Old 01-17-2017, 05:12 PM   #1
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Parallel Fuel Pumps
I'm working on fitting a second OEM pump into the passenger side of the saddle tank. I saw a closed thread from Accelerated Performance/Visconti about them doing so, but the kit was over $1k. Reason behind this is to prevent leaning out during cornering/powering out of a tight right corner under 1/2 tank of fuel. Also increased fuel volume for boost/E85.
I was wondering if anyone else has rigged up a setup like this. I'm planning on opening up the canister and tank to get a better idea what I'm looking at but I was thinking of splicing the passenger pump into the power for the drivers pump and putting a Y connector to send both pumps feed up front. Need to open the canister to see about mounting the pump still.
I'll document all my investigations when I get some time to work on the car, for now I'm asking if anyone has experience with this, and any problems they ran into.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 01-17-2017, 05:22 PM   #2
Not sure what (if anything) is available but what about just getting a single higher volume pump and then just splitting the intakes off into both sides of the tank? Installing a second pump will be major surgery for very limited gains.
Old 01-17-2017, 05:52 PM   #3
Tedderple
Drives: 2015 FRS Halo (White)
What about the hydramat for scavenging fuel?
http://www.motoiq.com/MagazineArticl...-Hydramat.aspx
AVO Turbo with FlexFuel| Perrin 2.75" CAI(gone) | Now: Perrin 3" Catback | MXP Comp RS Catback(gone) | Magnaflow Catback(gone) | Gruppe-S UEL Headers (gone) | 18x7.5 TE37 on Firehawk Indy500 225/40/18 | Valenti Tail Lights | Drift-Office Tuned 220whp-350whp
Tedderple is offline   Reply With Quote
Old 01-17-2017, 10:09 PM   #4
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Agree
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 01-17-2017, 10:19 PM   #5
It seems like the design of the venturi pump for the right side of the tank is either flawed or the location for the pickup is.
Just spitballing. I've wondered but never seriously studied the issue.
Old 01-18-2017, 07:53 AM   #6
RedFR-s
RedFR-s's Avatar
The issue is the venturi system to get gas to both sides of the tank especially when at lower levels. Are you talking about adding a pump external to the tank and drawing from both sides, or higher volume on the driver's side piped to pull from both sides?
You got me thinking now though. it might be easier to T the pump intake and run a line out of the canister across the tank to the passenger side. If I combine that with the smaller hydramats then I don't have to worry about air going through the pump from the empty canister.
Andy
Old 01-18-2017, 08:03 AM   #7
RedFR-s
RedFR-s's Avatar
That might work by keeping the fuel trapped on the driver's side. Connect it directly to the fuel pump, it would replace the canister. I will look further into this. Thanks.
Anyone used these on our cars in the stock tank by chance?
Andy
Old 01-18-2017, 08:04 AM   #8
RedFR-s
RedFR-s's Avatar
http://www.ft86club.com/forums/showthread.php?t=36231
Post #32 explains pretty well the issue. Just trying to avoid a $1k+ solution for it if possible.
Andy
Old 01-18-2017, 09:28 AM   #9
Was thinking a stronger single pump on the right and teeing off to both saddles.
Old 01-18-2017, 10:04 AM   #10
RedFR-s
RedFR-s's Avatar
I think I've got it figured out. Radium engineering has an adapter to 5/16 line from the fuel pump, stainless steel T from there out to a 8"x3" Hydramat on each side of the saddle. Would cut the bottom of the canister out and essentially by pass it. All in it's under $500USD.
This is why I love the forum and no idea is a bad idea.
Andy
Old 01-18-2017, 10:14 AM   #11
Yep that is pretty much what I pictured. Beats hell out of trying to add a second pump.
Old 01-18-2017, 11:14 AM   #12
slowest86
Drives: slow frs
Radium has a nice surge tank. http://www.radiumauto.com/MPFST-Mult...Tank-P271.aspx
slowest86 is offline   Reply With Quote
Old 01-18-2017, 02:33 PM   #13
RedFR-s
RedFR-s's Avatar
Originally Posted by slowest86 View Post
I'm looking to avoid surge tanks as I don't want fuel outside of my tank. Run into all kinds of issues for many different racing series and tracks.
Andy
Old 07-03-2017, 06:48 PM   #14
Hags86
Drives: Toyota GTS 86
I was talking with one of the TR86 Race Teams here in Australia (the Toyota spec racing series) about this. Their configurations are all specified by the race series organisers who do some engineering and determine what configs all the cars must run.
It is my understanding that they have installed a second OEM fuel pump in the left hand saddle. It's role is to pump fuel into the right hand side saddle where the standard pump and pickup is.
Seems like a simple solution that doesn't require an external surge tank. I'll try and find out some more info but if anyone has done this I'd like to see the details.
Hags86 is offline   Reply With Quote
FS: OEM Fuel tank with pumps MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 3 06-02-2016 03:08 PM
Aeromotive 325 fuel pumps 1stGenBRZ86 Forced Induction 12 05-05-2014 06:22 PM
Please read if swapping fuel pumps Dipstik-sportech Forced Induction 5 06-17-2013 02:39 PM
*** Introducing the SBD290 DROP-IN Fuel Pumps for the BRZ/FRS/GT86 *** Visconti Engine, Exhaust, Bolt-Ons 21 03-08-2013 01:50 AM
SEMA 2012 Coverage - Deatschwerks Fuel Pumps and Injectors *Video Interview* Circuit Motorsports Engine, Exhaust, Transmission 0 11-13-2012 07:40 PM
