Old 05-16-2013, 05:49 PM   #1
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
Local airport has 100 octane gas, would it be harmful to run?
So, as the title suggests, the local airport has 100 octane Low Lead aviation fuel for about 4.80 a gallon. I'm curious if it would be harmful to run in this engine. I've run the gas before in my dirtbikes with no ill effects whatsoever, but I'm assuming with three extra cylinders it would be a different story.
The engines used in all the Cessna's are all horizontally opposed 4 cylinder engines, so they are somewhat a close cousin to the engines in these cars. I know it says unleaded fuel only but I've never quite understood why and if it would be harmful to run a low lead gasoline in the car. Any help would be appreciated, and if this thread needs to be moved please do so mods.
VesperLynn is offline   Reply With Quote
Old 05-16-2013, 06:03 PM   #2
UncleFester
Why would you want to?
UncleFester is offline   Reply With Quote
Old 05-16-2013, 06:04 PM   #3
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
you'd have to remove the cats to run leaded fuel!
Sbeezy is offline   Reply With Quote
Old 05-16-2013, 06:04 PM   #4
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Because racecar
(Sorry, had to )
Myv is offline   Reply With Quote
The Following 2 Users Say Thank You to Myv For This Useful Post:
Inzandity (05-16-2013), WRXGuy1 (05-20-2013)
Old 05-16-2013, 06:08 PM   #5
Sbeezy
http://www.ehow.com/facts_7826145_le...onverters.html
Old 05-16-2013, 06:12 PM   #6
SkullWorks
Drives: SSM LT MT BRZ
Lead contaminates and reduces the effectiveness of the catalytic converters, it also coats the O2 sensor rendering it useless in a much shorter time period.
Long story short, long term drawback probably not worth short term gains
The Following User Says Thank You to SkullWorks For This Useful Post:
strat61caster (05-16-2013)
Old 05-16-2013, 06:24 PM   #7
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Most Cessnas run horizontally opposed engines, yes. However, they run carbureted, low compression (~7:1), air-cooled horizontally opposed six cylinder engines that have a design dating back to about the 1940s. Your engine has very little commonality with the aviation engines aside from which directions the pistons travel.
Oh, and definitely don't run leaded gas. You can find race gas some places if you really have a hankering to run high octane. You won't gain anything from it though unless you have made other modifications as well.
chrisl is offline   Reply With Quote
Old 05-16-2013, 06:40 PM   #8
VesperLynn
VesperLynn's Avatar
Drives: Subaru BRZ
I think I should state again that I'm not necessarily saying that I'm going to start pouring the blue stuff into my tank, I was just simply curious. Just trying to understand all the mechanics better!
The Following 2 Users Say Thank You to VesperLynn For This Useful Post:
LeeMaster (05-16-2013), RAWR BRZ (05-16-2013)
Old 05-16-2013, 06:49 PM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Higher octane won't improve anything over what the engine is designed to run on.
A higher compression ratio may warrant it, but the lead is not a good idea.
Wasn't speeding officer, only flying really low.
Old 05-16-2013, 08:44 PM   #10
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
No, don't use it. Check with your local Sonocos as they are somewhat likely to carry race gas. However, I think you wont notice much other than the nice smell.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 05-16-2013, 09:08 PM   #11
bestwheelbase
Drives: 1985 P-Type
Here's the VP race fuel distro for Oregon. http://repowell.net/vp-racing-fuel.html
Old 05-16-2013, 09:52 PM   #12
Allch Chcar
Drives: N/A
Originally Posted by VesperLynn View Post
... I know it says unleaded fuel only but I've never quite understood why and if it would be harmful to run a low lead gasoline in the car. Any help would be appreciated, and if this thread needs to be moved please do so mods.
Lead will damage the catalytic converters($$$$). It's part of the reason lead was banned from Gasoline in the 70's.
Either look for unleaded race gasoline or E85. Don't forget the ECU tune.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 05-16-2013, 10:02 PM   #13
Liquidsnake
Drives: "I drives like a Porsche"
Originally Posted by Myv View Post
Because racecar
(Sorry, had to )
Lol.
Liquidsnake is offline   Reply With Quote
Old 05-16-2013, 10:15 PM   #14
ianz28
Drives: 09' VW GTI
If you are in Portland there is a gas station off of MLK up by PIR that sells pure 93 octane (no ethanol) and 107 octane sonoco race fuels.
ianz28 is offline   Reply With Quote
FR-S at Williams Airport texas2888 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-22-2013 12:34 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
Buckingham Airport AutoX - Ft. Myers, FL - 11/11 raul Southeast 0 10-29-2012 08:26 PM
Baltimore airport. Any frs/brz guys here? Hardrock4445 Off-Topic Lounge [WARNING: NO POLITICS] 0 10-27-2012 08:50 AM
