Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Audio/Visual, Electronics, Infotainment, NAV
Old 05-18-2013, 08:58 PM   #1
Integrity Concepts
Integrity Concepts's Avatar
Drives: Concepts
8" Subwoofer Enclosure Passenger Side Pre Order FRS / BRZ / GT 86 Integrity Concepts
Pre Order Sale
All four of our 2013 Scion FRS / Subaru BRZ / Toyota GT 86 Integrity Enclosure prototypes are done and we will building the production molds for these four new enclosure models! We are building the 8” Passenger side enclosure production mold next, based on the order of popular demand from our prototyping thread and poll here http://www.ft86club.com/forums/showthread.php?t=31813.
For a limited time, while the production mold is being built, we are offering a pre order sale on this 8” Passenger side enclosure. Once the production mold is finished the pre order sale will end and this model will be listed at a higher introductory sale price, shortly followed by MSRP.
Don't miss out on this great pre order sale price!
Future sales will not offer this enclosure at a greater discount
This Pre Order will close on Sunday Nov. 10th.
- 8" Passenger Side Enclosure -
Pre Order Sale Price
$279.95
MSRP $349.95
Deposit required
Product and Order Details Below and on Our Website
WWW.INTEGITYCONCEPTS.NET
Pictures are of our prototype enclosure in primer. The actual product you are purchasing will be the exact same size and shape as pictured, but will come finished in carpet to match the OEM trunk liner unless another custom finish is specified.
Product Details
The 2013 Scion FRS, Subaru BRZ, and Toyota 86 is a great vehicle platform, collaborated on and offered by 3 heavy hitters in the auto industry. In its relatively short existence it has been hugely embraced by the aftermarket parts industry and Tuners alike. While the overall response to the vehicle has been great, it has come to our attention that the factory sound system is lacking a good low end. We have subsequently designed and manufactured one of our Integrity Enclosures to help owners solve this need for bass. As with most sports cars, space is at a premium, so we have molded our enclosure to fit snugly into the corner of the trunk. Our enclosure design utilizes the trunks dead space and takes up as little truly valuable cargo space as possible, yet offers enough sealed airspace and depth to work well with a variety of subwoofers. Our integrity Enclosure is constructed of thick hand laid fiberglass to be strong and durable yet lightweight and compact. Taking every detail into consideration, we have even formed it in such a way that performance tuners can still use an aftermarket rear upper strut bar in conjunction with this enclosure. Read on for the full features, specifications, and options for this enclosure.
Enclosure Features and Specifications
  • Passenger Side 8" sealed enclosure only (Right side - when standing behind car looking into trunk).
  • Finished in carpet to match the OEM trunk liner (other finishes available upon request).
  • Approximately 0.40 cu. ft. sealed.
  • Manufactured from hand laid fiberglass to approximately 1/4” thick (comparably rigid to ¾” MDF on the flat, and stronger in the curves).
  • Between 10 lbs. - 12 lbs. total enclosure only weight.
  • 7.125" inner diameter mounting ring - industry standard and fits most 8" woofers (contact us if a larger opening is needed as we can adjust it during the manufacturing process).
  • Recessed subwoofer mounting ring with an overall diameter of 8.75”.
  • Large mounting depth houses up to approx. 5.5” deep woofer with 5.5” wide magnet (fits most 8" woofers on the market)(Because this area is tapered the overall mounting depth increases as the magnet diameter decreases, so contact us with your specific subwoofer parameters if it is close or you are unsure of fitment).
  • ¾” thick MDF sub mounting ring sandwiched between multiple layers of fiberglass CSM forming an extremely rigid front baffle that is fully integrated with the enclosure and can be screwed into again and again.
  • Back of enclosure coated with a thick layer of spray on acoustical sound deadening.
  • Filled with polyfill acoustical dampening material for a smoother bass response.
  • Gold plated bolt through speaker terminal pair that accept up to 8 gauge wire.
  • Included is 2 - 3 ft. of 12 gauge twisted speaker wire inside the enclosure.
  • Included mounting brackets are designed to hold your enclosure securely in place yet allow quick and easy tool less removal of the enclosure within seconds for simple access to the spare or for track days.
  • No drilling into the vehicle or cutting of the trunk liner will be required to secure this enclosure, meaning you can return your vehicle back to factory condition, which is perfect for those leasing their vehicle.
  • Designed to allow the use of aftermarket rear upper strut bars.
  • 5 year limited warranty on enclosure manufacturing defects (improper installation, accidents, wear and tear, and abuse will not be covered)
  • Manufactured and assembled in the US with the highest levels of attention to detail and quality craftsmanship.
** This enclosure will fit perfectly in the right side corner of the trunk, on top of the factory carpeted spare tire cover and in front of the factory carpeted trunk wall. It was not designed to be installed with an add on trunk floor mat or cargo tray in place, therefore we cannot guarantee a perfect fit of our enclosure in those circumstances.
Optional add-ons and Customizations
available upon request at an additional charge
  • Optional pressure fit carbon steel pressed grill with trim ring can be added to this enclosure at any time (Trim ring can be color customized - painted or wrapped in suede or vinyl and grill can be color customized.)
  • The enclosure’s internal airspace can be adjusted, during the manufacturing process, to any volume below its standard 0.40 cu. ft. for a more accurate match to your woofer’s recommendations.
  • An extra pair of gold plated speaker terminals can be added to the enclosure.
  • This 8” enclosure can be modified to house a 6” woofer.
  • The enclosure can be wrapped in various finishes, custom painted, or even overlaid in real carbon fiber.
  • Additional customization requests are always welcome.
Order Details
Go to our website:
WWW.INTEGRITYCONCEPTS.NET
  • A $100.00 deposit is all that is needed to put your name on the list to receive one of the first production enclosures off the line, and secure this special pre order sales price!
  • Deposit will be non-refundable as it will be used to help fund a portion of the cost of making the molds.
  • Once the production mold is finished and the first products are being manufactured you'll be contacted about the available options you may like with your enclosure. Once all the details are settled you will receive an invoice with the remaining due plus shipping charges.
  • You will need to pay the invoice that includes the remaining due before your item will be shipped.
  • We will fill the pre orders in the order they are received.
Lock in this low $279.95 sale price
Click here to go to our website and place your
$100.00
Pre Order Sale Deposit
Note: When the production mold is done for this enclosure this special pre order sale will close.
This Pre Order will close on Sunday Nov. 10th. We will then begin filling the pre orders in the order they were received
If you are wanting to purchase a pair of enclosures (Passenger and Driver side), you can still get in on this sale and just specify to be notified when the Driver side 8" pre order sale is released. We can then ship your enclosures as you prefer, either together when they are both completed or individually as they are each completed.
PM or Email Us for Shipping Estimates
Brief Details About Shipping Estimates
We will ship the final product insured using UPS Ground for orders in the US, and USPS Priority for international orders. Contact us via PM, email, or our contact form with your city and area code for an estimate of the shipping charges that would be due before your product ships. Please be aware that if you are attempting to calculate your own shipping charges through the UPS or USPS websites, dimensional weight is applied at roughly 32 lbs. by the carriers because of the size of the shipping box (18”x18”x16”). Also our rate quotes may be less based on our agreement and volume shipped with them. If a faster shipping method is desired, please contact us.
Last edited by Integrity Concepts; 11-06-2013 at 03:38 PM. Reason: Update links and Dates
Integrity Concepts is offline
Old 05-18-2013, 10:52 PM   #2
wdninja
wdninja's Avatar
Drives: 2023 Toyota GR86 Premium
Deposit made for 8" passenger side enclosure!
2023 Toyota GR86 Premium, Neptune Blue Gasket Ninja.
wdninja is offline
Old 06-15-2013, 10:15 AM   #3
djdnz
1337
Drives: 2013 BRZ WRB S/C
Deposit made, now I gotta get shopping for some audio equipment! Thinking Alpine Type-R 8" with the Alpine MRX-V70 5 channel amp.
djdnz is offline
Old 06-15-2013, 10:29 AM   #4
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Do you guys have a recommended amp installation location? If not, maybe v2 of this enclosure could include some sort of amp mount. I found it a little difficult to figure a good location to install an amp that is out of the way but still gets adequate cooling.
mit_peid is offline
Old 06-17-2013, 04:40 AM   #5
nix
nix's Avatar
Drives: AVO BRZ
+1 on hidden amp mount for driver side 8/10 boxes.
nix is offline
Old 06-18-2013, 07:33 AM   #6
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I'm not sure if this will help you out but I decided to mount mine in the top portion of the trunk. It is out of the way and has no air restrictions.
shiro is offline
Old 06-18-2013, 09:36 AM   #7
mit_peid
Boosted Noob
mit_peid's Avatar
I'm not sure about Alpine amps, but the instructions that came with my Rockford amp said not install them upside-down for heat dissipation reasons. I'm sure it's fine as long as you're not running full power for long durations, but yeah that is a good location. I've seen some great installs of smaller amps (but right-side-up) in a fabricated rack at that location. I would love for somebody to produce that rack for others to buy.
mit_peid is offline
Old 07-16-2013, 02:57 PM   #8
wdninja
wdninja's Avatar
Any updates? Looking forward to getting this installed.
wdninja is offline
Old 07-18-2013, 03:08 PM   #9
Integrity Concepts
Drives: Concepts
We want to sincerely apologize for our lack of communication over the last few weeks. We are currently moving our shop and it has cut into production more than we anticipated. We hope to be back to full function by the end of next week. I will update on the progress of our enclosures as soon as I get everything unpacked and am able to make an accurate assessment.
Old 08-01-2013, 10:08 PM   #10
wdninja
wdninja's Avatar
Ok thanks for the update, good luck getting settled in.
wdninja is offline
Old 08-21-2013, 01:40 PM   #11
Integrity Concepts
Drives: Concepts
Things are really coming together and starting to get back to normal around here! We are no where near 100% again but we are seeing many of the processes come back in line. We finally finished getting our compressor wired up, plumbed, and running yesterday which is a huge necessity for the trimming and finishing steps. We have several Passenger side 10" enclosures waiting to be trimmed, several more awaiting the sound deadening treatment, and even a couple waiting for primer in preparation for paint. As soon as we get some of these Passenger side 10" enclosures moving through these processes and shipping again (especially for those who are still patiently waiting from the original pre order), I will start back on the 3 other production molds (8" Passenger side and 8" / 10" Driver side) where we left off. I am hoping this will be at the beginning of next week if all goes smoothly!
This move has been extremely overwhelming and as we all know time consuming, but we are very excited to see it all come back together in our new shop space, which is more than double the size of our last one. This space should allow little to no juggling of the various steps in the same areas (like we had to do before) thus saving time and hopefully increasing our production.
Thank you all for your kind words and wishes, and especially for being patient and sticking with us through this!
Dan - Integrity Concepts
Old 08-29-2013, 12:17 AM   #12
obriennathaniel
obriennathaniel's Avatar
Drives: Satin White Pearl Limited BRZ
i just pre-ordered the 8" passenger & driver side!
im pretty damn excited!
Full LED replacement| LED Fog lights| Tein S-Tech Springs| 19x8 TSW Nurburgring| 235/35 Nitto Motivo| Borla UEL headers| Perrin overpipe/frontpipe| Greddy Evo3| Greddy CAI| 86Motoring Pulleys| RF T2 components| RF T1 4" coaxial| RF 3Sixty.3| JL HD600/4| Kicker IX1000| 2 Kicker CompR 8"
obriennathaniel is offline
The Following User Says Thank You to obriennathaniel For This Useful Post:
Integrity Concepts (08-29-2013)
Old 09-30-2013, 05:55 PM   #13
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Bump!
chanomatik is offline
Old 10-08-2013, 04:24 PM   #14
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
So... are these available or still just a pre-order? It's been a while and this thread seems fairly dead. Thanks!
FR-S / BRZ / GT 86 - Fiberglass Subwoofer Enclosure Prototyping by Integrity Concepts Integrity Concepts Electronics | Audio | NAV | Infotainment 302 11-16-2018 11:47 PM
fan noise / passenger side itsfun Issues | Warranty | Recalls / TSB 17 03-09-2018 10:37 AM
10" Subwoofer Enclosure Passenger Side Pre Order FRS / BRZ / GT 86 Integrity Concepts Integrity Concepts Audio/Visual, Electronics, Infotainment, NAV 103 06-24-2014 12:08 PM
10" sub+enclosure+amp for sale fmsida Audio/Visual, Electronics, Infotainment, NAV 4 04-11-2013 03:51 PM
