Dynosty Tuned FR-S yields 355WHP with GTX28 Turbo and E85
The Dynosty team specked out a GTX28 turbo kit and E85 fuel to create an awesome stock-engine power plant. After installing the turbo kit, we bolted up Motiv concepts over pipe and front pipe, and then a MXP exhaust system. The fuel system was upgraded with a set of Dynosty 550cc plug&play injectors and drop-in fuel pump. We replaced the clutch and flywheel in favor of an ACT clutch kit that would hold the power.
With all of the parts in place, it was on to the dyno where we used EcuTek to dial in 264WHP DD on pump gas (300whp Dynojet). At this point, the fuel was exchanged for E85 and we increased boost to 13psi yielding 355WHP DD (400WHP Dynojet). ![]()
| The Following 2 Users Say Thank You to Hal@Dynosty For This Useful Post: | MAPerformance (12-12-2013), SnapOv3st3r (12-21-2013) |
#2 |
NASA SpecE30 Racer
Looks like the @FullBlown kit but shouldn't the GTX28 have a V band exhaust housing? Great numbers as usual, and I love that flat torque curve from 4400 RPM to redline.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#3 |
PhoneFlash by EcuTeK
Looks good. Nice smooth curves.
Are you running MAF or Speed Density? Also how is the bottom end holding up. Think it is good for any more power on the stock bottom end? Cheers, William Knose |
#4 |
Yes, it's a base kit with turbo upgrade. +1 on torque curve!
#5 |
#6 | |
Boosted
Drives: Not a supra....yet
Nice numbers guys |
#7 |
Drives: Asphalt FRS
You guys are killing it right now! Love to see some good stuff coming out of your shop. Also digging that torque curve
#8 | |
#9 |
Drives: AE86, 2x GT86, TE27
What spec was the GTX28? 63 or 67 compreesor? 0.86 turbine A/R Im assuming?
Cheers |
| The Following User Says Thank You to diss7 For This Useful Post: | DriftEightSix (12-13-2013) |
#10 |
Pegasus White
Drives: 86
You able to give us an boost map?
& dyno for no e85 run?
Driving: Pegasus White Manual GTS 86.
#11 |
#12 |
weird you ran out of maf. i run 15psi on e85... probably 340+whp and only see 4.9v. what size is the intake pipe on the full blown kit?
#13 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Really nice stuff!!
However, I do have to nit-pick about the chart scaling.. 500 hp max Y-axis on a 355 hp plot, coupled with an already wide aspect chart. It just makes it difficult to see the torque/power curves with any kind of detail. |
#14 |
Drives: 2013 LTD BRZ
They are running blow through, which usually causes the top end to get flaky when your running near the edge of the maf limit. Blow through setups usually also need to be sized slightly larger to be equivalent to a draw through setup to get the resolution you want. And placement is very important, 12 inches of straight pipe with an air straightener is usually what I like to see in a Blow thru MAF setup. To close to a bend, or no air straightener just makes it harder to tune, and will cause inconsistencies that cant be tuned out if its bad enough. You may already know this from working on your setup, but 99% of the time its still easier to tune blwo thru's via hybrid SD...
| Tags |
| dynosty, ecutek, scion fr-s, subaru brz, turbo |
| Dynosty Greddy Turbo FR-S Doubles Stock WHP | Hal@Dynosty | Forced Induction | 17 | 03-03-2016 03:03 PM |
| Vortech frs e85 Dynosty tuned | charged86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 06-19-2015 01:52 AM |
| Dynosty Tuned 530WHP 439TQ Toyota 86 with GTX3076 Turbo | Hal@Dynosty | Forced Induction | 16 | 10-12-2014 11:59 AM |
| New Vortech Quarter mile record 13.1 Dynosty tuned | charged86 | Forced Induction | 21 | 07-30-2013 09:32 PM |
| Dynosty Turbo FR-S Videos | Dustin@Dynosty | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 11-01-2012 11:57 AM |
