 is offline   Reply With Quote
The Following User Says Thank You to mikes603 For This Useful Post:
SirBrass (01-09-2014)
Old 01-08-2014, 12:43 PM   #2
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Not bad. My previous car, Cobalt SS turbocharged, had a feature similar to this built in. However, my annoyance with it was that I had to reprogram it every time I rotated my tires. It was a PITA. I take it this system will require the same?
Eurasianman is offline   Reply With Quote
Old 01-08-2014, 01:35 PM   #3
d1ck
Drives: Black 2013 FRS
These appear to measure the surface temp of the tires with a sensor mounted in the wheel well, so no.
d1ck is offline   Reply With Quote
Old 01-08-2014, 01:39 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
Excellent idea! I thought of this years ago.
My idea was to use a linear line scanning sensor.
As the wheel rotated, you could get a complete temperature map of the entire tire.
This would be extremely helpful setting up your suspension at the track.
Now F1 is using the exact system. You can even see the techs watching the tire temperature maps while racing.
You can see if the suspension is setup wrong, if a tire is failing, or if you flat spot a tire.
The Following User Says Thank You to stugray For This Useful Post:
Old 01-08-2014, 01:41 PM   #5
stugray
How many sensors could your system support?
Maybe three per tire?
Can it log data? If so, for how long?
What did you use as a microcontroller?
JohnJuan (10-03-2014)
Old 01-08-2014, 04:50 PM   #6
robot
There are now 2 carseats!
A few years ago on iwsti there was some discussion of making a system that had an array of sensors and told you if you had the correct camber settings for a given situation.
robot is offline   Reply With Quote
Old 01-09-2014, 12:30 AM   #7
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Are there plans for Inner, Middle, and Outer temps?
phastafrican is offline   Reply With Quote
Old 01-09-2014, 09:05 AM   #8
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
price?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 01-09-2014, 07:52 PM   #9
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
i'd love a system that did this plus real time PSIs.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following User Says Thank You to ultra For This Useful Post:
Old 01-09-2014, 07:57 PM   #10
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
10x more useful to us than the generally useless TPMS.
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
wparsons (06-16-2014)
Old 01-12-2014, 07:03 PM   #11
icemang17
Drives: Scion FR-S/ Subaru BRZ
IR tire temps aren't really that accurate.....the correct way is with a probe just under the surface of the tire...that gives a much more accurate reading than the surface via IR that can be much different than a probe reading...this is why all top teams use probe testers....
Sure its better than nothing, but distracting the driver with more data isn't neccesarily a good idea either.... Getting accurate tire temps and hot PSI is an excellent tuning tool to help you find the last little bit of performance out of your setup....it also shows weaknesses in your setup-driving style as well....
icemang17 is offline   Reply With Quote
Old 01-12-2014, 08:22 PM   #12
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I would love that! Please let us know if you're trying to sell your concept.
PoorMansRacing is offline   Reply With Quote
Old 01-14-2014, 01:42 PM   #13
mikes603
mikes603's Avatar
Drives: 2012 FRS
I have the 4 sensor kit for sale, send me an email (mikes at ntisys.com) and I can give you a quote for however long you need your harnesses.
A 3 sensor per corner, that does inner center and outer contact patches, should be available soon. I'm also working on CAN bus/network support, but that's a few months off.
Old 01-16-2014, 12:16 PM   #14
Totality
Drives: gt-86
Multiple sensors per tire and logging would make it a useful suspension set-up tool. Pricing will determine if it is practicle or just a curiosity.
Totality is offline   Reply With Quote
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 09:55 AM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 01:54 PM
Intake Air Temperature sw20kosh Forced Induction 18 06-19-2013 05:49 PM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 11:05 AM
Engine temperature Skye Issues | Warranty | Recalls / TSB 5 08-09-2012 11:33 PM
