Old 07-15-2014, 05:54 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Battery Acid Problem
So I have noticed that my battery forms a lot of acid but after checking today it seems to have escalated to a whole new level. Does anyone know how to prevent this or why this is happening? Also why is the color red now instead of the normal greenish acid formations?
My mods that are drawing from the battery include:
- Escort 9500ix radar detector
- Dashcam
- LED DRL strips (where fog lights are)
- OEM Audio+ Reference
- plug and play HIDs
Could these mods be drawing too much power?
Thanks.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-15-2014, 08:52 PM   #2
l0aded
Addicted
l0aded's Avatar
I cleaned it and greased it to temporarily fix it. Still not sure why it's leaking red lead acid though.
Old 07-15-2014, 09:09 PM   #3
wheelhaus
wheelhaus's Avatar
Damn that's a new one for me, I've never had a battery grenade like that, especially red...must be a defect... Might be able to warranty, or go Optima and fuggedaboutit...
Edit, as far as amp draw, I don't think that's an issue or you'd be popping fuses or seeing a dead battery frequently.
Old 07-15-2014, 09:26 PM   #4
celica73
The red is anti-corrosion spray, not battery acid. Unfortunately, in your case, it isn't working. I have the same red stuff on my car that is all stock, and it's been like that since brand new.
The Following User Says Thank You to celica73 For This Useful Post:
wheelhaus (07-15-2014)
Old 07-16-2014, 04:18 AM   #5
l0aded
Addicted
l0aded's Avatar
Anti-corrosion spray? Can you explain? It wasn't like this before and I'm assuming they came out of the posts since the posts were covered in them.
Old 07-16-2014, 04:22 AM   #6
l0aded
Addicted
l0aded's Avatar
Do you think the dealers will honor any warranties since I have mods that draw current from the battery?
Old 07-16-2014, 04:23 AM   #7
extrashaky
Drives: 2014 BRZ Limited
I was also thinking the red stuff is anti-corrosion spray. Do you have the car serviced at the dealer? They probably saw your corrosion and sprayed it on there. It looks like they sprayed it on top of the corrosion without actually cleaning it first, which is just stupid.
The crud on the terminal is not exactly acid. It's corrosion. It's formed when acid fumes from the battery react with the lead in the terminal. The crud is not conductive, so it will cause voltage problems that can grow more crud.
To clean it off, use baking soda and water with a wire brush or old toothbrush. Degreaser doesn't really do the job; you need the baking soda to neutralize the acid in the corrosion to stop the chemical process. Try to get it spotless and rinse it thoroughly, then hit it with a corrosion inhibitor. You can buy that red stuff at auto parts stores. A lot of the Jeep guys coat their terminals in Ox-Gard from Lowe's instead to keep the fumes from reaching the metal.
As for the cause? You might have an electrical problem, or you might just have a shitty battery. Try cleaning and protecting the terminals and see where that gets you.
The Following User Says Thank You to extrashaky For This Useful Post:
l0aded (07-17-2014)
Old 07-16-2014, 04:47 AM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
The red is battery terminal spray. You're supposed to spray it on the post (under the terminal) and not on the actual terminal.
Usually this happens on the POSITIVE side so I would pop that side off as well and check under there.
If you clean it and it comes back at an alarming rate, check the battery for leaks. On my Corolla (rarely driven), the positive side kept getting corroded at a really fast pace. Every 3 days I would need to clean it again. I bought the spray and sprayed it on (just like in your case).
What I found out was that the seal between the post (positive side) had failed, the post CAME OUT OF THE BATTERY. The corrosion was so bad I had to replace the ENTIRE positive side because it welded the terminal to the post.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
l0aded (07-17-2014)
Old 07-16-2014, 11:13 AM   #9
wheelhaus
wheelhaus's Avatar
It's worth a shot, it's so common for people to install mods like yours that it's certainly not causing it so they would be real ****s to not replace it for you. Did you have the car serviced somewhere where they would have sprayed it for you?
Old 07-16-2014, 11:43 AM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Which they are 99% of the time...
Old 07-16-2014, 03:14 PM   #11
steve99
Drives: FT86
I reckon your on the money.
Reckon that battery is cracked or leaking near that terminal or the apprentice at the dealer has overfilled the electrolyte and its leaking. Check the levels
Old 07-17-2014, 05:24 AM   #12
l0aded
Addicted
l0aded's Avatar
Only had my car serviced at dealer so far since it has been free. I have not checked it since my last oil change last month so it is very likely that it is the spray you speak of. The red (positive) terminal is covered with it as well so makes sense. Thanks for helping me make sense of it.
Old 07-17-2014, 05:25 AM   #13
l0aded
Addicted
l0aded's Avatar
You are correct sir, positive terminal is completely coated in red. Thanks for the help.
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
battery jkr Engine, Exhaust, Transmission 1 04-11-2013 02:03 PM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 11:05 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
