| Software Tuning Discuss all software tuning topics. |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
OEM softwear quesstion
is the stock softwear reliable. i talked to some friends who say that at high rpms, the car doesnt retard timing and causes knock? is this true or is the stock softwear completely fine. if its not i would be interested in getting a ecutek tune. i do track so i would love to get some inputs. thanks soo much for responses.
#2 |
I would be VERY suspect of anyone making claims like that without logs to prove it.
| The Following User Says Thank You to wparsons For This Useful Post: | SirBrass (03-26-2014) |
#3 | |
Shift Down
#4 | |
Drives: 2013 GBS BRZ Limited
The 2013 cars had the issue that is believed to cause the blown DI seals issue. If your car is a 2014, you already have the updated ROM to solve the transient retard issue. |
#5 |
If the ECU detects knock, it'll pull back timing, but without logs I'd be very suspicious.
#6 | |
Trust me, I'm the Doctor
My stock ROM was for the 2014 models, so I wouldn't have had the serious transient knock issue anyway.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#7 |
Not saying it can't knock on the stock tune, but if it knocks it will pull back timing. The OP's post was asking about the ECU not pulling timing if it detected knock.
#8 | |
Troll Hunter
Drives: fr-s, tundra
Definitely don't want any knock on my softwear ..
| The Following User Says Thank You to 86-tundra For This Useful Post: | OrbitalEllipses (05-09-2014) |
#9 |
Drives: Ultramarine 86 - 6MT
#10 |
The factory tune does indeed knock on 91 octane, and I've seen it knock on 93 octane as well. Most of this knock was at lower rpms 1600 - 3000rpm and with a fair amount of tip-in knock. It did not have knock issues at the high rpms.
The ECU will pull/retard timing if it is detecting knock, regardless of the rpm you are running at. There have been a few significant factory ECU flash updates since the earlier models came out. You can bring it to a local dealership to have it flashed to the latest factory update if you have not done so yet. If you have a 2014 you should be good. If you have installed an aftermarket intake, you may be running too lean depending on the intake. Modifications will need a tune the get the maximum benefit from them. - Bob |
| The Following User Says Thank You to Circuit Motorsports For This Useful Post: | steve99 (03-26-2014) |
#11 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
If you want at some point, we are close enough that you can see how my car runs with @shiv@vishnu's tune on the OFT. We can also use it to log your car if you wish. The factory tune can be all over the place sometimes. I noticed the IAM drop a few times with the stock tune, but never with Shiv's Stage 1 or EL Stage2 E85 tunes.
#12 | |
Drives: FT86
I believe your answer is here, transient knock retard was not activated in early ROM's http://www.ft86club.com/forums/showthread.php?t=50088 Depending on your fuel the stock tune knocks as per above post by Circuit Motorsports. You can also get some knock in 5000-7000 rpm WOT, yes FLCK tries to correct it but its better if you retard your timing so it does not occur in the first place. Remember the engine must knock before the knock detector can sense it and then the ecu corrects it. |
#13 | |
![]() Subaru will not bring the 2013 models up to date if your car is older than some line in the sand. |
#14 | |
