Old 03-07-2014, 02:52 AM   #1
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
'14 BRZ Ltd. - Rough Idle
Hey all,
My super duper stock BRZ Limited (2014) has been idling a bit rough. The revs aren't bouncing all over the place, but the engine just doesn't feel like she's running phenomenally smooth - is anyone else running into this problem?
Not sure if I need to make the trip to the dealer to get it looked at!
Edit: I'm asking because with my last '13 FR-S I don't ever recall having it like that, then again I was on an OFT flash for a while too...
Thanks,
David
leicaboss is offline   Reply With Quote
The Following User Says Thank You to leicaboss For This Useful Post:
ZionsWrath (05-20-2014)
Old 03-07-2014, 10:42 PM   #2
tv4184
Drives: FD / IS300 / V8 4Runner
Is it throwing a CEL?
Current: 2018 Tesla Model 3 // 2007 4Runner V8 // 2004 IS300 5MT // 1994 RX7 5MT
SOLD: 1999 4Runner 5MT // 2018 FK8 CTR // 2007 TSX // 2007 RS4 // 1993 Accord 5MT // 2004 S2000
tv4184 is offline   Reply With Quote
The Following User Says Thank You to tv4184 For This Useful Post:
Old 03-07-2014, 11:04 PM   #3
FRSure
Drives: Toyota
Because its super new, your dealer might have put in 87 octane gas by accident. Burn the whole tank and fill up some 93 shell v power.
FRSure is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSure For This Useful Post:
mav1178 (03-08-2014), ZionsWrath (05-20-2014)
Old 03-07-2014, 11:18 PM   #4
Drive
Crickets...
Drive's Avatar
Drives: FR-S 10 Series
Originally Posted by FRSure View Post
Because its super new, your dealer might have put in 87 octane gas because they are cheap. Burn the whole tank and fill up some 93 shell v power.
Fixed that for you.
Smile on every turn.
Drive is offline   Reply With Quote
The Following 3 Users Say Thank You to Drive For This Useful Post:
FRSure (03-07-2014), M-17 (03-10-2014), ZionsWrath (05-20-2014)
Old 03-07-2014, 11:22 PM   #5
leicaboss
Coffee Snob
leicaboss's Avatar
Oh shoot that's a great point. No CEL and not as rough as my FR-S was with the ECU issue. I suspect the gas issue may be the problem. Sigh what the hell...
Old 03-07-2014, 11:33 PM   #6
FRSure
Drives: Toyota
Originally Posted by Drive View Post
Fixed that for you.
I don't get dealers sometime. They make big bucks, and they can't afford a extra $4 on gas.
The Following User Says Thank You to FRSure For This Useful Post:
Old 03-07-2014, 11:34 PM   #7
Drive
Crickets...
Drive's Avatar
I believe their mentality is something along these lines:
It's not my car, so why should I care? I'll cut corners and save what I can.
The Following User Says Thank You to Drive For This Useful Post:
Old 03-08-2014, 01:58 AM   #8
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
You'll understand the day you need to hit revenue and margin goals in your line of work.
-alex
Old 03-09-2014, 01:21 AM   #9
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Mine seems to have the same problem at times, ive tried a few different top tier premium fuels and it hasn't changed anything.
BRZZZZZZZZZZ is offline   Reply With Quote
The Following User Says Thank You to BRZZZZZZZZZZ For This Useful Post:
Old 03-09-2014, 06:10 PM   #10
Ozzman
Drives: old
Mine always runs better after a good flogging.
Ozzman is offline   Reply With Quote
The Following User Says Thank You to Ozzman For This Useful Post:
Old 03-09-2014, 06:26 PM   #11
extrashaky
Drives: 2014 BRZ Limited
I have 5000 miles on my '14, and it's doing something similar. It seems to run fine at cruise, and it's not so rough at idle that it quits. I figured I would just keep an eye on it for a while and take it in if it got any worse, but for now it doesn't seem to be affecting driving performance.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
leicaboss (03-10-2014), ZionsWrath (05-20-2014)
Old 03-10-2014, 08:12 PM   #12
swpbrz
Drives: swp brz limited
I've got a brand new 14. That does funny idle things too. If I come to an abrupt stop from high speed it dips to 500 and gives a bad rattle. It Also randomly dips to 500 at stopped idle. It seems to be caused by gas brand. So far first tank from dealer was great but in California we don't have ethanol free gas and my first fill up gave me crickets and the stutter in idle. Shell seems better for stutter but worse for crickets then Chevron.
swpbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to swpbrz For This Useful Post:
Old 03-10-2014, 08:31 PM   #13
leicaboss
Coffee Snob
leicaboss's Avatar
Glad to know I'm not the only one then - my car's a 01/2014 produced car (you can see your month by looking at the sticker between the driver's door and the chassis. It's not AS rough as the FR-S problem I had before which was way more sever and felt like the car was gonna stall, but this one is still unsettling nevertheless.
Old 03-11-2014, 12:30 AM   #14
extrashaky
I learned to drive in my dad's 1970 MGB that he had set up so that it would not idle. You had to feather the gas at stop lights to keep it running. My own first car was a 1971 Triumph TR6 with a performance engine that sounded like three Harley V Twins side by side under the hood. I had the twin carbs leaned out so that it idled (mostly) around 600 rpm, but the needle was always somewhat spastic.
I haven't had a sports car in a long time, but after those early days I don't guess I was expecting a performance engine to idle like a sewing machine, even with electronic ignition and fuel injection. As long as it's not quitting on me, I'm not very concerned.
It's not easy to find ethanol-free fuel in my area either, and my crickets come and go intermittently. Now that you've mentioned that, I'll have to start paying attention to differences between the brands.
The Following User Says Thank You to extrashaky For This Useful Post:
CEL, Skid Light, Rough Idle ... SherbFrs Issues | Warranty | Recalls / TSB 8 07-18-2013 07:43 PM
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 09:53 AM
Looks like CEL/Rough Idle is getting a lot more attention. wawro569 Scion FR-S / Toyota 86 GT86 General Forum 11 10-06-2012 01:24 AM
Rough Idle & CEL *video JiB Issues | Warranty | Recalls / TSB 5 10-04-2012 11:28 PM
CEL and Rough Idle Issue Autonews.com article Yruyur Issues | Warranty | Recalls / TSB 11 10-04-2012 04:34 PM
