Old 03-07-2014, 12:20 PM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
2014 Scion Display Audio problem
So after installing & connecting everything for the SDA w/ BeSpoke, my usb/aux plugs(the one on the center console, not the back of the HU) aren't working properly. USB isn't connecting to the headunit or charging my phone while the aux plug is producing incomplete audio unless I wiggle around the aux cord. I have tried connecting the usb/aux cord into both the headunit and the extension box to double check if it was a connection issue and it wasn't. So before I actually get the part replaced, is there any other testing solutions I can do?
Bach415 is offline   Reply With Quote
Old 03-22-2014, 10:51 PM   #2
ricebox
Drives: AE86 & GT86
Have nav on it? If so you have to connect the thick grey wire to the nav not the hu.
ricebox is offline   Reply With Quote
Old 03-23-2014, 12:29 AM   #3
Bach415
Bach415's Avatar
Yeah. I have nav on it. It is plugged into the nav, not the HU right now. Still getting problems aux/usb not working properly. The dealer had decided to replace the aux/usb port under warranty. The weird thing is that, if I have the usb and the aux plugged in and being used at the same time, both will work without any problems. If only one or another, the problem arises.
WTT: AVH-X3500BHS for Scion Display Audio 1ucky11 Audio/Visual, Electronics, Infotainment, NAV 3 02-12-2014 12:44 PM
Scion Display Audio Questions 1ucky11 Electronics | Audio | NAV | Infotainment 13 11-03-2013 12:51 PM
FS: 2013/2014 Toyota Display Audio defylogik Audio/Visual, Electronics, Infotainment, NAV 28 09-11-2013 05:32 PM
FS: Scion Display Audio HU ($350 shipped) SpeedLab Audio/Visual, Electronics, Infotainment, NAV 0 09-06-2013 01:13 PM
2014 Display Audio SleePi Electronics | Audio | NAV | Infotainment 1 08-13-2013 11:21 AM
