Old 03-26-2014, 04:05 PM   #1
andrew20195
Drives: 2013 Subaru BRZ
PSA: New ECM file available for idle dip/extended crank time
Came out today for Subaru. It's a TSB not a recall. Bulletin number 11-136-14. Subaru believes the issue is related to a/c compressor cycling.
andrew20195 is offline   Reply With Quote
The Following 3 Users Say Thank You to andrew20195 For This Useful Post:
codesplice (03-26-2014), Slysdexia (05-14-2014), XanRules (03-26-2014)
Old 03-26-2014, 04:06 PM   #2
NickFRS
Drives: 2013 Asphalt FRS
So a new flash?
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 03-26-2014, 04:14 PM   #3
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Originally Posted by NickFRS View Post
So a new flash?
How else would you write it? Osmosis?
Old 03-26-2014, 04:19 PM   #4
NickFRS
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
The Following 2 Users Say Thank You to NickFRS For This Useful Post:
SkAsphalt (08-15-2014), SloS14 (03-26-2014)
Old 03-26-2014, 04:21 PM   #5
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I like to use a pencil in case I want to change it later.
Thanks for the headsup though @andrew20195 - I haven't encountered an idle issue yet, but I've been reading quite a bit about it. Good to know they've got a (suggested) solution.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 03-26-2014, 05:13 PM   #6
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Can we get a PDF copy of this TSB, as well as, get it added here: http://www.ft86club.com/forums/showthread.php?t=21868 ?
Eurasianman is offline   Reply With Quote
Old 05-14-2014, 10:39 AM   #7
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
That lines up perfectly with the idle dips I've been having. With AC on, coming to a stop after engine braking, it seems to not expect the AC to kick on so when it does the idle will dip, occasionally requiring the ECU to slam the spark advance to full, leading to some momentary spark knock. I do note that if I blip the throttle, it stays in elevated idle long enough to come to a stop and not do it until I've been sitting stopped for a bit.
I also note that the tach seems to go into a different mode during these. The idle will dip and the tach will lag, then move to a twitchier, faster mode before settling back down once idle speed has stabilized.
No AC means no dip, but I live in GA, so that's not often an option.
Think I'll head to my dealer.
Slysdexia is offline   Reply With Quote
Old 05-14-2014, 11:07 AM   #8
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
TSB PDF will be helpful.
if i didnt get my OFT, i probably went dealer to reflash
Old 05-14-2014, 01:48 PM   #9
Eurasianman
Chief
Contemplating if I should bother with the TSB even though I have not had any issues with the car since I bought it (September 2012). Almost have 17,000 miles on it and no lights. The idle has dipped on me, but, at least to me, has not seemed severe enough to take it in and have it looked at.
Old 05-14-2014, 01:55 PM   #10
OrbitalEllipses
Drives: Attitude
Had it done, still dip to ~400 RPM.
zc06_kisstherain (05-14-2014)
Old 05-14-2014, 02:24 PM   #11
dsgerbc
Drives: BRZ(sold), STI
It has been posted in the TSBs thread ages ago.
Old 05-14-2014, 02:47 PM   #12
zc06_kisstherain
Drives: SWP BRZ
I thought newer than that old one. lol
Old 08-14-2014, 11:06 PM   #13
Dboe
Drives: 2013 Red FRS
Has anyone actually tried re-flashing already?
I have an openflash and have a different map on it, so it should have already fixed it. However, i notice this issue everytime.
Dboe is offline   Reply With Quote
Old 08-15-2014, 06:29 PM   #14
themajesticone
themajesticone's Avatar
Drives: '13 UM86
OFT is offering the B series maps. have had it for a couple weeks now - it is working well.
themajesticone is offline   Reply With Quote
Perrin Crank Pulley Install (time lapse vid) ninjasaurusrex DIY (Do-It-Yourself) Guides 0 03-12-2014 02:42 AM
File Repository? rupert Site Announcements / Questions / Issues 1 01-08-2014 04:46 PM
GT 86 Logo in PSD file format avig FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 10-01-2013 02:12 PM
usb mp4 file format wrohdejr Electronics | Audio | NAV | Infotainment 1 04-16-2013 08:19 PM
