Old 06-02-2013, 01:15 PM   #1
charged86
charged86's Avatar
Attention All VENDORS Speed shops!
The frs/brz/gt86 needs your help!!!. we need and adequate fuel solution to the following: (anyone please help me add or delete these requests)
1. Direct injector O-ring solution.
(higher temp rated Teflon or billet aluminum or ceramic
2. Fuel return system (we need one)
@Visconti @Don@Accelerated
3. Fuel canister rubber ring (whole canister revision?)
(oem Subaru part # 42025CA000. beginning to believe this should
replaced and included in aftermarket pump sales)
*also we need a better diy*
4. root cause of the reason for failure. ECU tuning, fuel type, etc
Since all of us forced induction guy have no warranty left and these issues are a major part of any FI system we need to have something fool proof and reliable. Please help. GOD Speed.
@FT-86 speedfactory FT-86 SpeedFactory
@FullBlown
@Jesse@JDLAuotdesign JDLAutoDesign
@AVOturboworld
@Abel_PTUNING
@FA20Club.com
@Brian@Vortech
@Evasive Motorsports
@Titanmotorsports
@PERRIN_Jeff
@RallySport Direct
@MAPerfomance MAPerformance
found this on direct injection o rings
http://www.pspglobal.com/oscillating.html
found this on mk6 Volkswagen forums
http://www.golfmk6.com/forums/showthread.php?t=37349
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
The Following 9 Users Say Thank You to charged86 For This Useful Post:
ATL BRZ (06-06-2013), CSG Mike (06-03-2013), dabocx (06-02-2013), DAMotorsports (06-04-2013), jonbonazza (06-02-2013), Lonewolf (06-06-2013), Pete (06-02-2013), Splat (06-03-2013), Sportsguy83 (06-02-2013)
Old 06-02-2013, 01:31 PM   #2
Dezoris
Dezoris's Avatar
Just to add this in we need root cause of the reason for failure. ECU tuning, fuel type, etc.
The Following User Says Thank You to Dezoris For This Useful Post:
charged86 (06-02-2013)
Old 06-02-2013, 01:33 PM   #3
charged86
charged86's Avatar
added problem #4
Old 06-02-2013, 01:45 PM   #4
jamesm
Teflon is Dupont-marketing speak for PTFE, which is only good to 300c. It also can kill you if you overheat it and breathe in the fumes. PEEK is good to ~250c. If you want to insulate much higher temps that that, you would typically use some sort of ceramic.
What kind of temperatures are we dealing with here?
edit: in response to the comment above, i agree 100%. the solution isn't a new, higher temp material. the solution is to keep the temps from getting that damn high in the first place, and that's a tuning issue (i believe).
The Following User Says Thank You to jamesm For This Useful Post:
Old 06-02-2013, 02:19 PM   #5
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
According to Toyota(or was it Subaru?), we're dealing with combustion temps during knock. Apparently the combustion pressure is pushing the injectors up out of the chamber, allowing the burning gases to squeeze past and damage the seal/injector body.
If that's actually happening, then we aren't going to find a seal that will fix it, it'll just make it take longer to start misfiring or whatever it does that generates the DTCs, and it really is a tuning issue and not a hardware issue.
Sellout is offline   Reply With Quote
The Following User Says Thank You to Sellout For This Useful Post:
jamesm (06-02-2013)
Old 06-02-2013, 02:58 PM   #6
charged86
charged86's Avatar
Well I believe my tuning will keep that from happening I don't continuely push my car hard maybe 3 2 gear street pulls no track. I always use 93octane.
How can it push the injector out if its bolted in a few places. I thinks its melting then shoving the Teflon seal outward
Old 06-02-2013, 03:00 PM   #7
FT_Monk
Drives: Over the hill WRX
How about copper seal for the DI injector?
FT_Monk is offline   Reply With Quote
Old 06-02-2013, 03:01 PM   #8
Frs300
Frs300's Avatar
Drives: Pile of junk
@charged86 what size are the teflon seals do you know? or anyone else for that matter
Frs300 is offline   Reply With Quote
Old 06-02-2013, 03:04 PM   #9
Sellout
Mr. Cranky Pants
Sellout's Avatar
It doesn't have to move much, and the kind of pressure the combustion chamber sees during knock would easily be enough to shift the injector around a little tiny bit, but the injector itself could be getting hot enough to melt it maybe? Is there no thermal barrier in the body of the injector to protect the seal?
Old 06-02-2013, 03:18 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Not exactly size, but a good starting point to find out:
http://www.ft86club.com/forums/showp...4&postcount=17
Originally Posted by romin View Post
Given this diagram:
I believe this teflon ring is the part that folks have found damaged or completely missing from their direct injectors:
Can someone confirm?
Did other folks find additional parts damaged?
Update, others have also found these insulators damaged on many vehicles:
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 06-02-2013, 03:21 PM   #11
s2d4
s2d4's Avatar
Why?
Old 06-02-2013, 03:25 PM   #12
charged86
charged86's Avatar
Originally Posted by s2d4 View Post
Why?
Because Jon@visconti knows his tuning. I said believe I don't have raw data of my own vehicle yet
Old 06-02-2013, 04:43 PM   #13
wootwoot
Drives: FRS
We are in very capable hands. Good luck boys. I'll have my credit card ready!
The Following User Says Thank You to wootwoot For This Useful Post:
Old 06-03-2013, 07:47 PM   #14
charged86
charged86's Avatar
Nobody gonna touch this with a ten foot pole aye?
The Following User Says Thank You to charged86 For This Useful Post:
Sportsguy83 (06-03-2013)
*** ATTENTION ALL VENDORS - CLASSIFIEDS SECTION RULES!! READ OR RISK BAN *** Hachiroku Brakes, Suspension, Chassis 11 02-25-2014 02:51 PM
*** ATTENTION ALL VENDORS - CLASSIFIEDS SECTION RULES!! READ OR RISK BAN *** Hachiroku Interior Parts (Incl. Lighting) 5 10-11-2013 02:47 PM
*** ATTENTION ALL VENDORS - CLASSIFIEDS SECTION RULES!! READ OR RISK BAN *** Hachiroku Engine, Exhaust, Bolt-Ons 12 10-11-2013 02:40 PM
*** ATTENTION ALL VENDORS - CLASSIFIEDS SECTION RULES!! READ OR RISK BAN *** Hachiroku Transmission and Driveline 0 07-25-2012 02:00 PM
