Drives: 2016 WRX, 2016 Corvette Z51 3LT
Shifting with a manual...
I was wondering how you guys stop. I have been off from work and have had more time than usual so I've been looking up basic pointers on the internet. I have always downshifted and then put the car in neutral once I'm in second and approaching the stop. Online, a bunch of sites are saying that this is bad for the engine and transmission. I stop the same way on my motorcycle, but don't go into neutral and shift down to first and stay in first holding the clutch in at a stop.
The other websites are suggesting that you should just shift into neutral and use the brakes, not downshift and engine brake. I do this on side streets, but not when I'm on a road where you are picking up some speed (30+ mph). Other people are saying that this is dangerous if you need to get out of the way. In neutral, if you are moving, you can shift into first anyway, so I don't really see the danger. Anyway, what do you guys normally do when approaching a stop? |
#2 |
Drives: 2013 Whiteout Scion FR-S 6MT
Downshift through the gears to 2nd, neutral at like 10mph, coast to stop. Floor it and leave everyone in the dust. Repeat.
| The Following 6 Users Say Thank You to husker741 For This Useful Post: | FRSBRZGT86FAN (04-19-2014), HunterGreene (04-22-2014), JohnJuan (04-19-2014), ProjectGT86 (04-22-2014), SalM (04-18-2014), TJ3000 (04-18-2014) |
#3 |
Drives: 2013 asphalt scion FRS
Depends on the situation I guess. Most of the time I'll pop into neutral and use brakes to stop. If I have a "sudden stop" I'll down shift a gear to let the engine help.
To my knowledge on modern transmissions it doesn't matter which one you choose.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
| The Following User Says Thank You to J_kennington For This Useful Post: | 86-tundra (04-18-2014) |
#4 |
86 noober
Drives: Asphalt FRS, 90' CRX
I usually downshift and use the gears as a brake for the most part, I have done this since I started and I have never had any premature wearing of the engine or clutch with any of my cars.
Sent from my SGH-M919 using Tapatalk |
| The Following User Says Thank You to Assphalt For This Useful Post: | racecat (04-20-2014) |
#5 |
On the bike, I rev match downshift every time I slow down or stop. Also, I always leave it in 1st just in case I need to get out of the way or shoot between two cars to avoid being run over. I've heard tires screeching behind me a couple times, and it's unnerving... So, on the bike I err on the side of safety and leave it in gear, holding the clutch lever. Clutch maintenance is far easier on the bike should it be needed.
In the car, I also rev match and double clutch nearly every downshift. Around town I'm not engine braking at 7k rpm, more like 3-4k at most and it's only as I'm slowing down. So the engine braking being bad for the car IMO, is an extremist point of view. I prefer to maintain speed and momentum, so I will downshift in anticipation of turning, stopping, etc and be in a usable gear at all times. Once stopped, I put the stick in neutral and let the clutch out so I'm not constantly riding the throw out bearing. Clutch maintenance on the car is a much more intensive endeavor, so I like to preserve it as much as is reasonable. Slightly different logic, |
#6 | |
Since I'm in the break in period on my car, I'm overly paranoid and don't want to hurt it. Shifting to neutral to stop without down shifting just seems weird to me. I do it, but just when I'm going slow and am in a low gear anyway. |
#7 |
Drives: 85.5 Porsche 944, '15 mustang GT PP
I just let the engine slow itself down while in gear. I don't downshift, just let it spool itself down and go into neutral when it's ~ 800 rpm. I don't really get the point of downshifting when stopping? I must be missing something.
| The Following User Says Thank You to Chad11491 For This Useful Post: | tobin (04-18-2014) |
#8 |
You can be in the proper gear for your speed in case you need to get the heck out to avoid a bad situation.
#9 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
Engine slow itself down to 800 rpm? Are you one of those drivers on a 1 mile stretch of road where it takes you 1/2 a mile to get to the speed limit and the rest of the way you're slowing down for the stop? ![]() Down shifting while stopping. Down shifting/Engine breaking to aid in slowing the car. |
| The Following 2 Users Say Thank You to tahdizzle For This Useful Post: | FRSBRZGT86FAN (04-19-2014), tennisfreak (04-19-2014) |
#10 |
So elite I'm 1338
When I need to slow down. I break, press the clutch, and run the gears sequentially down to 2nd, or 1st if its a complete stop.
I only engine break when I absolutely need to. Like "OMG! Dunno if I'm gonna make this one moments". |
#11 |
Gold Member
Drives: 14' SWP BRZ MT limited
Brakes only. I keep it in the same gear with clutch in until almost to a stop then neutral if I'm behind a car or right to neutral if I know how far to stop and there isnt anyone to worry about in front of me. Just harder to drop into the right gear in neutral if you need to make a correction. I use to down shift when I was younger but slowly changed to brake only to a stop
#12 |
Drives: 2014 Monogram FR-S White MT
For those of you who downshift, you are presumably riding the brakes (even lightly) to flash your brake lights.
So you heel and toe every time you slow down, or don't even bother to rev match? BTW, heel and toeing while lightly pressing on the brakes is a bit more difficult. I just keep the car in whatever gear I was in and brake. When revs hit 1K, clutch in and stop. |
#13 | |
#14 | |
If you care to know why/how: Big rigs use a dog box, (similar to many race cars) which means it has big blocky teeth that engage to each gear, no synchros. When downshifting, the input shaft on the transmission needs to be at a higher rpm, but instead it naturally wants to slow down. Synchros work for you by speeding up or slowing down the input shaft (that's the bump you feel in the stick when picking a gear) by using friction, so after the bump, the stick drops right in. With a dog box, however, it'll clash and gnash and won't go into gear until the input and output parts of the transmission are near the same speed. Here's where double clutching comes into play. If you're downshifting from 4th to 3rd, you use the engine to do what the synchros would do. You first push in the clutch, pause when the stick is in neutral. Let the clutch out. Blip the throttle (rev match). Push the clutch back in, select 3rd, and let the clutch out. What you've just done, is engage the transmission while it's in neutral, and used the engine to speed up the input shaft. Now when you select 3rd, the dog box is at a close enough rpm to drop right into gear, instead of clashing. Even with a synchro transmission, you'll feel the difference. Since the input shaft is already at the correct "rev matched" speed, the synchro's job is already done. You feel little to no bump in the stick and it just falls into place. Double clutch: 1: Clutch in, go to neutral 2: Clutch out, rev match 3: Clutch in, select lower gear 4: Clutch out, repeat if necessary or accelerate Ideally this is done rather quickly while braking, (heel & toe). This is where you brake with the inside of your foot (typically the inside ball), and use the outer edge (or heel) to stab the gas pedal for the rev match blips. The only point to doing this in a road car is for personal enjoyment, |
| A Week of A/T Manual Shifting Mode | Ocala FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 98 | 05-15-2013 03:35 AM |
| TRADE: my Silver GT Manual (October Delivery) for Pegasus White GT Manual -AUSTRALIA | ysagisan | Cars for Sale/Trade | 0 | 09-19-2012 12:24 PM |
| MT Shifting | n8dog11914 | Engine, Exhaust, Transmission | 4 | 08-28-2012 04:28 PM |
| shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 06:09 PM |
| SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado | huma | BRZ First-Gen (2012+) — General Topics | 15 | 06-14-2012 12:33 PM |
