Old 06-20-2013, 01:36 PM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
EcuTek RaceRom Questions.
After Reading through Johns latest Racerom features for the GTR.
http://www.gtrlife.com/forums/topic/...-advancements/
I noticed this.
RACEROM Knock Light via CEL
Is this a GTR only feature? Seems it maybe useful for us as well.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-20-2013, 02:26 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
One thing I miss about Kpro is that exact feature plus another...
You could set lean protection, where you can specify a MAP sensor reading threshold (boost) and Lambda (AF:R) to protect against damage caused by a lean condition.
Say I set the MAP threshold to positive boost pressure, and AF:R to 12.5.... if I am boosting and the AF:R goes more lean than 12.5, the engine will cut all power. Useful if a fuel pump goes bad or any other reason where you would lean out and cause potential engine damage.
You can also set a trigger delay in milliseconds, for lets say you mash the throttle with a centrifugal supercharger and there is an instant of "lean" because of the instant boost
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-20-2013, 05:19 PM   #3
feldy
feldy's Avatar
Maybe @Visconti knows since I stole the description from his GTRlife thread. ha
Maybe Tony knows to. @FA20Club.com Tony have you seen this feature in any of the ecutek stuff for the twins?
Old 02-12-2014, 02:48 PM   #4
EcuTek
Drives: Toyota GT86
I noticed this.
It’s not available at this time. The knock control on the BRZ works in a different way meaning it is not so easy for us to add this feature. We are looking at it as a potential future update.
EcuTek is offline   Reply With Quote
Old 02-12-2014, 02:51 PM   #5
EcuTek
Drives: Toyota GT86
You can do this using custom maps and importing a wideband sensor. You will need to purchase the RaceROM BRZ upgrade to get Custom Maps. To understand how to do this, see page 53 - 55 of the EcuTek BRZ Tuning Guide. Hope that helps!
Old 02-12-2014, 03:18 PM   #6
jamesm
You can do that with a custom map. I have mine set up to close the throttle if it goes too lean under boost as well.
Edit: sorry didn't see the post above lol
Old 02-12-2014, 05:04 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
Yup, just realized that. I keep forgetting that with custom tables you can do a LOT. Kpro had no custom tables so you relied on hardcoded options and setup menus
2013 FRS
Vortech V3 11psi
Old 02-12-2014, 05:07 PM   #8
jamesm
it'd really be easier to try and list the things you can't do, which there are some. i can think of a few input and outputs i'd like, but aside from that...
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 03:55 PM
Ecutek RaceRom Custom Features Manual iBRZ Software Tuning 33 07-25-2013 02:39 PM
EcuTek racerom feature help lbroskee Engine, Exhaust, Transmission 10 05-08-2013 11:45 AM
EcuTek Questions. feldy Engine, Exhaust, Transmission 2 03-15-2013 07:39 PM
ecutek cable and license questions bulldog11267mad Engine, Exhaust, Transmission 11 12-14-2012 09:01 AM
