Old 04-05-2014, 01:28 PM   #1
lukeskyplayer1
Drives: 2013 Frs
DIY NARDI install 2013 FR-S
Here is a video we did to try and help out a few others who are interested in installing a similar steering wheel.
[ame="https://www.youtube.com/watch?v=eZ2Yp2DMci4"]FRS NARDI Steering WHEEL DIY Install - YouTube[/ame]
Hope this helps out
Watch in HD por FAVOR
lukeskyplayer1 is offline   Reply With Quote
Old 04-05-2014, 04:20 PM   #2
cb7tuner
Drives: 2013 whiteout FR-S
What about the airbag light and traction control light that I've read about staying on
cb7tuner is offline   Reply With Quote
Old 04-05-2014, 05:32 PM   #3
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Nice video, nice steering wheel
What's the name of that song at the end?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 04-05-2014, 06:16 PM   #4
lukeskyplayer1
Drives: 2013 Frs
As far as the Airbag and Traction control light goes my friends states it does not show on his dash
Thanks The song at the end is called Real and True by Future
Old 04-06-2014, 12:18 PM   #5
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
if you use a Works Bell Hub it comes with resistors for the airbag and TC so they do not kick.
alpine is offline   Reply With Quote
Old 04-06-2014, 01:14 PM   #6
White64Goat
1:29 that's maybe the airbag? I hope you had the battery disconnected before you did that.............
Confusing.......what happened between around 8:08 and 8:15? Looks like there was an adapter being screwed into place and then the steering wheel was held in place and pulled away and there were wires sticking out of the center. Was there another ring screwed onto the adapter and some wires attached to the first adapter?
Old 04-06-2014, 01:30 PM   #7
lukeskyplayer1
Drives: 2013 Frs
Yea that was the first thing we did before we even started recording.
Around 8:00 he's just screwing down the actual NRG quick release that connects to your NRG Hub and then it cuts to the next seen where he is pulling the steering wheel away. The wires sticking out of the middle of that piece are for connecting your steering wheel horn. That is what the inside of the Actual NRG quick release hub looks like without the NARDI steering wheel cap over it.
Old 04-11-2014, 01:56 AM   #8
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
What was the black ring with white ribbon he removed? I heard if you remove a ring, when you signal and turn the signal stays on and won't reset. And also does his horn work? Can you do an update video to see if the TC and the ABS lights turned on ?
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
Old 04-11-2014, 12:15 PM   #9
lukeskyplayer1
Drives: 2013 Frs
I have a Picture of his dash with the car turned on so you can see all of the lights that are currently on but as far as the turn signals go he tells me that you have to almost make a U-turn for the steering wheel to actually catch and click off the signals but no his Horn does not work. WE did not hook the horn up.
We probably will later on down the road for inspection purposes but for now there is no horn. We did this install to mainly see how the Nardi will look with his interior and it seems to be as close as it can to being factory which is what he wanted.
Old 04-11-2014, 02:11 PM   #10
cb7tuner
Looks like those traction control and airbag lights are on to me
Old 04-11-2014, 03:38 PM   #11
lukeskyplayer1
Drives: 2013 Frs
Yea shows how much he knows about his FRS lol
but like I said we simply made this video for tutorial purposes, were not recommending anybody get a certain hub over another. We just wanted to show people the set up we used
Old 04-16-2014, 12:59 PM   #12
MrMarinakos
Drives: Asphalt Monogram Fr-s
Are you guys going to make a video on how to fix the lights with resistors and connect the horn?
MrMarinakos is offline   Reply With Quote
Old 04-17-2014, 01:11 PM   #13
lukeskyplayer1
Drives: 2013 Frs
Yea we probably will soon just school finals and work is keeping us busy right now.
2013 FR-S SQ Install deaddawg Electronics | Audio | NAV | Infotainment 23 01-23-2014 03:21 AM
WTB: Nardi Orido/Taniguchi Wheel keioffice Want-To-Buy Requests 0 01-09-2014 06:45 AM
Nardi Two Spoke Steering wheel Joakim3 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-22-2013 03:59 PM
FRS/ NARDI NSX/ Kouki NSX/ FORD GT Tanuki FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-07-2012 02:26 AM
Nardi and Personal Steering wheels from Jordan Innovations! Jordan Innovations Interior Parts (Incl. Lighting) 1 07-31-2012 01:59 AM
