Old 08-29-2012, 10:45 AM   #1
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Angry BRZ: Voice reconginition with NAV?
I've been trying to use voice recognition with the navigation system. The owner's manual tells me it is possible, but I can't figure it out.
1) I go to the maps and hit the 'I agree' button. This is necessary to get to the navigation via speech.
2) I hit the 'speak' button on the head unit.
3) It prompts me for a command, and I say 'Navigation'.
4) I then get a text prompt that says 'That feature cannot be used with the selected voice guidance profile.' And there's an OK button, but nothing else.
I cannot find anything in the owner's manual or the settings on the head unit to alleviate this problem.
Any thoughts?
Grimlock is offline   Reply With Quote
Old 08-29-2012, 11:15 AM   #2
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
After playing with it a bit more, I figured it out. In the Navigation, go to the Settings and select Sounds and Warnings. The voice that is used to talk back to you needs to be set as Samantha, the only TTS voice in the system. Then the navigation by voice command works.
The Following 3 Users Say Thank You to Grimlock For This Useful Post:
kalamitykode (05-27-2014), kuhlka (05-30-2014), schtebie (08-29-2012)
Old 05-27-2014, 02:09 AM   #3
jcruz827
Drives: 2014 BRZ Limited 6spd Manual
Thanks!
THANK YOU! I was having issues with my GPS and the dealer nor could i figure out what was going on until now. thank you. Now I just need to solve my Bluetooth issue. It will connect and start playing my music but you hear no sound.
jcruz827 is offline   Reply With Quote
Old 05-27-2014, 02:40 PM   #4
kalamitykode
I draiv de cah
kalamitykode's Avatar
Drives: 2022 BRZ Limited MT
Mine does that every once in a while. I just turn off my iPhone and the headunit, then turn both back on and it works.
2022SubaruBRZ/CrystalWhitePearl/Limited
kalamitykode is offline   Reply With Quote
Old 05-27-2014, 04:16 PM   #5
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Fucking Samantha
Deathalo is offline   Reply With Quote
The Following User Says Thank You to Deathalo For This Useful Post:
Jive Turkey (05-30-2014)
Old 07-26-2014, 02:05 AM   #6
jcruz827
So my Bluetooth would only mess up with my Samsung Galaxy S3, but after i restarted it it was fine. Then my S3 crapped out and stopped working.
Went back to my Iphone 5 and the Bluetooth worked fine.
brz, navigation, voice
BRZ Voice Control touge-n00b Electronics | Audio | NAV | Infotainment 3 04-03-2013 04:11 PM
NOS!!! (Torreto Voice FF1) Sportsguy83 Forced Induction 86 03-19-2013 03:46 PM
handsfree voice command help lbroskee Electronics | Audio | NAV | Infotainment 5 09-13-2012 05:51 PM
Voice over IP Ideas/ Questions Tanuki Off-Topic Lounge [WARNING: NO POLITICS] 6 08-18-2012 01:17 PM
NAV Voice Directions disabled? ShoGun Electronics | Audio | NAV | Infotainment 0 07-15-2012 10:06 AM
